S85 Vanos Solenoids prices going crazy - Page 36 - BMW M5 Forum and M6 Forums
 75Likes
post #351 of 367 Old 15th February 2017, 11:17 AM
Craze
Got new solenoids fitted in my car. I have done about 500km and sometimes when idling it goes up and down a bit (not too bad, and never did it prior)
Is this the dme adpating slowly to the new solenoids??
Ambient temps today were a lot hotter than normal
New test results are .8 and .9
Craze is online now
post #352 of 367 Old 15th February 2017, 12:32 PM
Coors
Coors's Avatar
Tell us more. Did you purchase them from the dealer? A 3rd party vendor? How much per valve? Who did the installation?
Was the bleed procedure ran multiple times after installation? Were VANOS adaptation values rest? Just curious...
The system should stabilize over time the more cycles the DME sees.
Coors is offline
post #353 of 367 Old 15th February 2017, 08:50 PM
Craze
Bimmerzone
Was dear but cheaper than other vendors
Bmw installed it charged me 2hrs labor
It was bled
Adaptions not sure
How does it drive? Doesnt feel any different hahaha and im sensitive to changes
Maybe sings a little smoother but marginal
Craze is online now
post #354 of 367 Old 16th February 2017, 08:07 PM
Slippery
Slippery's Avatar
Bmw dealer renewed all 4 of mine a couple of months ago under warranty. Doesn't drive any different but the Vanos is quieter.
2006 E60 M5 & Mk7 Golf GTI DSG.
Slippery is offline
post #355 of 367 Old 17th February 2017, 09:35 AM
Craze
I did however get 1-2l per hundred km better fuel economy
Craze is online now
post #356 of 367 Old 18th February 2017, 01:41 PM
Tim_Mc
I'm taking my 08 in Monday to dealer. I've lost the 6000-8000 bump in power along with an inconsistent idle at times as well as inconsistent low rpm accel. No codes thrown. We will see how the dealer/warranty work this.
Tim_Mc is offline
post #357 of 367 Old 21st February 2017, 03:33 AM
Tim_Mc
Well, no dice-they wouldn't change unless they were below .6 quality. Mine are .6, .7, .8, and .9. I lean toward the basis of my power loss. $1875 a solenoid...I wasn't going to fund the change-I'll wait until they fail and have warranty cover.
When will a suitable substitute be available...
Tim_Mc is offline
post #358 of 367 Old 21st February 2017, 04:18 AM
5soko
5soko's Avatar
Your passing the vanos test that means which is good... Stay on top of your oil changes and change your oil At or less then 5K miles to keep them clean as possible. I Like to do 3K oil changes
2009 ///M5
Evolve Alpha-N Stage 2 Flash Tune | Eventuri Intake Kit | RPI GTS Full Exhaust
OEM Alcantara tri-stitch steering wheel|LUX H8 160 Angel eyes|Osram CBI's
IND Black Gloss Fender Vents|IND Painted Side Markers
Satin Black OEM wheels |Michelin PSS |30% Tint|LED License Plate lights
BMW Performance Grills|Full OEM BMW LED Interior + Trunk
Oem M projection Door lights|US Mill Work Tow plate|OEM M Floor Mats|Coding
5soko is offline
post #359 of 367 Old 21st February 2017, 09:21 AM
Derived
Really hope there is some sort of solution forthcoming for this - if prices are approaching 2k/solenoid, there really is no point in keeping the car long-term. That's insane. Mine are fine for now, but I dread the day they start to go, that will be a major tipping point if prices are going to stay this way or even increase. Hopefully I'll get a few more years out of it before this happens, and by then a reasonable solution will present itself.
Sent from my iPad using Tapatalk
Derived is offline
post #360 of 367 Old 21st February 2017, 09:40 AM
Craze
They can be had for about 1000-1500 each.
These cars are pretty cheap to but now, cheaper than an e39 now in australia
People still seem to struggle with the concept that is was $250000au when new! It costs money to fix
They buy their 2nd hand rocket for $22k and expect it to run like a camry that revs to 5000.
The are dear to fix, it come with owing this car
There are many other things that can break that are just as dear if not dearer to fix
Craze is online now
m5 vanos solenoids gazb666gareth E60 M5 and E61 M5 Touring Discussion 15 21st February 2017 11:30 AM
DIY - Changing the S85 VANOS solenoids anzafin E60 M5 and E61 M5 Touring Discussion 151 10th January 2017 12:26 AM
Did my Vanos Solenoids Blue Thunder E39 M5 and E52 Z8 Discussion 14 26th February 2015 07:06 AM
VANOS or Solenoids??? Eight8toy E39 M5 and E52 Z8 Discussion 7 19th February 2014 01:24 AM
VANOS-solenoids s85!!! alex m E60 M5 and E61 M5 Touring Discussion 1 16th April 2013 10:36 PM
