Fast Attack Motorsports Dyno Results are in! - BMW M5 Forum and M6 Forums
 31Likes
post #1 of 37 Old 3rd July 2016, 12:03 AM Thread Starter
torque
torque's Avatar
The run was done yesterday under 90F heat, with a very weak fan pointed to the car, and another one blowing into the oil cooler... The map had no time to adapt, I basically flashed and ran.
Remember this is a Mustang dyno, and take the HP value with a big stone of salt.
If you want to see what the dyno thinks the peak value is with weather compensation factor :
We also ran in AWD mode, as the Dyno operator had bad experience with these BMW models where you cannot disable traction control completely, so the front wheels were also spun.
I did test the map a couple of days prior to the dyno run (flashed stock back a day prior) , and it felt very very good; more alive and willing to go even in P400 mode. It might be just placebo effect, but I swear I hear the intake more, so it's one more reason to floor it all the time
If you look at the torque gain, I believe what my butt dyno felt is that 28ft.lb gain from 3500 all the way to 5250 RPM's where the torque and HP always meet...
I like it and I highly recommend it; I believe gains are even higher after adaptation and even more so if you have some other mods, like headers/exhaust, etc. Headers are most likely my next mod also...
_______________________________________________
BMW M5 E60 6 speed manual - /RPi intake scoops/Agency Power pulley/Fast Attack 93 tune
Audi A4 2007 6 Speed manual/JHM stage1 software 93 octane/Cobb Intake/New Audi sport suspensoin - the old lady
2001 VW Golf GTI VR6/intake/GIAC/Exhaust- the small one
torque is offline
post #2 of 37 Old 3rd July 2016, 12:10 AM Thread Starter
torque
torque's Avatar
One more thing, all runs done on 3rd gear plotted above.
I did do one 4th gear run for comparison, but they said it's more stress on the car, as it's much longer, and we reverted to 3rd... It also brings heat soak quicker due to high temperatures.
torque is offline
post #3 of 37 Old 3rd July 2016, 12:42 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Nice! What other mods do you have? Fuel?
I need to do mine, but I have had ZERO time.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =133,000 miles with no RCOD and counting ...just saying...
2007 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing (Blanton) 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PSS 255/40/19 and 295/35/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; RedLine B/S RDR off, F/R G1W-H, ALP w/GPS and BT. Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 miles!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; z3 1.9L ssk and ZHP shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the sub 2,400lb e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 228,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014 to a good home.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service autohausfrankfurt.com/ my local Dinan supplier trinityautosport.com my local drug dealer for my crack habit
fastattackmotorsports.com because JColley!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #4 of 37 Old 3rd July 2016, 12:43 AM
LeeDan00
LeeDan00's Avatar
Nice numbers and there's quite a few people out there with Jim's tune now. I know Randy just flashed his this weekend and letting the car adapt as well. He just text me saying this his shifts are faster and smoother! I imagine your numbers may be slightly better once the car adapts..It's these new things that keep our cars relative to time.
Dan
ESS VT2-650 Supercharger with Intercooler
ESS Alpha N Tune
Vortech BOV vta to replace the stock recirculating one (OMG loud!)
Rod bearings changed 8/10/15 at 88k miles
Dinan sections 1 - 3. Straight pipe 4'' "loudest" version Dinan offers. (Sounds amazing at WOT)
Secondary cats and resonator removed
KWv3
Flat bottom steering wheel all leather with M stitching
RPi SV1 Oil Cooler in silver
RD Sway Bars
Brembo BBK 405/380mm in factory yellow
Dinan Monoballs
Hardwired V1
CF hood by Seibon. E9x style with hood bump and functional vents
CF Hamann front lip
CF rear diffuser
CF trunk lid from member Socale39
ZHP shift knob
HRE 545 custom built with tri-step-lip
HRE P40 with MPSS
Custom built headlights by Evan with fx-r projectors and Orion v2's and full blackout
Gloss black kidneys and side vents
Gloss black M5 badge
Gloss black ESS badge
LCI tails with special brake effect done by Simon aka BCD
LED front, side, and license plate
Dyno'd 598wrhp and 413tq on Dynojet 10/29/15 on stock headers
LeeDan00 is offline
post #5 of 37 Old 3rd July 2016, 12:44 AM Thread Starter
torque
torque's Avatar
My only mod is the agency power pulley, and removal of carbon filters... that's it. Octane 93 optimized map.
torque is offline
post #6 of 37 Old 3rd July 2016, 01:00 AM
m5 guy
m5 guy's Avatar
Very nice! Do you plan on going back after the adaptation period? Also how much more responsive is it in your opinion? For me response and smoothness is more important than power so I'm curious about these two points. Thanks!
2016 F10 M5 Space Gray-Black
2010 E60 M5 Saphire Black-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
m5 guy is online now
post #7 of 37 Old 3rd July 2016, 01:15 AM
Fiftytwoeighty
Nice.
Jim set me with a 91 tune and 100 tune. Can't wait to find the time to load it.
I know my neighbors will appreciate the cold start delete .
~Woody
~I FRACKING!
~Viva La Wolfpack!
post #8 of 37 Old 3rd July 2016, 02:05 AM Thread Starter
torque
torque's Avatar
I can tell you that you will feel that torque so the car feels much more responsive to throttle input. As i said it also seems to respond quicker on p400 mode, so i like it... If this was a turbo i would say the lag is reduced :-)
Sent from my SM-N910V using Tapatalk
torque is offline
post #9 of 37 Old 3rd July 2016, 03:08 AM
JGINWS
JGINWS's Avatar
I haven't even had time to flash original tune back from Eurocharged to send mine off to Jim
Just dropped her off today to get all the new clutch pieces installed, should be back close of business on Tuesday - hopefully his week I can get it flashed, read and sent off to Jim.
Like others, I have a good list of bolt-on mods that we should be able to see some good power gains from-
JGINWS is online now
post #10 of 37 Old 3rd July 2016, 04:06 AM
Mcc420
Mcc420's Avatar
I'm also running his tune and I couldn't be more happier. I didn't think I would feel that much of a difference over my last tune but I was wrong the whole car runs smoother from idle on. This is my fourth tune by the way and I'll get it dyno'd like the last ones. The car evens sounds different. Good job Jim
Mcc420 is offline
Fast Attack Motorsports S85 Performance Tuning jcolley M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 26 26th October 2016 03:15 AM
Trouble contacting Fast Attack Motorsports? Minimization E60 M5 and E61 M5 Touring Discussion 18 27th June 2016 03:54 AM
///Fast Attack Motorsports - VDO S85 Throttle Actuators jcolley M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 5 16th June 2016 11:16 PM
Tune, fast attack vs Evolve vs jaws M6sweden E60 M5 and E61 M5 Touring Discussion 12 27th May 2016 09:18 PM
Old and Busted Jailbreak Tune Dyno Results (dyno graph and vid) Bayou E39 M5 and E52 Z8 Discussion 41 3rd September 2013 05:40 AM
