Car developed an oil leak after a redline run - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By 335xi
post #1 of 9 Old 20th April 2017, 12:07 AM Thread Starter
335xi
A few days ago I was driving in 'D' (I know, why?) and during a spirited drive I hit the redline once. After that, I noticed a puddle of oil every morning on the garage floor. I had a 60 mile drive the other day and it lost 1/2 of a quart but during the every day sedate commute is loses very little. Obviously, the car will be going on the lift shortly but what could have broken from that one redline excursion?
Thx
335xi is offline
post #2 of 9 Old 20th April 2017, 01:01 AM
cold m3
cold m3's Avatar
This should happen soon! Remove the under tray and check for the leak. Hell if you have a jack I would go take a look now. Could be the oil cooler / lines.
Hard to believe it happened after one redline excursion unless it wasn't warmed up. Probably a slowly failing seal that finally gave out.
Current: 6MT 2008 E60 M5 (IB)
Sold: E46 M3 (6 years of ownership)
Insta: Cold_M3
Photos of My ///M5
cold m3 is offline
post #3 of 9 Old 20th April 2017, 02:18 AM Thread Starter
335xi
It was warmed up
I have been taking it easy on the car since I did a rod bearing job on it at the end of January. So, this was the 1st redline since then.
335xi is offline
post #4 of 9 Old 20th April 2017, 03:03 AM
ticat928
ticat928's Avatar
Thx
Effect: oil loss higher under load
Cause: crank case pressure higher under load
may want to check PVC system, valve cover seal, oil pan seal etc.
ticat928 is online now
post #5 of 9 Old 22nd April 2017, 05:28 PM Thread Starter
335xi
335xi is offline
post #6 of 9 Old 22nd April 2017, 06:57 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Glad you found the leak.
Our OEM oil coolers are fragile. I hit road debris, which caused my leak. I used it as an excuse for an RPi oil cooler.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =133,000 miles with no RCOD and counting ...just saying...
2007 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing (Blanton) 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PSS 255/40/19 and 295/35/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; RedLine B/S RDR off, F/R G1W-H, ALP w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 miles!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; z3 1.9L ssk and ZHP shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the sub 2,400lb e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 228,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014 to a good home.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service autohausfrankfurt.com/ my local Dinan supplier trinityautosport.com my local drug dealer for my crack habit
fastattackmotorsports.com because JColley!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #7 of 9 Old 22nd April 2017, 10:00 PM Thread Starter
335xi
Mine was leaking at the usual place
Up top by the inlet.
335xi is offline
post #8 of 9 Old 22nd April 2017, 10:34 PM
cold m3
cold m3's Avatar
I had a feeling it was.
Insta: Cold_M3
Photos of My ///M5
cold m3 is offline
post #9 of 9 Old 23rd April 2017, 02:20 AM
Fiftytwoeighty
Yup. The usual place. It's our achilles tendon.
~Woody
~I FRACKING!
~Viva La Wolfpack!
Help Concerning this car~E60 M5 Cylinder head cover oil leak hankm5 E60 M5 and E61 M5 Touring Discussion 6 22nd March 2015 08:49 PM
Question To those that use Redline oil DentalBoy E39 M5 and E52 Z8 Discussion 15 22nd March 2013 05:51 PM
Took off my front skid plate to install a new oil pan (oil consumption or oil leak...?!) blks4 E39 M5 and E52 Z8 Discussion 7 19th August 2011 10:34 AM
is this a good transmission oil to use (redline d4 atf) partouza E39 M5 and E52 Z8 Discussion 10 5th May 2011 07:41 PM
Hot! GM mulling aquisition of BMW-First photo of jointly developed car! 03E39M5 E60 M5 and E61 M5 Touring Discussion 12 24th December 2003 02:30 AM
