Crazy CCC issues - BMW M5 Forum and M6 Forums
post #1 of 10 Old 20th April 2017, 11:44 PM Thread Starter
BobbyT
BobbyT's Avatar
Crazy CCC issues
I had some weird issues with my 2006 M5 CCC - Bluetooth wouldn't pair a phone (it would connect and show the phone in iDrive, but then delete it within a second or two).
Also, I couldn't edit anything in the MDrive - Anything that I would try to change, would revert back to what it was within about a second.
I ran DIS to see if it could see anything, and it noticed some coding faults in the gateway. I flashed the GW module with KDCan (on K) with WinKFP, and was successful - However, it did not fix the issues above.
I decided to flash the entire CCC the same way, and what I didn't realize is that it was going to take about 7 hours. It got to 100%, then error and brick. Biggest waste of 7 hours ever, considering I monitored the voltage the whole time.
I contacted Bimmergeeks to see if they had a solution with their cable, and they explained that they wouldn't recommend any KDCan on the MOST flashes (which theirs is). However, they suggested either ICOM (my last resort before dealership or new CCC), or CD CCC Recovery Disc - which I was not familiar with. They explained the files, and I burned the correct disc for my CCC hardware (9.5).
Popped the disc in, and in about 1 hour and a half, I was back in business.
Now the current status -
- MDrive is editable, however the EDC line is missing.
- Bluetooth menus look more normal, however the "enable bluetooth" is grayed out, so bluetooth is still not functional. Possible MULF module issue?
- No sound at all from speakers - No radio, chime, nothing...
I checked all the fuses, and pulled negative battery cable for a while, however no change. I was going to hook it up to DIS to see if it can see any faults - however, if anyone has any suggestions on how to resolve this, I'd love to hear it.
Thanks!
An
BobbyT is online now
post #2 of 10 Old 21st April 2017, 11:10 AM
LCM
LCM is online now
post #3 of 10 Old 21st April 2017, 12:09 PM
gmak
Did you look in the trunk under the "wheel well" to see if water fried any electronics?
gmak is online now
post #4 of 10 Old 21st April 2017, 01:38 PM Thread Starter
BobbyT
BobbyT's Avatar
Originally Posted by LCM View Post
default code the ccc
What method would you suggest?
I did a bit... looked at MULF, Sat, trunk fuse box, etc. All looked good.
post #5 of 10 Old 22nd April 2017, 01:09 AM
LCM
the usual with ncsexpert
LCM is online now
post #6 of 10 Old 22nd April 2017, 10:05 PM
335xi
I have a CCC + Screen for $cheap$
Thanks!
An
It's from my 2008 from when I upgraded to CIC, I will give you a good price.
335xi is offline
post #7 of 10 Old 25th April 2017, 02:33 PM Thread Starter
BobbyT
BobbyT's Avatar
I will definitely keep this in mind. I'm skeptical that it's a bad CCC at this moment, but if I can't code it back to normal, I'll contact you on this. Thanks!
post #8 of 10 Old 25th April 2017, 08:03 PM
LCM
I share your reasons for skepticism!
LCM is online now
post #9 of 10 Old 28th April 2017, 08:54 PM Thread Starter
BobbyT
BobbyT's Avatar
I screwed up.
I had a little time, and threw NCS Expert on. I was taking a look through some of the modules, and the audio one looked a little weird. I was doing some research online, when I noticed that Radio Volume Bundle (or something like that) had two options - 1) Wert 01 - Checked... 2) E6x Hifi - unchecked.
I just assumed that may be part of my issues, and I'll code that over to the E6x Hifi instead of Wert 01, when things started going south. Lights flickered a bit, and I realized I forgot to plug in my battery charger. Oops, killed the battery.
I charged it for a while, and it started right up. However, literally nothing is on the CCC. Zero power. iDrive wheel free-spinning.
I tried everything I can think of - Pulled the battery, checked all the fuses, tried the "reset" techniques, etc. INPA and NCS say "no module detected". I'm thinking a low voltage connection went to the CCC while reading in NCS and killed it.
Anything else I can check?
Also, I received a few PM's from some members about used CCC's. I can't reply as I'm fairly new here, although I'd like to. If you can, either shoot me another PM with your email, or shoot me an email - schreiber779 at gmail
Thanks!
post #10 of 10 Old 29th April 2017, 01:36 AM Thread Starter
BobbyT
BobbyT's Avatar
ATTN: 335XI
Shoot me an email at
I can't PM, as I don't have enough posts.
E60 For Sale: I have CCC and CCC Screen from 2008 M5 for sale 335xi Parts / Other For Sale or Wanted 3 30th December 2015 05:11 PM
Would my ccc professional be able to replace a ccc business? pyro225 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 18th March 2012 02:21 PM
Update the CCC ziad E60 M5 and E61 M5 Touring Discussion 3 3rd December 2011 07:45 PM
Issues with DVD CCC Map disc M5 Jed E60 M5 and E61 M5 Touring Discussion 6 14th March 2009 06:05 AM
Another CCC Failure pvr E60 M5 and E61 M5 Touring Discussion 29 20th January 2008 04:16 PM
