Rod Bearing Failure Prevention (10-60w vs 0-40w) - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 44 Old 20th April 2017, 01:32 AM Thread Starter
R8ED_M
Hey Guys,
Firstly I want to say Thanks to everyone who posted on my last few threads. I have a 2006 E60 M5 W/Smg. Car was in the shop for transmission issues ended up replacing the transmission and clutch/flywheel. While the beast was in the shop i had noticed a rattle from the passenger side of the engine close to the valve covers. I brought this up with the shop owner who was doing the work.
2 weeks later I get a call that they took out my oil filter and found metal shavings and that the rod bearings were shot and the damage is done and the cars pretty much toast and that I should take it home and just park it. I told the owner to go ahead and fix the transmission and i would deal with the engine after. Before taking the car there i had no real serious issues with the car besides the normal throttle actuators and the transmission oil consumption was minimal and the car ran perfect. Now what i want to know is if there is rod bearing damage would running a thinner oil help so i can drive the car till i save up for a rod bearing job? and if there is anyone whose been running 0-40w for a while now and had good results. Thanks in advance any sort of info helps
R8ED_M is offline
The Following User Says Thank You to R8ED_M For This Useful Post:
old city bimmer (20th April 2017)
post #2 of 44 Old 20th April 2017, 01:51 AM
gmak
I'm sorry for your loss. I wouldn't drive the car it would just make it worse, I believe.
gmak is offline
The Following 2 Users Say Thank You to gmak For This Useful Post:
R8ED_M (20th April 2017)
post #3 of 44 Old 20th April 2017, 02:15 AM
335xi
I ran 0-40 for the last 2 years, just did bearings at 60K miles and they looked ready to go. Of course, I don't know if the damage was done prior to the switch or not. What precipitated the rod bearing change was a mildly high lead reading during the last oil change.
335xi is offline
The Following 2 Users Say Thank You to 335xi For This Useful Post:
post #4 of 44 Old 20th April 2017, 02:22 AM Thread Starter
R8ED_M
That being said who knows how long it would have lasted running 10-60w :/ Good thing you caught yours in time
R8ED_M is offline
post #5 of 44 Old 20th April 2017, 03:02 AM
Tim_Mc
Nobody knows.
If you find flakes in the oil filter...the fix is new bearings at best, worst is a dead engine. Simple as that.
Tim_Mc is offline
post #6 of 44 Old 20th April 2017, 03:43 AM
pmalik
pmalik is online now
post #7 of 44 Old 20th April 2017, 03:45 AM
pmalik
pics? I would be highly skeptical of that.
post #8 of 44 Old 20th April 2017, 05:23 AM
Bibm5
Bibm5's Avatar
Originally Posted by R8ED_M View Post
Hey Guys,
I personally would not drive it even one more time without pulling the bearings.
You should wait on ordering the new bearing kit though til you see if your crank is damaged or not. It may not be worth it to drop over a grand on parts if there is scoring.
How many miles on it?
Sent from my SM-G930P using Tapatalk
2008 Alpine white ///M5 6mt (nights & weekends toy)
2003 F250 V10 (daily)
1972 F100 (ongoing project)
1998 540i sport 6mt (sold to help fund the ///M)
Bibm5 is online now
post #9 of 44 Old 20th April 2017, 07:53 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Just to add to what the fellow members have said already; do not run the car with metal in your oil. It will destroy the engine and your VANOS solenoids. Just park the car and get the bearings fixed as soon as possible.
If you have the ticking noise form the bearings already, using 0W-40 will not help much.
Good luck and hope everything turns out good for you.
Hasan Shaikh is offline
post #10 of 44 Old 20th April 2017, 01:54 PM
Craze
I may be incorrect but I understand the following:
Tws 10w60 shears to lower very soon
10w60 oil increases oil pressure as apposed to lighter weight oil
10w60 is required because otherwise the capacity of oil pump rate would need to be increased drastically
Rod bearings and crank clearance are tight but keep oil pressure up
E39 was apparently more known for failures, but build number was more
Only 1 person im aware has pulled bearings after redoing them and they looked to be as bad as the original much higher mileage units
People think replacing them means its fixed now
From my experience seeing 1st owners pms the oil change duration was generally excessive which we know isnt good
I often wonder who tops up oil when car tells them too, they probably ignore that like the service warning
statistically my own findings suggest perhaps 2% of motors have failed
Bmw are pretty smart
However they made the n63 motor so who knows
Craze is offline
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Mfiveusa
UK Rod Bearing Failure - Warranty? Lazyjames E60 M5 and E61 M5 Touring Discussion 9 2nd August 2015 02:11 PM
Another Rod Bearing Failure Thread MKSixer E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 149 18th February 2014 01:31 AM
Rod Bearing Failure Thoughts 3martini E39 M5 and E52 Z8 Discussion 141 27th January 2012 03:40 AM
S62 Rod Bearing Failure Pictures tenmile E39 M5 and E52 Z8 Discussion 80 22nd October 2011 03:04 AM
Connecting rod bearing failure CTW E39 M5 and E52 Z8 Discussion 13 22nd January 2008 04:26 AM
