E60 M5 DCT Transmission Swap - Page 4 - BMW M5 Forum and M6 Forums
 57Likes
Closed Thread
post #31 of 266 Old 27th January 2017, 11:07 AM
Craze
Well that russian m6 a thread was started a long time ago and no updates, it went silent
Unless this is another person
Craze is online now
post #32 of 266 Old 27th January 2017, 03:53 PM
Bucky
I want DCT shift speed with the neck snapping change of the SMG. I am asking too much I think.
Bucky is offline
post #33 of 266 Old 27th January 2017, 07:09 PM Thread Starter
DinanE60M5
DinanE60M5's Avatar
Originally Posted by CHARIOT View Post
Never gonna happen, at least not legitimately from BMW.
The software doesn't have a valid street release approval for public road use, so BMW would be putting themselves on the line if it were ever to get handed over without legitimately going through the public use validation process. All drivetrain and powertrain related software releases get an individual release/approval for the component, then a group "Verbund" release/approval for all the software/components together as partner components in the vehicle stating that the components (DME, DSC, EGS, etc.) are approved to work together on the same software level. This is how the whole i-step process was born and came to fruition.
The only possibility is if the software was privately written...the legitimate S85 DCT software from BMW will never reach public hands unless it is stolen and unknowingly distributed like the rest of the software and development tools seem to end up.
I've set my calendar to check in in 3 weeks. I'm hoping this isn't another pipe dream thread; i'd personally really like to see the DCT V10 combo come to life with a little more proof than people claiming it's been done before with no hardcore proof to validate the yip-yap
I will keep you all updated once I drop the car off in roughly 2 weeks. Gintani is always packed and busy so the first date available is two weeks out. I can't wait to be fully finished with the project.
2009 BMW M5 Alpine White/ Black Merino Extended Leather
Exterior
-IND E60 M5 Cosmetic Package
-Powdercoated Gloss Black OEM Wheels
-BMW M Performance Black Kidney Grilles
Performance
-Dinan High Flow Air Mass Meter and Intake Assemblies
-Dinan Stage 3 Performance Engine Software
-Dinan 13% Underdrive Crankshaft Pulley Kit
-DCT Transmission (Underway)
-Eisenmann Race Exhaust (Oval Tips)
-Supersprint Section 2 X-Pipe (Resonator Delete)
-RPI Scoops
Handling
-Dinan 21mm Adjustable Rear Anti-Roll Bar
-Dinan Supplemental Ride Quality & Handling Kit
-Dinan Performance Spring Set
DinanE60M5 is online now
The Following User Says Thank You to DinanE60M5 For This Useful Post:
JJmattos1 (28th January 2017)
post #34 of 266 Old 28th January 2017, 12:14 AM
JGINWS
JGINWS's Avatar
im not saying it cant happen ........
honestly i want it to happen so i can buy one ......
there are a lot of very knowledgeable ppl on board ...... a lot of them have significant resources and have modded their cars and upgraded motors to the point that it is borderline insanity ...... smg is another weak point. if anyone had successfully done this at this point we would all know and it would be on youtube .......
the s85 has been out of production longer than they produced it ...... lots would have this ....... as you can see no one has it .........
Good luck
JGINWS is offline
post #35 of 266 Old 28th January 2017, 04:59 PM
moe00
moe00's Avatar
would a dct transmission hold the weight of the car?
aren't there any relation with with Transmission also and car weight?
moe00 is offline
post #36 of 266 Old 28th January 2017, 05:04 PM
JJmattos1
The OP said that the M6 would receive a biturbo system. So I really don't think that the DCT trans is a OEM one, they probably are going to upgrade it too.. so the weight will not be a problem!
Sent from my XT1058 using Tapatalk
JJmattos1 is offline
post #37 of 266 Old 28th January 2017, 05:35 PM
Bucky
Weight should not be a problem. If that was the case, having passengers in the car would screw things up.
Bucky is offline
post #38 of 266 Old 28th January 2017, 05:48 PM
Blue Thunder
The F10 M5 is heavier than the E60 M5 and also has more torque.
1999 M5 Avus Blau Metallic
Twin Rotrex superchargers, Front mount intercooler, Steel sleeved block, Forged CP pistons, 10.5:1 compression, SS Headers, SS race cats, TUBI Rumore, UUC 11" V12 cerametallic clutch + flywheel, UUC EVO3 SSK w/DSSR, Brembo GT4 brakes front/back, KWv3's, Angel Eyes + Angelibrights, Celis, 19" Hamann PG2´s, Strongstrut front Strut Brace, BMW fire extinguisher, Dynawin headunit, CF interior trim
1989 E30 M3 White - track toy
S85B54 with M-DCT - 600+ hp, 1300kg rocket for the Ring being built
Blue Thunder is offline
The Following User Says Thank You to Blue Thunder For This Useful Post:
post #39 of 266 Old 28th January 2017, 07:47 PM
Bucky
Which transmission are they using? The one from an E9X M3 or the F10 M5 version? Is there a difference?
Bucky is offline
post #40 of 266 Old 29th January 2017, 03:10 AM
CHARIOT
All manual cars use the GS6-53BZ. The transmissions are all technically interchangeable, but the internals vary based on torque specs as well as some exterior pieces like the output flange and the mounting brackets. Same applies to the GS7 DCT trans.
CHARIOT is offline
The Following User Says Thank You to CHARIOT For This Useful Post:
JJmattos1 (29th January 2017)
Closed Thread
E60 M5 DCT Transmission Swap DinanE60M5 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 13th April 2017 02:54 AM
E60 For Sale: e60 BMW M5 ENGINE/TRANSMISSION COMPLETE SWAP German Parts / Other For Sale or Wanted 8 20th December 2011 07:39 AM
Gathering information on the M-DCT transmission Nate@IND E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 3 3rd April 2011 05:11 PM
Will the M6 get M DCT Transmission anytime soon? blkfast6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 18 18th February 2008 04:37 PM
