E60 m5 in forfeiture for 3 years - Page 2 - BMW M5 Forum and M6 Forums
 10Likes
post #11 of 16 Old 16th February 2017, 02:18 PM Thread Starter
Jhollywood420
Jhollywood420's Avatar
Thanks for the advice
Originally Posted by jcolley View Post
Remove F30 in the glove box and and F72 in the trunk. Both are fuel pump fuses. Done.
Can you please explain why i should remove these fuses? Should i remove them and then start the car? What is the idea behind it? What about the 3 year old fuel? Do I need to get the fuel out and replace it, or will it be fine?
Thanks John
Jhollywood420 is offline
post #12 of 16 Old 16th February 2017, 06:13 PM
Bucky
Thanks John
Jim is saying to remove the fuses so you can crank the engine to get the oil flowing.
Throw some fuel stabilizer, injector cleaner in and give it a crank. Just make sure you fill up with good fuel as soon as you can and go through a couple of tanks before you open her up.
Bucky is offline
The Following 2 Users Say Thank You to Bucky For This Useful Post:
Jhollywood420 (16th February 2017)
post #13 of 16 Old 27th February 2017, 07:03 PM Thread Starter
Jhollywood420
How bout
How about the old fuel? I don't need to get it out?
post #14 of 16 Old 27th February 2017, 07:41 PM
texsn95
texsn95 is offline
The Following 2 Users Say Thank You to texsn95 For This Useful Post:
Jhollywood420 (27th February 2017)
post #15 of 16 Old 27th February 2017, 07:53 PM Thread Starter
Jhollywood420
Originally Posted by texsn95 View Post
If it were my car, I'd get as much out of it as I could.
What would be the best way to remove the old fuel? Only way I can think of, is to remove thr fuel pump so i can pump it out. Any other suggestions would br greatly appreciated.
post #16 of 16 Old 27th February 2017, 09:36 PM
texsn95
Or the side with the fuel filter on it and change that out at the same time...but yeah you may have to get primitive with it. There are probably some good transfer pumps around that would be easy to use. Maybe even rentable.
texsn95 is offline
Tags
3 year old gas
Storing the e60 m5 for 4+ years IlyaG E60 M5 and E61 M5 Touring Discussion 26 13th January 2017 01:27 AM
BMW M5 over the years through all generations: E28 M5, E34 M5, E39 M5, E60 M5 and F10 M5 Gustav E34 M5 Discussion 1 14th February 2012 07:53 AM
10% of last years BMW M5 E60 where manual in the USA which... Gustav F10 M5 Discussion 2 26th June 2011 05:30 AM
From E39 to E53 to E60 in 2 years (pics) NCM5Guy E60 M5 and E61 M5 Touring Discussion 6 10th April 2011 03:07 AM
Will the E39 M5 be worth more than E60's in a few years? sshu930 E39 M5 and E52 Z8 Discussion 22 23rd February 2010 10:43 AM
