Gear selector stuck - BMW M5 Forum and M6 Forums
post #1 of 13 Old 19th May 2017, 10:11 AM Thread Starter
Lakotiy
Gear selector stuck
Installed the new engine today and now it will not crank ok gear selector shift into anything. Totally dead selector. My matco scanner is able to shift into any gear but not the selector. Checked the wiring plugs 5 times already. Says trans fail safe mode. New engine came with a harness and one plug doesn't match. Any insight would help.
Lakotiy is online now
post #2 of 13 Old 19th May 2017, 12:13 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
That's an LCI engine harness for a pre-LCI car. That plug carries CAN bus signals for the SMG module. If the SMG doesn't receive them, it won't shift normally.
jcolley is offline
post #3 of 13 Old 19th May 2017, 05:13 PM Thread Starter
Lakotiy
Is it possible for me to rewire my original plug or do I need to swap the harness. Also, do you know how many ground points we have? So far I remember one on top of passenger side motor mount
post #4 of 13 Old 19th May 2017, 06:08 PM
jcolley
jcolley's Avatar
Possible, not recommended. I would swap the engine harness.
Just the one on the cradle, yes.
jcolley is offline
post #5 of 13 Old 19th May 2017, 06:21 PM Thread Starter
Lakotiy
Yes, I didn't mess with my trans harness. Should I drop the engine again or take my time and swap my harness with the engine intact?
Found this post, the blue connector is the starter solenoid. There the problem for not cranking
post #6 of 13 Old 19th May 2017, 06:25 PM Thread Starter
Lakotiy
post #7 of 13 Old 19th May 2017, 06:30 PM
jcolley
jcolley's Avatar
This is the same plug that doesn't match.
Edit: Disregard, I had the E-box oriented backwards. This blue connector is the front? The one you posted looks like the connector in the back inside corner for the SMG harness.
jcolley is offline
post #8 of 13 Old 19th May 2017, 06:33 PM Thread Starter
Lakotiy
The starter solenoid relay perhaps, but the solenoid is located on the starter itself.
I can promise you the is a pair of wires in that connector with spiral color banding that is a twisted pair of CAN signals to the SMG module. It's been a while, but if I remember correctly, it's the LLS-CAN from the SMG module to the idle actuators (LLS) and DME.
I'll take your word for it. Thank you! Should I swap the harness with the engine bolted to the chassis it drop the engine?
post #9 of 13 Old 19th May 2017, 06:35 PM
jcolley
jcolley's Avatar
Check again, I just edited the post you quoted. This connector you can't connect...is it in the front right or the back left of the E-box?
jcolley is offline
post #10 of 13 Old 19th May 2017, 06:39 PM Thread Starter
Lakotiy
The blue plug is upfront coming from the engine harness. The white plug is coming from the chassis and supposed to be sitting where the blue plug is at
2007 M6 - stuck in gear survyor2 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 18th August 2015 07:42 PM
Warning Light in Gear Selector fasteddie1215 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 27th May 2015 12:15 AM
fixed -- no start / gear selector wont move... HISandHERsM5 E60 M5 and E61 M5 Touring Discussion 6 23rd May 2014 06:57 PM
Paddle Shifts vs. Gear Selector C.James.B E60 M5 and E61 M5 Touring Discussion 8 22nd March 2012 12:02 AM
Stuck in 2nd gear! AliM5 E39 M5 and E52 Z8 Discussion 27 5th February 2010 05:16 AM
