Blue smoke while reving - Page 5 - BMW M5 Forum and M6 Forums
 2Likes
post #41 of 71 Old 24th January 2017, 02:11 PM
Bucky
You might be able to use a valve spring compressor from an auto store. There are a few different types, I have one that might work with a bit modification so will grab a photo if I have time.
You will need a magnetic tool to go with it to catch the retainers.
Bucky is offline
post #42 of 71 Old 25th January 2017, 05:14 AM Thread Starter
ninjabmw
UPDATE
I have already removed the valve springs and the valve seals how do i go about installing them? I have the magnetic socket so i removed them with ease the installation how do i go about that any help is greatly appreciated.
ninjabmw is offline
post #43 of 71 Old 25th January 2017, 05:20 AM
rt7085
rt7085's Avatar
Originally Posted by ninjabmw View Post
UPDATE
Before you do so: Did you locate the issue?
rt7085 is offline
post #44 of 71 Old 25th January 2017, 06:23 AM Thread Starter
ninjabmw
Cylinder 5 exhaust valve seal was shot, the intakes seemed fine but the exhaust valve seal was shot spring was fine.
ninjabmw is offline
post #45 of 71 Old 25th January 2017, 12:27 PM
rt7085
rt7085's Avatar
Do you have some pictures? I would like to see how it failed.
rt7085 is offline
post #46 of 71 Old 25th January 2017, 01:56 PM
Bucky
That explains the oil but not the loss of compression.
Bucky is offline
post #47 of 71 Old 25th January 2017, 05:49 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
jcolley is online now
post #48 of 71 Old 25th January 2017, 08:21 PM
Bucky
Originally Posted by jcolley View Post
Are you talking the valve seat or the valve guide?
I am thinking the valve stem seal since he does not have the head off.
Bucky is offline
post #49 of 71 Old 2nd February 2017, 09:03 AM Thread Starter
ninjabmw
UPDATE
Sorry for posting this super late been super busy with everything lately.
So i took the stem seals off the green circular objects.
I made a home made tool in order for me to install them and got a valve stem removal tool from amazon for $10.
This job i would give 9/10 10 being the hardest difficulty to do at home this is not an easy job like changing an oil.
Cylinder 5 was a nightmare to do it took me 6 hours to put the collet's on it since there is no room to work with.
Mean while i lost 1 collet and had to go to BMW Motorcycle dealer to buy that's right a motorcycle dealer had it and no other.
I also ordered the cam alignment tool, since the gears do have to come out obviously.
https://jet.com/product/S85-BMW-Cam-...9a2055ad0d6401
That is the one that i got.
I am going to align everything tomorrow and hopefully start the car tomorrow, i know that the Vanos is going to need a bleeding i have all the software DIS InstaD/P INPA etc.
Which one is the best to do the job and if possible any tutorials on how to run the bleeding would help.
I am going to upload pictures tomorrow of the tool that i made if anyone is interested as well as all the pictures that i took of the old stem seals and the new ones.
The job took me 2 full days to do just in case if anyone is wondering there is total of 40 stem seals 20 each side with each cylinder having 4.
ninjabmw is offline
post #50 of 71 Old 2nd February 2017, 01:08 PM
rt7085
rt7085's Avatar
I commend you devotion and persistence in trying to fix this! It will be very gratifying for you when you do. Please post some pictures of the process steps if you have them. I know it is hard to grab a camera with oily dirty hands.
ISTA/D is the tool to use. In my latest version of ISTA+, I found the bleeding procedure under service jobs. It is a guided procedure. Fire it off and follow the steps. Repeat it a couple of times as many have reported the need for that to be successful.
rt7085 is offline
Blue smoke (under specific test conditions) turabo87 E39 M5 and E52 Z8 Discussion 66 18th August 2015 10:17 AM
Intermittent blue smoke XxGhostxX E39 M5 and E52 Z8 Discussion 11 2nd November 2014 05:12 PM
Noob needs help with white & blue smoke alfanator E39 M5 and E52 Z8 Discussion 46 28th May 2013 07:13 PM
Puff of Blue smoke maxm5 E39 M5 and E52 Z8 Discussion 17 18th February 2010 08:54 AM
Blue Smoke on start up ;-( t.j E39 M5 and E52 Z8 Discussion 7 29th September 2006 08:00 PM
