Driver side window switch no longer working - BMW M5 Forum and M6 Forums
post #1 of 3 Old 14th February 2017, 07:51 PM Thread Starter
M6LA
I had one of these crazy rotating mirrors on the driver side so I cut the red wire to it to stop that from happening... in the process I (being dumb and not disconnecting the battery) accidentally had the red wire touch ground and since then:
- window switch on the driver side no longer working, no led light up etc.
- window switch on passenger side working still, can lower top with windows going up and down etc.
wondering if a fuse's broken or if I actually fried the window switch electronics
I checked voltages on the connector to the window switch and found only 5v on one of them, no 12v.
any ideas? 2006 M6 conv
M6LA is offline
post #2 of 3 Old 15th February 2017, 03:30 AM Thread Starter
M6LA
M6LA is offline
The Following User Says Thank You to M6LA For This Useful Post:
Texasgrego (16th February 2017)
post #3 of 3 Old 16th February 2017, 06:56 PM
Texasgrego
Texasgrego's Avatar
Thank you for posting the solution.
On the way to different shop with more advanced software to diagnose similar problem. All fuses checked showed continuity with multimeter.
Saw your post, rechecked 32 visually, bam.
Texasgrego is offline
Tags
windows
Need Help - Window Switch on Driver's Side and Driver's Side Door Lock Not Work E39 M5 jmauro E39 M5 and E52 Z8 Discussion 1 6th February 2013 05:38 AM
Master window switch replaced but windows still not working jaminj946 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 20th September 2012 07:26 PM
E39 Want to buy: Not-working window switch Milla Parts / Other For Sale or Wanted 5 30th July 2011 09:01 AM
E60 Want to Buy: e60 driver side window switch master panel typer142 Parts / Other For Sale or Wanted 0 30th April 2011 06:54 PM
Window Switch Not Working? ZJamaican E39 M5 and E52 Z8 Discussion 3 30th May 2007 03:23 AM
