P0306, P0308 and Limp Mode - BMW M5 Forum and M6 Forums
post #1 of 5 Old 19th March 2017, 06:58 AM Thread Starter
B1mmerbob
Good Evening All,
I am having an issue and wanted to run it by here before i bring it in to be diagnosed. I have a 2008 M5 with 112k on it and had an issue come up where around 2000-2350rpms I would get a P0306 and P0308 and the car would go into limp mode. No matter which mode the car was in it would happen. I can turn the car off and it would reset itself and if I drove out of that rpm range, it would be fine. I've had the oil changed (inspected for metal shavings was negative), spark plugs, coils, and fuel injectors. Anyone have any idea of what route I should follow before I bring it in to a auto shop or the stealership? Any help is greatly appreciated!!
B1mmerbob is offline
post #2 of 5 Old 19th March 2017, 02:45 PM
B767capt
B767capt's Avatar
Assuming those are misfires on bank 2, I would swap ionic modules and see if the misfires goes to bank 1. Being both misfires are on the same bank, I would bet it's a bad ionic module. This is the first step in misfire trouble shooting.
B767capt is offline
post #3 of 5 Old 19th March 2017, 11:14 PM Thread Starter
B1mmerbob
post #4 of 5 Old 20th March 2017, 02:08 AM
ninjabmw
if your spark plugs and coils look good, check the valve springs, which means the head needs to come off. Very common failures on this cars were the springs just brake into pieces.
ninjabmw is offline
post #5 of 5 Old 20th March 2017, 03:10 PM
B767capt
B767capt's Avatar
Yes next would be swap coils around and replace spark plugs while you have the coils out and clearing existing fault codes. The warranty manual says to replace spark plugs every 37k miles. Then look at fuel injectors and then valve springs.
B767capt is offline
Limp Mode.... rangerb3 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 20th November 2015 01:02 AM
Limp mode!! Need help! adrigm6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 19th October 2015 06:28 PM
E60 2006 BMW M5 safe mode limp mode throttle pedal position senor dskrakow E60 M5 and E61 M5 Touring Discussion 1 14th December 2010 06:23 PM
Limp Mode 507hp M6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 29th April 2009 12:28 PM
Just what exactly is “Limp Mode” or “Engine Failsafe Mode”? Ripp67 E39 M5 and E52 Z8 Discussion 1 10th December 2008 09:35 PM
