M5 a money pit? - Page 7 - BMW M5 Forum and M6 Forums
 32Likes
post #61 of 92 Old 15th February 2017, 07:17 PM
DaveY
DaveY's Avatar
Originally Posted by ADA View Post
Over the years of owning mine, I've dumped a ton of cash into it. Of course, some was preventative maintenance which won't be required for another 100-150k miles. Here is a short list of maintenance items with rough costs (parts + labor + tax)
LB Idle actuator (these go bad in 50-70k miles usually) ~ 2k (1k part, 1k labor + tax)
RB Idle actuator ~ 2k
All brakes and discs completely redone (oem) ~ 5k
Rod bearings change + other enginy stuff ~ 6.2k
LB Throttle actuator ~ 2k
Oil changes ~ prolly around 1.5k right now
Battery replacement ~ $300
New Key + reprogramming ~ $200
Yeah...you do the math.....
I mean, car runs great, other than the actuators, which are a pain and whenever they go bad car stalls and can die in the middle of the road (this is not dangerous at all BMW wtf), the car has actually been pretty reliable.
Soon I think I'll have to renew my clutch, now that's gonna be fun.
Perhaps consider taking it to a different garage?
Surely those things I've highlighted are highly exaggerated? It can't be that much in te US for servicing surely? I thought the UK was more expensive??
If you are not afraid to get involved yourself and do the simple mechanical bits and pieces then you can save a fortune.
For example:
Complete Brakes change (4x BMW OEM Discs, Full set of OEM Pads, Full set of braided brake lines, Replacement brake fluid, OEM Handbrake Shoes, BMW OEM Handbrake Install kit (springs etc), BMW OEM Handbrake Cable, and even replacement BMW OEM disc fitting bolts and full hydraulic bleed of the system) I can do for about £1400 GBP or $1700 USD. It takes a few hours at most.
People over here are getting quotes around £2000 GBP or $2500 USD for a rod bearing change. Not sure what other enginey work you mean.
Oil changes are simple. Full drain, flush, drain, fill procedure and new BMW OEM filter can be done for around £200 GBP, or $250 USD using Castrol Edge 10w60. (Other oils are generally cheaper in fact)
I've found a guy that will also install a new battery that I have bought and register it for £140 GBP or $175 USD.
Still,none of that is as cheap as perhaps, a decent Ford, French/Jap car etc but you should expect to pay for what your getting in performance!
Illustrious car history:
'94 Renault Clio, '86 Peugeot 205, '97 Peugeot 106, '89 Nissan 200SX, '99 Peugeot 306 GTI-6, '01 Citroen Xsara, '07 Ford Mondeo, '06 BMW 335d E92, '06 BMW E60 M5 + Various smaller cc motorbikes over the years!
DaveY is online now
post #62 of 92 Old 15th February 2017, 08:30 PM
ADA
ADA's Avatar
For example:
I save all of the paperwork and I can look up the actual figures but there are probably a few reasons for why the prices are through the roof. Reason 1 being I only service at the dealer. Always. Although I am car literate, where I live I don't have a garage or any other space and tools to work on the car. So if there is anything that needs to be done, I typically take it to the dealer. I have tried to take my car into numerous repair shops around where I live, all of them either declined to service my car, or tried, and after terrible experience I went out the door anyway.
I'll look up the brake numbers when I get home tonight, but as far as the engine, that's the price for BE bearings, ARP bolts, new VANOS lines, a few other wear and tear engine parts (seals, etc etc) and the labor. Around here, the labor costs pretty much half of the part prices. Even small repair shops in town charge $100 per hour and higher.
Oil changes are typically $300 a pop, because I always replace filters and etc. Once in 4k miles, and over the years yeah..about $1500 now in total
____
Meh.
ADA is offline
post #63 of 92 Old 15th February 2017, 09:00 PM
DaveY
DaveY's Avatar
Money Pit Confirmed. LOL
The BMW stealers near me charge $125/hr to be honest, but an ex-dealer BMW mechanic charges me $45~/hr.
I was all for getting my 335d properly serviced by BMW Main Dealers so i could keep its value up in its service history. As I've bought my M5 with only part of a history and accident damage, it doesn't other me so much.
DaveY is online now
post #64 of 92 Old 15th February 2017, 10:31 PM
JrMint03
Originally Posted by Fiftytwoeighty View Post
I couldn't agree more. I'm on another forum where we buy/exchange/sell watches that range from four figures to six figures. The first rule is to buy the seller, before you buy the watch.
Unfortunately as more of these cars exchange hands and end up on dealer lots, it's getting harder and harder to buy the seller.
Is that so?? PM me the forum, I switch out my watches from time to time.
2007 E60 M5- Black Saphire
Eisenmann Race Exhaust
CIC Retrofit
Euro SMG Tune
RPI Scoops and Block off Plates
Lowtech Front Springs
H&R 12mm Spacers all around
Black Kidney Grills
LED Interior, License Plate and Side Marker Lights
JrMint03 is offline
post #65 of 92 Old 15th February 2017, 11:45 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
PM sent. There are a handful of us on both Boards.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =133,000 miles with no RCOD and counting ...just saying...
2007 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing (Blanton) 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PSS 255/40/19 and 295/35/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; RedLine B/S RDR off, F/R G1W-H, ALP w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 miles!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; z3 1.9L ssk and ZHP shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the sub 2,400lb e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 228,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014 to a good home.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service autohausfrankfurt.com/ my local Dinan supplier trinityautosport.com my local drug dealer for my crack habit
fastattackmotorsports.com because JColley!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #66 of 92 Old 16th February 2017, 01:11 AM
335xi
wow, that is cheap
Here it's $180/hour at dealer.
About $100 at indy.
335xi is offline
post #67 of 92 Old 16th February 2017, 01:41 AM
texsn95
texsn95 is offline
post #68 of 92 Old 16th February 2017, 04:19 AM
pyite
pyite's Avatar
Originally Posted by corrieharris27 View Post
huge money pit.
Any used car is a risk. If you have rotten luck and need a new engine it will hurt. There are also a lot of gadgets to break. Don't get one of these if you can't afford to drop $10k unexpectedly. And find a good independent mechanic because BMW dealers seem to be set up more for warranty repairs (i.e. mega inflated prices).
M5's are great bargains if you enjoy working on them yourself. They are relatively easy to work on, too... certainly compared to our Outback and Odyssey.
pyite is offline
post #69 of 92 Old 16th February 2017, 07:21 AM
ADA
ADA's Avatar
Just pulled up a few of my records
Replacing throttle actuator last summer: $1327.41 in parts, $738.40 labor
Head gasket replacement, screws, o-rings, self-locking collars, pulley adjustment, adjusting belt tensioners, new deflection pulley, filter, compression springs, fluids, all belts, vanos oil lines, arp bolts, be rod bearings: $1806 parts and $3850 labor+ tax ~ $6116.14
Oil and filter change ~ $275
Coolant Flush ~ $300
Final Drive Fluid Flush ~ $350
Transmission fluid flush ~ $260
SMG service with adaptation ~ $370
Replace microfilter ~ $220
OEM brake pads, discs, steel brake lines, fluid flush ~ $1417 labor, I bought all my parts somewhere else but they were like $2k for everything, and also Dinan monoballs were part of the same job, so all and all it was actually more like $4k for it, rather than 5k.
Just a little glimpse into ownership right there.
Basically, the only things which broke over the years of ownership were the actuators, some of those were like $800 bucks to replace (I think idle), and some were 2k a pop (throttle)
Other than that, the car didn't really brake down, and I just end up doing these $300 oil changes..
____
Meh.
ADA is offline
post #70 of 92 Old 16th February 2017, 10:41 AM
pmalik
I'm guessing every single car you've owned has been a money pit.
Here's a hint: you're getting ripped off. Like senile old lady walks into a shady used car dealership level of ripped off. The owner of that BMW store just made 100% profit margin on that microfilter replacement charge (2 $36 filters, 10 mins of tech time). I would highly recommend purchasing a CPO car next time around and only keep it while the manufacturer warranty is in force. Otherwise you'll get taken again.
On a side note, we've got a bunch of family friends that own various dealerships and they always joke how it's the people that continually bring in their 20 year old 3 series and E classes that pay for all the dealer overhead.
pmalik is online now
Re Intro to my Money Pit with pics! RayIam E39 M5 and E52 Z8 Discussion 50 20th May 2014 09:33 PM
Money where your mouth is!!!! (money goes to charity!) mattmartindrift E39 M5 and E52 Z8 Discussion 65 17th September 2011 05:32 AM
Some teaser pics of "The Matte Black Money Pit"... vantaam5 E39 M5 and E52 Z8 Discussion 82 25th May 2011 01:43 AM
Endless money pit.... mmzcee E39 M5 and E52 Z8 Discussion 29 11th May 2011 11:35 AM
Cheap project or just a huge money pit? carlgrz E39 M5 and E52 Z8 Discussion 11 18th July 2010 09:12 PM
