F10 M5 Brake retrofit on a E60 M5 - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 29 Old 30th January 2017, 09:43 PM
Muz_M5
Muz_M5's Avatar
Muz_M5 is offline
post #12 of 29 Old 30th January 2017, 11:31 PM Thread Starter
DinanE60M5
DinanE60M5's Avatar
I want to be able to have the OEM F10 M5 Brakes compatible for my E60 M5. I don't mind having just the calipers either but I want to be fully compatible for my car (even if it requires custom work being done to fit my setup).
2009 BMW M5 Alpine White/ Black Merino Extended Leather
Exterior
-IND E60 M5 Cosmetic Package
-Powdercoated Gloss Black OEM Wheels
-BMW M Performance Black Kidney Grilles
Performance
-Dinan High Flow Air Mass Meter and Intake Assemblies
-Dinan Stage 3 Performance Engine Software
-Dinan 13% Underdrive Crankshaft Pulley Kit
-Euro SMG Tune
-Eisenmann Race Exhaust (Oval Tips)
-Supersprint Section 2 X-Pipe (Resonator Delete)
-RPI Scoops
Handling
-Dinan 21mm Adjustable Rear Anti-Roll Bar
-Dinan Supplemental Ride Quality & Handling Kit
-Dinan Performance Spring set
DinanE60M5 is online now
post #13 of 29 Old 31st January 2017, 12:17 AM
Bucky
Check ebay, you can buy the calipers on there for 1k a side.
Bucky is offline
post #14 of 29 Old 31st January 2017, 06:38 PM Thread Starter
DinanE60M5
DinanE60M5's Avatar
Will they fit on my stock rotors?
Exterior
Performance
-Euro SMG Tune
-RPI Scoops
Handling
post #15 of 29 Old 31st January 2017, 06:42 PM
Bucky
They will not fit stock E60 rotors.
E60 stock rotors are 374mm
F10 are 400mm
The pads will overhang.
Bucky is offline
post #16 of 29 Old 31st January 2017, 08:28 PM Thread Starter
DinanE60M5
DinanE60M5's Avatar
F10 are 400mm
BUCKY how do go as far as installing the whole F10 brakes and rotors (400mm rotors) on the E60 M5? Custom brackets have to be created, right?
Exterior
Performance
-Euro SMG Tune
-RPI Scoops
Handling
post #17 of 29 Old 31st January 2017, 08:46 PM
Bucky
If the rotors fit the E60 hubs and clear the suspension components, its just a matter of custom caliper brackets and 20" wheels.
Bucky is offline
post #18 of 29 Old 31st January 2017, 09:34 PM Thread Starter
DinanE60M5
DinanE60M5's Avatar
I want to put this kit on to fit my stock 19 inch wheels. Is this kit only for the front? It's hard because the website is not available in English.
Ultimot GmbH - Komponenten-Anzeige
Exterior
Performance
-Euro SMG Tune
-RPI Scoops
Handling
post #19 of 29 Old 31st January 2017, 09:59 PM
Bucky
Them kits are made for the E60, they will bolt straight on but with 19" wheels your stuck with 380mm brakes.
Bucky is offline
post #20 of 29 Old 31st January 2017, 11:16 PM Thread Starter
DinanE60M5
DinanE60M5's Avatar
The website I referenced is 374mm which would be fine for the front brakes. However how do we achieve the rear brakes? The F10 M5 rear brakes are 4 pistons whereas the E60 M5 rear brakes are 1 piston. The website only offers the kit for the front I haven't seen it for the back.
Exterior
Performance
-Euro SMG Tune
-RPI Scoops
Handling
F10 brake kit vs e60 brake kit 4onenight E60 M5 and E61 M5 Touring Discussion 35 22nd January 2017 10:26 PM
>>>Bimmer Retrofit - NBT Retrofit Kits for E60, E61, E62, E63, E64 <<< BimmerRetrofit M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 19 8th September 2016 09:44 AM
F10 M5/M6 Brake System Retrofit Kit Tiago_ E60 M5 and E61 M5 Touring Discussion 2 17th February 2015 04:44 AM
>>>Bimmer Retrofit - NBT Retrofit Kits for E60, E61, E62, E63, E64 <<< BimmerRetrofit M6 E63 Group Buy and Sponsor Discussion and Offerings 6 3rd December 2014 05:48 PM
F10 performance steering wheel e60 retrofit? P/N 32302344136 funbobbyrob E60 M5 and E61 M5 Touring Discussion 4 25th September 2014 12:22 PM
