Air intake fault codes - BMW M5 Forum and M6 Forums
post #1 of 14 Old 31st December 2016, 05:37 AM Thread Starter
Craze
Hi, hoping for some help, have had codes 2b5a come up (bank 2 intake sensor plausibility) come up a lot
Clear it and returns
Swapped mafs left to right and i get 2b12 which is ambient air intake sensor not plausible
Bank 1 is a different code and that one didnt come up when swapped mafs which id imagine if faulty it would
Any idea if its mafs? Have ordered new ones but 2 week wait
Is there another temp sensor aside from mafs? Thanks
Craze is offline
post #2 of 14 Old 31st December 2016, 06:28 AM
Texasgrego
Texasgrego's Avatar
If the problem is MAF output, the header tune can exacerbate the problem and the fault codes may change.
Try flashing back to stock file and clear/reread.
Look at live output from the MAF's. If there is a large difference from bank to bank (be advised that iat will be slightly higher B2 v. B1 with the eventuri, due to screen orientation) or noticeable spikiness in the data, then one of them is probably bad.
It MAY work in the other side after switching around/fuking with it a few times. Or not.
Texasgrego is offline
post #3 of 14 Old 31st December 2016, 07:39 AM Thread Starter
Craze
Ah ok thanks
Does inpa allow live output??
Will be swapping mafs and injectors as preventative maintenance in about 2 weeks
Craze is offline
post #4 of 14 Old 31st December 2016, 08:42 AM
Texasgrego
Texasgrego's Avatar
IDK
Never got inpa to work used borrowed BAV TECH at that point
Just don't get caught with a bad MAF in one hand and a good one in the other, because someone WILL walk up and ask a question oh shi.t.
post #5 of 14 Old 31st December 2016, 10:18 AM Thread Starter
Craze
Craze is offline
post #6 of 14 Old 31st December 2016, 05:07 PM
IGNANT
MAFs are installed properly? I recall 1 side has to face oncoming air (airbox direction)
IGNANT is offline
post #7 of 14 Old 31st December 2016, 06:02 PM Thread Starter
Craze
Craze is offline
post #8 of 14 Old 2nd January 2017, 01:16 PM Thread Starter
Craze
Ah thanks for the pic, they are correct
Does the maf also function as ambient air sensor??
Craze is offline
post #9 of 14 Old 11th January 2017, 11:47 AM Thread Starter
Craze
New mafs and it logs 2b5a after a couple of drives
It runs perfect
Perhaps combination of intakes and tune? L
Craze is offline
post #10 of 14 Old 11th January 2017, 01:14 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Can you take a pic of the MAF orientation? It's possible with Eventuris to rotate the MAF housing in a non-desirable way. The entrances of a MAF body into an airstream should be perpendicular to any directional changes in flow, so it matters there the bend is and how the MAF is positioned.
jcolley is offline
SMG transmission fault - unknown fault codes saxant1 E60 M5 and E61 M5 Touring Discussion 0 8th April 2016 11:32 PM
E60 M5 - Transmission fault but un-identifiable fault codes saxant1 E60 M5 and E61 M5 Touring Discussion 0 6th April 2016 10:52 AM
m5 fault codes. need help please. gazb666gareth E60 M5 and E61 M5 Touring Discussion 8 21st April 2015 11:13 AM
Air Intake Fault Codes - E60 M5 rsancol E60 M5 and E61 M5 Touring Discussion 5 27th February 2012 10:42 PM
HELP: intake sensors fault codes ++ 1C00lVC E39 M5 and E52 Z8 Discussion 2 3rd March 2009 06:37 AM
