Blue smoke while reving - Page 6 - BMW M5 Forum and M6 Forums
 2Likes
post #51 of 71 Old 2nd February 2017, 10:16 PM Thread Starter
ninjabmw
Originally Posted by rt7085 View Post
I commend you devotion and persistence in trying to fix this! It will be very gratifying for you when you do. Please post some pictures of the process steps if you have them. I know it is hard to grab a camera with oily dirty hands.
ISTA/D is the tool to use. In my latest version of ISTA+, I found the bleeding procedure under service jobs. It is a guided procedure. Fire it off and follow the steps. Repeat it a couple of times as many have reported the need for that to be successful.
Is it okay to start the car up without running the Vanos bleeding test? Or do i have to follow the test on my very first start up of the car?
Of course i will upload all the pictures that i took, i didnt take pictures of the basics like removing the intakes etc. Maybe we can make it into a DIY guide for others.
ninjabmw is offline
post #52 of 71 Old 3rd February 2017, 03:12 AM
rt7085
rt7085's Avatar
You need pressure to bleed it so the engine must run. All it does is cycle the valves back and forward in an attempt to purge trapped air that way.
rt7085 is online now
post #53 of 71 Old 4th February 2017, 02:03 AM Thread Starter
ninjabmw
I am getting vanos control exhaust bank 1/2 codes in DIS Vanos control on both cylinder banks show fault what could be the cause of this. The vanos stops on both cylinder banks are show no fault but the Vanos control show fault generic code shows as p0025 and p0015?
ninjabmw is offline
post #54 of 71 Old 4th February 2017, 03:07 AM
rt7085
rt7085's Avatar
I wonder if some adjustment is needed. Are you sure you installed the VANOS system correctly? You are getting a 7000 RPM DME emergency limit as well?
post #55 of 71 Old 4th February 2017, 03:20 AM Thread Starter
ninjabmw
No i am actually getting a 4500 rpm limit basically limp mode codes come up like this
Vanos Control Exhaust Bank 1- Actual Value too Low
Vanos Control Exhaust Bank 2-Actual Value too Low
271B
271D
ninjabmw is offline
post #56 of 71 Old 4th February 2017, 08:01 PM
rt7085
rt7085's Avatar
post #57 of 71 Old 4th February 2017, 08:48 PM
Muz_M5
Muz_M5's Avatar
271B
271D
Can you post some pictures of the removal and install PLEASEEEE O @ninjabmw
BMW M5 '06 Interlagos Blue , Supersprint headers, K&N typhoons, Hartge accelerator booster
MINI COOPER S JCW '06 Hot chilli red, 17% reduction pulley, straight piped
SUZUKI JIMNY '13 Gun metallic grey, 2 Inch body lift, K&N Cold air intake
YAMAHA R1 '02 Yoshimura full system exhaust, Stretched, BMC filter
Muz_M5 is offline
post #58 of 71 Old 5th February 2017, 06:30 AM Thread Starter
ninjabmw
For some odd reason i am having issues with DIS V57 it is not working properly for me. Everything works fine i can read the faults and the codes but as soon as i go to start the bleeding process when it says run car at idle so it can warm up the connection ends as soon as i start the car and i get error number 200.95 this never happened to me before for some reason this is keeping me from bleeding the system so its taking me a while to post back the results.
I will upload pictures as soon as i am done writing it up in Word the process.
If anyone can shine a light on the DIS issue that i am having would be great.
ninjabmw is offline
post #59 of 71 Old 5th February 2017, 04:57 PM
rt7085
rt7085's Avatar
The crank drops out the battery voltage and the OBD dongle goes offline for a moment. DIS Does not like it. Try to start the process in DIS with the engine already running?
post #60 of 71 Old 5th February 2017, 11:28 PM Thread Starter
ninjabmw
I have already tried that but it didnt seem to work if i dont start the engine and do like quick read of the codes DIS lets me do it just fine but as soon as i start the engine error 200.95 never had this issue before. I am so disappointed that i cant get the end of this.
ninjabmw is offline
Blue smoke (under specific test conditions) turabo87 E39 M5 and E52 Z8 Discussion 66 18th August 2015 11:17 AM
Intermittent blue smoke XxGhostxX E39 M5 and E52 Z8 Discussion 11 2nd November 2014 06:12 PM
Noob needs help with white & blue smoke alfanator E39 M5 and E52 Z8 Discussion 46 28th May 2013 08:13 PM
Puff of Blue smoke maxm5 E39 M5 and E52 Z8 Discussion 17 18th February 2010 09:54 AM
Blue Smoke on start up ;-( t.j E39 M5 and E52 Z8 Discussion 7 29th September 2006 09:00 PM
