E60 m5 in forfeiture for 3 years - BMW M5 Forum and M6 Forums
 9Likes
post #1 of 12 Old 13th February 2017, 03:46 PM Thread Starter
Jhollywood420
Jhollywood420's Avatar
I get my baby back in 2 weeks! It was stored in their warehouse, so at least they didn't leave it outside. My question is...Can i start the car with the 3 year old fuel? If I need to drain it, is my best bet to do so through the fuel pump? Any other advice on what I should do before starting? I purchased new tires 2 weeks before it was seized. Are the tires going to be bad? I am so excited to get it back, but I definitely don't want to ruin the car by being hasty.
Jhollywood420 is online now
post #2 of 12 Old 13th February 2017, 04:41 PM
Celicasaur
If it was me, I'd hand turn the engine a couple of times via the crank pulley bolt and then disconnect the injector clips and crank it over for about 5-6 seconds. This is on the assumption that there's oil in there and you have the means to get power to the battery etc or you have a jump pack.
Old fuel....not ideal, but as long as you take it easy and don't load up the motor, you'll be fine until you can get it to a gas station.
Tyres, yes they'll most likely be a little out of round, depending on how they were stored, but thats something you can address once you get home Engine/Tranny are the important bits.
Good luck
Celicasaur is offline
post #3 of 12 Old 13th February 2017, 05:34 PM Thread Starter
Jhollywood420
Thanks for the advice
Good luck
By disconnecting the injector clips, would that make the fuel squirt out of the lines? Could I push down the fuel pressure port to do this? Or would the injector clips be better?
post #4 of 12 Old 14th February 2017, 03:02 AM
Coors
Good luck
If I understand correctly. No fuel will squirt out. Disconnect the electrical harness connectors feeding each injector.
This process will de-energize the fuel injectors and help prime the internals with oil. Build up oil pressure then, fire up the motor.
Coors is offline
post #5 of 12 Old 14th February 2017, 06:38 AM Thread Starter
Jhollywood420
Hey thank you for explaining that further for me! I personally was worried that the old gas may have broken down over 3 years and could spit sludge into the fuel injectors and engine. I will take it to the dealership a couple months after i get it back. But I don't think i can wait that long to start her up. Thanks again for taking the time to help!
post #6 of 12 Old 14th February 2017, 01:32 PM
Celicasaur
Yeah no, by disconnecting the electrical clips to the injectors, they won't be sent any voltage to open up and squirt fuel. However yes if you remove the injectors themselves from the rail and turn the ignition key, it'll get real messy, real quick.
Personally....I'd do injector clips, assuming they're easy to access. Fuel pump relay is another way, although that might not stop the tiny bit of fuel inside the injectors from coming out and then firing the engine momentarily....which you're trying to avoid initially.
This ^
post #7 of 12 Old 14th February 2017, 01:55 PM
B767capt
B767capt's Avatar
If you have ISTA+ or Rheingold, you can turn off the injectors with the software. I do this for compression checks. This software is a must for this car with most of them out of warranty now. Saves big time on SMG and vanos work.
B767capt is offline
post #8 of 12 Old 15th February 2017, 12:46 AM
intrepid one
intrepid one's Avatar
How much fuel is in the car now.If it is close to empty,.possibly topping up with fresh gas with injector cleaner will be enough to get it going..
intrepid one is offline
The Following User Says Thank You to intrepid one For This Useful Post:
Jhollywood420 (15th February 2017)
post #9 of 12 Old 15th February 2017, 01:56 AM Thread Starter
Jhollywood420
I don't have software, but I'm definitely impressed with how much the members are doing with software and coding. Absolutely amazing. I spent alot of money at the dealership fixing smg cogs when i had the car in 2013. So i will look into more posts on software.
post #10 of 12 Old 15th February 2017, 02:49 AM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
jcolley is offline
Tags
3 year old gas
Storing the e60 m5 for 4+ years IlyaG E60 M5 and E61 M5 Touring Discussion 26 13th January 2017 02:27 AM
BMW M5 over the years through all generations: E28 M5, E34 M5, E39 M5, E60 M5 and F10 M5 Gustav E34 M5 Discussion 1 14th February 2012 08:53 AM
10% of last years BMW M5 E60 where manual in the USA which... Gustav F10 M5 Discussion 2 26th June 2011 06:30 AM
From E39 to E53 to E60 in 2 years (pics) NCM5Guy E60 M5 and E61 M5 Touring Discussion 6 10th April 2011 04:07 AM
Will the E39 M5 be worth more than E60's in a few years? sshu930 E39 M5 and E52 Z8 Discussion 22 23rd February 2010 11:43 AM
