Blue smoke while reving - Page 2 - BMW M5 Forum and M6 Forums
 2Likes
post #11 of 71 Old 16th January 2017, 01:48 PM
Bucky
CCV or rings. If you still have your primary cats, expect to change them soon as they will get blocked up with the oil.
Bucky is offline
post #12 of 71 Old 16th January 2017, 02:29 PM
rt7085
rt7085's Avatar
Well, not all rings are going bad at the same time I would imagine. Unless the engine experienced bad treatment such as the wrong oil or the like. It would just be one bad cylinder in the bunch? Hence my tail pipe question. Did this come on suddenly or gradually? Is it running smoothly?
So given that both pipes put out the same amount I would suspect it is a common to all cylinders problem.
The oil pan should be under slight vacuum driven by the plenum attachment. Have you pulled off all these hoses and see if they are backed up? Did you pull off the plenum and look down the throttle bodies. Any of them particularly dirty?
rt7085 is offline
post #13 of 71 Old 16th January 2017, 03:42 PM
cold m3
cold m3's Avatar
Does it feel down on power? When you pull the oil cap off with the car idling does smoke blow out of there like crazy? I would say get a compression test done and go from there.
Sent from my SCH-I545 using Tapatalk
Current: 6MT 2008 E60 M5 (IB)
Sold: 6MT E46 M3 (6 years of ownership)
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
post #14 of 71 Old 16th January 2017, 03:44 PM
Bucky
Pull the spark plugs and check each one for oil on them. This will give you an idea if it is 1 cylinder or all of them.
Check the throttle body butterfly's to see if they are dirty and covered in oil.
Your going to have to take apart parts of the engine to find out where it is coming from, no way round it.
Bucky is offline
post #15 of 71 Old 16th January 2017, 09:23 PM
Thumper600
Thumper600's Avatar
does smoke come out from under the hood? If so and you smell oil more on one side of the motor then the other check your valve cover gasket
Thumper600 is offline
post #16 of 71 Old 16th January 2017, 10:24 PM
Thumper600
Thumper600's Avatar
Don't know why the edit button doesn't work but anyhow, if no smoke from under the hood perhaps your crank case ventilation is clogged
post #17 of 71 Old 16th January 2017, 10:30 PM Thread Starter
ninjabmw
Thanks guys for all the help and useful information that you guys give me.
This is what i did. I pulled everything off the engine took the spark plugs out and did a compression check. The Cyl 5 spark plug was covered in burned oil. The results are CYL 5 compression 30 and the rest were all 90 i checked every single one. So now the question is what am i going to expect to be changed and how much money wise?
Thumper i dont smell any oil from under the hood. By saying the ventilation is clogged how do i go about cleaning that?
As mentioned i have already changed the non return valves and that didnt help.
ninjabmw is offline
post #18 of 71 Old 16th January 2017, 10:30 PM Thread Starter
ninjabmw
I will upload pictures later tonight just so you guys can see whats going on with it.
ninjabmw is offline
post #19 of 71 Old 17th January 2017, 12:32 AM
rt7085
rt7085's Avatar
This is an engine rebuild. The engine has to come out. This will be expensive. Contact @jcolley .
You have a compression issue on #5. It is not the CCV or anything like that.
rt7085 is offline
post #20 of 71 Old 17th January 2017, 01:01 AM
cold m3
cold m3's Avatar
Yeah I hate to say it but it sounds like your engine is 'blown' (
Haven't you noticed a loss in power?
Instagram: Cold_M3
Photos of My ///M5
cold m3 is offline
Blue smoke (under specific test conditions) turabo87 E39 M5 and E52 Z8 Discussion 66 18th August 2015 10:17 AM
Intermittent blue smoke XxGhostxX E39 M5 and E52 Z8 Discussion 11 2nd November 2014 05:12 PM
Noob needs help with white & blue smoke alfanator E39 M5 and E52 Z8 Discussion 46 28th May 2013 07:13 PM
Puff of Blue smoke maxm5 E39 M5 and E52 Z8 Discussion 17 18th February 2010 08:54 AM
Blue Smoke on start up ;-( t.j E39 M5 and E52 Z8 Discussion 7 29th September 2006 08:00 PM
