Fast Attack Motorsports (FAMS) Tune Review - Dyno & Datalogs - Page 25 - BMW M5 Forum and M6 Forums
 187Likes
post #241 of 330 Old 30th January 2017, 08:29 PM
Muz_M5
Muz_M5's Avatar
Originally Posted by Bucky View Post
What about air temp and coolant temp? If they are fine then it seems normal to me.
Best to compare with someone else car with no cats, try a different fuel brand.
Yeah I am trying to get hold of one with the same set-up so far no luck..
Thanks bro any more insight much appreciated.
Muz_M5 is offline
post #242 of 330 Old 30th January 2017, 09:10 PM
anatoly14
I had two e60s with catless headers (one was completely straight piped), the smell is normal. Tune wont solve the smell problem.
anatoly14 is offline
post #243 of 330 Old 30th January 2017, 09:45 PM
Muz_M5
Muz_M5's Avatar
**** maybe changing the injectors and spark n coils would solve it?
Muz_M5 is offline
post #244 of 330 Old 31st January 2017, 05:33 AM
Silver///M5
Silver///M5's Avatar
Silver///M5 is offline
post #245 of 330 Old 31st January 2017, 11:55 PM
5soko
5soko's Avatar
Originally Posted by Muz_M5 View Post
Hi guys need some info before purchasing the tune! from the reviews it promises to be amazing but I got a few question
I have supersprint headers installed as well as secondary Cat delete.
K&N typhoons
Hartge accelerator booster
Now when I bought the car it came with all of these. The cars been running RICH like a burning oil tank but I figured that during the service and new clutch install the ECU was flashed back to stock and that is why the car runs rich to compensate for the different parameters.
1) Will getting the tune help the RICH problem?
2) Will K&N typhoons etc be incorporated for the high flow of air mass into the tune?
3) will the post-cat o2 sensors be made to switch off (because I just started to get the emissions service message)
Need help before Buying
Get the Fams tune, it will set the parameters in place and where they need to be, remove the SES/CEL light you might have on now on the stock software and headers, and you will take full advantage of the power the headers will give this engine.
5soko is offline
post #246 of 330 Old 1st February 2017, 06:28 PM
Muz_M5
Muz_M5's Avatar
Hey brother 5soko the TUNE is defo on the table need to get the beast sorted first .. no errors and all and then BAM on with the tune... BTW does FAM gave Alpha N protocols so get rid of MAFS? Curious..
Muz_M5 is offline
post #247 of 330 Old 2nd February 2017, 03:05 AM
5soko
5soko's Avatar
FAMS can do alpha N no problem, but they have their own Alpha N hardware kit which is going to be fully plug and play coming soon.. Plug and play IAT sensor, block off plate..
5soko is offline
post #248 of 330 Old 2nd February 2017, 04:13 AM
anatoly14
Ok guys, so, I wanted to see what my car would make on the 93+ map, so I got some 95 octane, flashed my 93 map (Yes I did let the car adjust, drove 150 miles and did plenty of hard pulls), so here are the results:
496WHP / 347TQ
Mod List:
High flow headers
Meisterschaft section 1 & 2 with secondary cat deletes
Section 3 Agency Power valvetronic mufflers
FAMS Tune
BMC filter
EvoSport Pulley
RPI scoops & block off plates
AP Power Pedal
So, to summarize:
Before FAMS tune car dynoed 460WHP / 328TQ on 91octane
After the FAMS tune:
On 91Map 482WHP / 339TQ (22WHP / 11TQ Gain)
On 93Map 496WHP / 347TQ (36WHP / 19TQ Gain)
Dyno sheet attached, Video: https://youtu.be/S6WPej3Mcic
The Following User Says Thank You to anatoly14 For This Useful Post:
feisaldz (2nd February 2017)
post #249 of 330 Old 2nd February 2017, 12:23 PM
Muz_M5
Muz_M5's Avatar
496WHP / 347TQ
Mod List:
High flow headers
FAMS Tune
BMC filter
EvoSport Pulley
AP Power Pedal
So, to summarize:
IN LOVE !! I NEED THIS IN MY LIFE haha
BMW M5 '06 Interlagos Blue , Supersprint headers, K&N typhoons, Hartge accelerator booster
MINI COOPER S JCW '06 Hot chilli red, 17% reduction pulley, straight piped
SUZUKI JIMNY '13 Gun metallic grey, 2 Inch body lift, K&N Cold air intake
YAMAHA R1 '02 Yoshimura full system exhaust, Stretched, BMC filter
Muz_M5 is offline
post #250 of 330 Old 5th February 2017, 11:27 PM
Matt C
Matt C's Avatar
After a little to-ing and fro-ing got the FAM tune installed on the weekend. After install I wasn't able to take it for an immediate drive but started it (to make sure it still would I guess) and the difference was immediate. This may sound odd but the tune seems to line everything up. Idle was smoother than it ever has been and the typical mechanical racket that comes from the S85 when cold, even without having the cold start process deleted, is significantly less. Its odd but it sounds like everything is aligned.
Under power the car pulls harder. Shifts better and just generally feels like it should. Crisp and punchy. My seat of the pants dyno suggests an additional 20 bhp.
I'm a very happy owner and can't thank Jim enough for the extra hours spent coding a version he hadn't worked on previously.
If you're considering a tune, otherwise why would you be on this thread I'm guessing , do it. Awesome and more than reasonable bang for buck.
Cheers,
Matt
///M Fanboi
E60 2007 M5. Michi PSS's. Eibach. FAM. BE and ARP's. BMC. RPi.
E46 2004.5 M3. RIP 4th May 2015 my joyful toy.
Matt C is offline
The Following User Says Thank You to Matt C For This Useful Post:
feisaldz (6th February 2017)
Fast Attack Motorsports S85 Performance Tuning jcolley M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 33 26th April 2017 11:26 PM
Fast Attack Motorsports Dyno Results are in! torque E60 M5 and E61 M5 Touring Discussion 36 13th September 2016 12:15 AM
Trouble contacting Fast Attack Motorsports? Minimization E60 M5 and E61 M5 Touring Discussion 18 27th June 2016 02:54 AM
///Fast Attack Motorsports - VDO S85 Throttle Actuators jcolley M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 5 16th June 2016 10:16 PM
Tune, fast attack vs Evolve vs jaws M6sweden E60 M5 and E61 M5 Touring Discussion 12 27th May 2016 08:18 PM
