Old 30th September 2005, 23:33   #31
Amjad Ali
Amjad Ali's Avatar
Garage: 740i Daily Driver Waiting for a B7
Re: The 21" Tire dilemma . (long)
Originally Posted by sydl
What has? The wheels? I'm not talking about the wheels.
The issue is whether a non-OEM tyre, on a car is covered by the car owner's insurance. Passing a TUV test is not what our laws and local authorities and insurance company looks at. All they care about is whether the tyres (not wheels) are as per the manufacturer's specifications. It's really got nothing to do with the wheel manufacturer Hartge - it's the driver/owner - the person who sold/put the tyres on the car.
The TUV process invloves testing of both the wheels and tyres.
The final TUV certificate states the vehicle, wheel sizes, and exact tyre sizes and manufacturer(s) in most cases if they have tested more than 1 tyre. The TUV would highlight the fact that the tyre is not correct. The way they check if the tyre is correct for the car is by using TUV's data of that particular car, which in this case has been supplied to them by BMW. Believe me if the tyre was not as per manufacturers specification then they would not approve it for TUV.
I hope that clarifies it.
Amjad Ali is offline
Old 30th September 2005, 23:37   #32
Amjad Ali
Amjad Ali's Avatar
Originally Posted by m5-black
One other Insurance matter that was raised was durabiity, as In Ireland and some parts of the UK pot holes are a real problem and seeing as the 21" Tires are
255 / 30
295 / 25
Maybe with our less then stellar rural roads, these might be risky.
any opinions on the durabilty of Contis in the /30 /25 range
Hi M5-Black
I have not used 21" conti's but have used Conti's in 255/30/20's and 305/25/20's sizes on SL55 AMG's with no problems. Yes you will have to be a bit careful when you drive them on bad roads, but that is accepted when you are running such low profiles.
And to think my first Alpina B9 ran 225/50/16's on the rear and I thought they were low profile and really wide!!!!
Old 1st October 2005, 00:28   #33
sydl
sydl's Avatar
Garage: Carbon Black M5
I've called The NCT people - Ireland's MOT and spoken to the insurance company.
The NCT will pass the tyres they have absolutely no issue with them as long as they are fitted and inflated correctly
The insurance company had no problem, they just wanted to know it would pass the NCT.
Very interesting - sounds like your authorities and insurers aren't as strict as down under.
It sounds like they don't care about load rating.
sydl is offline
Old 1st October 2005, 01:08   #34
Amjad Ali
Amjad Ali's Avatar
Sydl the insurers here would not even know what a load rating was!!!
All they ask is are you running aftermarket wheels what they cost and if they increase the value of the car.
Old 1st October 2005, 04:07   #35
frylord
frylord's Avatar
Garage: 2000 525TDS
Same over here aswell. I can imagine that this is something that wouldn't apply to a "regular" road going car which can barely reach 200km/h (124mph) and doesn't do the hard acceleration and breaking an M5 does. If you fit 17, 18 or maybe even 19 inch rims under a "ragular" car then I can imagine that there is a very wide range of tyres you can choose from and almost any tyre will do. These cars probably make up 99% of their bussiness.
But for a car like the M5 or whatever other "supercar" (I don't concider the M5 to be a supercar cause it's not supposed to be, although it is) which can easily run +300 km/h and can do very hard acceleration and breaking this becomes a mayor safety issue. But because it's not part of their everyday bussiness they're not aware of it or simply don't care.
Ofcourse this is sepculation but it should be something every M5 owner should be aware of, make sure you have the correct tyres before you decide the pull the throttle to full or else very bad things might happen. Specialy make sure the pressure in your tyres are correct before doing 250 or 300 km/h cause it's very easy to destroy your tyres at those speeds.
frylord is offline
Old 3rd October 2005, 01:33   #36
frylord
frylord's Avatar
Garage: 2000 525TDS
Okay I did some research on the subject and this might come as a shock.
If you get a aftermarket exhaust then you need a certificate saying the new exhaust conforms to sound and emission regulations.
If you get your front windows tinted (rear can be as dark as you want) you need a certificate saying the windows still have a x percentage shine through and have good visibility.
But if you get new wheels, you don't need anything.
frylord is offline
Old 3rd October 2005, 01:38   #37
m5-black
m5-black's Avatar
Garage: E60 Black m5
Yep same here - As noise and emissions get tested during our National Car Test Agency test - and Tinted windows will be checked
Whereas Tyres - only have have correct tread, be fitted correctly, have no serious damage and not protrude too far.
m5-black is offline
American V-8 Supercars Announces Nitto Tire Deal DHR Track and Racing Forum 0 18th February 2005 06:08
"When should I replace my tires?" per Tire Rack howler E39 M5 and E52 Z8 Discussion 1 4th February 2005 00:12
Ground effects & Tire Problems unespekta E34 M5 Discussion 11 12th November 2004 02:00
Largest Tire on 8.5 x 19 2003 M5!!! E39 M5 and E52 Z8 Discussion 8 2nd July 2004 19:50
First track day of season (long) SMB M5 E34 M5 Discussion 0 12th June 2000 23:52
Page generated in 0.14872 seconds with 11 queries
