SMG Pressure question - BMW M5 Forum and M6 Forums
post #1 of 5 Old 21st March 2017, 12:28 AM Thread Starter
pizdous
pizdous's Avatar
Question SMG Pressure question
Does anyone know what the SMG pressure on our car is supposed to idle at? How many bars? also how can I tell if my SMG Pressure is dropping too fast?
For example I did a test on my Hydraulic pump in ISTA and pressurized my pump to 108.5bar i then timed it and it took about 15 minutes to get down to about 55. Bar are there any references i can compare this to? also at which point is the SMG automatically triggered to start building pressure again?
I just did a fluid CHS11S flush so I want to make sure everything is working correctly.
Thanks for all your help in advanced!
Follow me on Instagram @MlifeM6
E36 M3, E46 M3, E39 M6, E63 M6 Visit My YouTube Channel for Vids!
Shop BMW ///MLifeM6 Clothing & Accessories HERE!
pizdous is offline
post #2 of 5 Old 21st March 2017, 02:45 AM
5soko
5soko's Avatar
On a warm engine, running, The pressure will build to 77-81bar and will kick back in around 57bar..
DIS and ISTA has a accumulator test that does just this, checks if it leaking pressure too fast in a certain time that it likes.. Run the test, and report back.
5soko is online now
post #3 of 5 Old 21st March 2017, 02:49 AM Thread Starter
pizdous
pizdous's Avatar
5soko, Thank you so much for the reply! I actually ran the accumulator test twice and it finished perfectly and did not come back with any errors so I believe i should be good on that
Appreciate the help!
pizdous is offline
post #4 of 5 Old 21st March 2017, 02:53 AM
5soko
5soko's Avatar
Yup sounds good then! If it is able to hold pressure (well leak at a acceptable rate), and is able to hit the pressure targets, then you are fine on the hydraulic side of things.
cold engine, engine off, the targets are different, i think 65bar target, and turns on at 45bar.
5soko is online now
post #5 of 5 Old 21st March 2017, 04:36 AM Thread Starter
pizdous
pizdous's Avatar
interesting, good to know! thanks again!
pizdous is offline
SMG pump will not bleed/build pressure Matt Knight E60 M5 and E61 M5 Touring Discussion 3 11th September 2016 06:06 AM
Smg pressure sensor Lloydv10 E60 M5 and E61 M5 Touring Discussion 0 16th January 2016 12:05 PM
Smg pressure/leaking test laomaiv10 E60 M5 and E61 M5 Touring Discussion 1 3rd January 2015 09:05 PM
SMG Help!! Need pressure sensor Picture BMTROUBLEYOU E60 M5 and E61 M5 Touring Discussion 3 17th September 2013 12:43 AM
Tire pressure question: Summer pressure vs. Winter pressure tripleD E39 M5 and E52 Z8 Discussion 3 13th June 2007 01:29 AM
