Blue smoke while reving - Page 7 - BMW M5 Forum and M6 Forums
 2Likes
post #61 of 71 Old 6th February 2017, 09:26 PM
rt7085
rt7085's Avatar
No the other way around: START the engine BEFORE you start the DIS procedure instead of starting it DURING the test procedure.
rt7085 is online now
post #62 of 71 Old 7th February 2017, 12:24 AM
tx tahoe z71
tx tahoe z71's Avatar
I think he lacked some punctuation. The way I read it, my punctuation added:
I have already tried [starting the process in DIS with the engine already running] but it didn't seem to work. If i don't start the engine and do like quick read of the codes, DIS lets me do it just fine, but as soon as i start the engine, error 200.95 [appears]. Never had this issue before. I am so disappointed that i can't get the end of this.
2001 M5 - Carbon black on black (purchased 2-2016)
- Stock for now, catching up on maintenance first...
2003 Tahoe Z71 - 600hp, E85, supercharged, cammed and bolted
- Much faster (and less reliable) than the M5
tx tahoe z71 is offline
post #63 of 71 Old 9th February 2017, 04:43 AM Thread Starter
ninjabmw
Turns out the cable was shorted ordered a new cable got the bleeding done today did it at least 3 times and performed the vanos tested 3 times as well and this is what i got.
All the Banks measurements were not met there were .40 and it was saying not Okay next to them.
Does this mean the Solenoids? I will upload pictures that i took from DIS so you guys can help me decide if its the solenoids the timing error still comes back after the engine idles.
ninjabmw is offline
post #64 of 71 Old 9th February 2017, 05:13 PM
Mfiveusa
Mfiveusa's Avatar
It may take a few more bleeding to get better results. The vanos system hates any air trapped within or dirt that may come into contact with the vanos solenoids especially. Did you change your oil? Also make sure you clear any adaptations before proceeding. I found that helps.
I applaud you for the great effort put through on this project. Best of luck don't give up you almost there
Mfiveusa is offline
post #65 of 71 Old 10th February 2017, 06:01 AM Thread Starter
ninjabmw
I did change my oil. I ran the test 2 to 3 more times same results it idles very poorly the rpm moves back and forth when its idling and few minutes into it again the same codes come up. I can seem to get around it when its doing the bleeding test the codes do no come up as well as no check engine light. After the bleeding is done the codes come up again.
ninjabmw is offline
post #66 of 71 Old 14th February 2017, 06:51 PM
Mfiveusa
Mfiveusa's Avatar
The hunting up/down of the idle could be indicative of poor fuel/air mixture or ratio. Double check your hoses/connections ,maybe you may have moved or not plugged in a vacuum line correctly.
Mfiveusa is offline
post #67 of 71 Old 14th February 2017, 06:53 PM
Bucky
Check this, if the hoses are good then your solenoids need changing out.
Bucky is offline
post #68 of 71 Old 16th February 2017, 01:49 AM Thread Starter
ninjabmw
I messed around with the solenoid figured which ones are better put them on 1 side and put the other semi bad ones on the other did the test and oh man bank 2 codes come up for intake and exhaust. Now i am on a hunt for 4 solenoids.
Question that i have do i have to buy the new revision ones or can i get the old ones as well? The car is an 06.
ninjabmw is offline
post #69 of 71 Old 16th February 2017, 02:12 PM
Bucky
I thought there was just 1 design.
Bucky is offline
post #70 of 71 Old 16th February 2017, 04:05 PM
Mfiveusa
Mfiveusa's Avatar
Yea, They should be all one design, most likely updated part #'s. Question, you never threw a solenoid code before opening up the engine correct? So most likely two things happened.Either the solenoids got contaminated with dirt or they finally just quit.
The solenoids are well know to throw a false positive code, meaning they are extremely sensitive to dirt. BMW, in the S85 repair manual tell you to be extremely careful when working with them.You have to make sure you have a super clean environment. I occasionally check mine from time to time when I run my vanos bleed.I have seen them show integrity issues from time to time , but never threw a code. I tend to see this as my oil get closer to end of life.
So just make sure they are clean and run a few more test before biting the bullet. Good luck!
Mfiveusa is offline
Blue smoke (under specific test conditions) turabo87 E39 M5 and E52 Z8 Discussion 66 18th August 2015 10:17 AM
Intermittent blue smoke XxGhostxX E39 M5 and E52 Z8 Discussion 11 2nd November 2014 05:12 PM
Noob needs help with white & blue smoke alfanator E39 M5 and E52 Z8 Discussion 46 28th May 2013 07:13 PM
Puff of Blue smoke maxm5 E39 M5 and E52 Z8 Discussion 17 18th February 2010 08:54 AM
Blue Smoke on start up ;-( t.j E39 M5 and E52 Z8 Discussion 7 29th September 2006 08:00 PM
