Blue smoke while reving - Page 3 - BMW M5 Forum and M6 Forums
 2Likes
post #21 of 71 Old 17th January 2017, 01:15 AM Thread Starter
ninjabmw
The power is still there to be honest since i dont really drive the car aggressive i can still feel the power being there. By saying expensive how bad is it? $4-5000 in parts because the clutch and smg is brand new.
ninjabmw is offline
post #22 of 71 Old 17th January 2017, 01:39 AM
rt7085
rt7085's Avatar
If you get a Troy-rebuilt engine you are look around $10k. But have an expert look at it. Sorry man. It really sucks.
rt7085 is offline
post #23 of 71 Old 17th January 2017, 02:01 AM Thread Starter
ninjabmw
So by changing the piston rings and rod bearing the compression wont be back on that cylinder?
ninjabmw is offline
post #24 of 71 Old 17th January 2017, 02:05 AM
drewTT
No, that cylinder is probably toast. Scorred, etc. Best bet is a rebuilt engine.
2008 M5 SMG
drewTT is offline
post #25 of 71 Old 17th January 2017, 02:25 AM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Could be as easy as a valve spring. OP, try a "wet compression check" by putting a couple of ounces of oil in the spark plug hole on that cylinder and seeing if compression increases. If so, the problem is likely the bottom end (ring/cylinder wall). If it doesn't change at all, it's likely the top end and could be a valve or spring.
jcolley is online now
post #26 of 71 Old 17th January 2017, 02:55 AM
rt7085
rt7085's Avatar
But what explains the oil on the spark plug? If it was just a bad valve spring, I agree no compression. But there should not be any oil in the chamber?
Put a borescope down the spark plug hole and look. Make sure the piston is at BDC.
rt7085 is offline
post #27 of 71 Old 17th January 2017, 03:41 AM Thread Starter
ninjabmw
jcolley thanks for the reply. I will do the oil test tomorrow in the morning. And to answer RT it actually was carbon on the spark plug when i put a boroscope to look at it there was no marks of oil on that cylinder and it was build up carbon. All the cylinders actually had some type of build up carbon on it. I dont think that the cylinder is toast nor the motor because everything functions normally besides the oil consumption. Test will tell tomorrow i will keep you guys posted on this journey that i am having with this car.
ninjabmw is offline
post #28 of 71 Old 17th January 2017, 07:27 AM
achman
Blue smoke on decel- valve guides/valves
blue smoke while revving- rings
A compression and leakdown test for $200 will tell you all you need to know
Sent from my STV100-2 using Tapatalk
achman is offline
post #29 of 71 Old 17th January 2017, 02:39 PM
Thumper600
Thumper600's Avatar
Unfortunately the comment about cleaning any CCV related anything won't help. You mention #5 being caked with burnt oil and no compression. This may sound odd but try doing the "wet test" with some Marvel Mystery Oil. put some in the cylinder to see whether or not that "loosens" up your rings to the point of sealing with block. Only thing is that test will take a few hours in that the oil needs time to loosen up what ever may be stuck.
As far as CCV is concerned, there is a website called realoem.com and depicted there are any and all diagrams of what's related to any BMW so you can look at pictures and decipher your next plan of action.
Thumper600 is offline
post #30 of 71 Old 17th January 2017, 03:19 PM
Bucky
Low compressor on that cylinder, something is dead. Rings, valve, spring.
Do a leak down test and you should know for certain.
Bucky is offline
Blue smoke (under specific test conditions) turabo87 E39 M5 and E52 Z8 Discussion 66 18th August 2015 10:17 AM
Intermittent blue smoke XxGhostxX E39 M5 and E52 Z8 Discussion 11 2nd November 2014 05:12 PM
Noob needs help with white & blue smoke alfanator E39 M5 and E52 Z8 Discussion 46 28th May 2013 07:13 PM
Puff of Blue smoke maxm5 E39 M5 and E52 Z8 Discussion 17 18th February 2010 08:54 AM
Blue Smoke on start up ;-( t.j E39 M5 and E52 Z8 Discussion 7 29th September 2006 08:00 PM
