Trouble contacting Fast Attack Motorsports? - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 19 Old 6th June 2016, 09:15 PM Thread Starter
Minimization
Minimization's Avatar
Hi,
Just curious. I know Jim in ME is just starting up and must be super busy, but I am having a hard time connecting with them (Fast Attack Motorsports) at all. I need to find out about what rod bearing parts to order and their availability. Funding and a shop are already lined up. I want to do BE bearings/bolts with an update of everything else that makes sense. Hopefully this motor won't blow in the meantime! :-O
Thanks!
2006 BMW M5 Sedan
SMG III/Silverstone Metallic/Black Perforated Merino/Aluminum/Anthracite Alcantara
X2/4MA/610/322/453/655/416/465/261/496
Dynamic Performance Engineering Monoblock ST7 Brushed Aluminum; 20 x 9.0", 20 x 11.0"
Michelin Pilot Super Sport; 265/35ZR-20, 295/30ZR-20 | H&R Trak+ 12 mm, 5 mm
Pirelli Winter 240 Sottozero;
255/40VR-19, 285/35VR-19
Thule K-Summit K44|LED 5 W 6,000 K 350 lm angel eyes|LED license plate lights
Valentine 1 hard-wired with Remote Display
Minimization is offline
post #2 of 19 Old 6th June 2016, 09:23 PM
gmak
He is really busy. Took quite a number of days to answer a PM and still haven't got an answer to "contact us" missives. I guess the key is patience and give him a chance to get caught up. Besides the BE bearins aren't available anywhere until July (?), no?
gmak is offline
The Following 2 Users Say Thank You to gmak For This Useful Post:
Minimization (6th June 2016)
post #3 of 19 Old 6th June 2016, 09:23 PM
Mark@Evolve is offline
The Following 2 Users Say Thank You to Mark@Evolve For This Useful Post:
post #4 of 19 Old 6th June 2016, 09:26 PM Thread Starter
Minimization
Yes, I have mailed him directly a couple of times. I know about the July back order but I want to get all of the orders prepped and ready to go before then.
2006 BMW M5 Sedan
post #5 of 19 Old 6th June 2016, 09:42 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Hey guys. I've been spending a lot of time tuning a 6.0L stroker for @Troy jeup, so not a lot of time to spare. Having said that, I'm pretty busy but not too busy to get back to emails.
I'm not sure what's going on, but I seem to have emails disappearing and I think it's related to getting them on multiple devices. For some reason when I read them on my phone, they're gone forever and I can't reply to them from my laptop or desktop.
As for the BE bearings, I inquired directly with them today instead of the distributor and still don't have a firm date. I'm really not sure what to say, it's certainly holding me up on a few projects. I do need to update the website to reflect that.
As for messaging here on the forum, my box gets about 50 a day for random questions and troubleshooting, so it gets hard to make it through them. I always say that's why email is the best method, but apparently not the case.
Thanks for the heads up on this @Mark@Evolve , will try and get to emails this afternoon after I get some overnight shipments out.
jcolley is offline
post #6 of 19 Old 6th June 2016, 11:47 PM Thread Starter
Minimization
Thanks Jim for letting us know! Would you post here once you hear back from BE about their S65/85 connecting rod bearings status?
My questions are these. I think I am going to order the following:
BE Bearings S85 set
BE Design ARP Rod Bolts - S85 set
S85 Rod Bearing Swap Parts Kit
S85 Oil Pump Chain Tensioner Pack
S85 VANOS Line Swap Parts Kit
S85 Oil Squirter Kit
Should I do these too while I am in there?
Front Main Seal (+$32.00)
Electric Oil Pump Seals (+$16.00)
Oil Sensor Seal O-ring (+$5.00)
Rear Main Seal (+$32.00)
Also, I keep hearing that "knocking" is a spun bearing. My valve train is noisy, but not sure if there is knocking or not. I do not want to invest anymore in this car if it needs bottom end work beyond the bearing situation. I figured the engine would be dead already if it has a real problem inside. Any thoughts?
2006 BMW M5 Sedan
post #7 of 19 Old 7th June 2016, 04:40 AM
jcolley
jcolley's Avatar
BE Bearings S85 set
Correct on the parts list. As for the last 4 items, I would only replace them if they are leaking, especially on the main seals. Very few people have the proper installation tools (I didn't until a few months ago) and often the seal outer bores get screwed up on removal. You don't need to remove the oil sensor or lateral electric oil pumps to do a bearing job either, so same applies for them.
As for knocking...if you question it...it isn't rod knock.
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
Minimization (7th June 2016)
post #8 of 19 Old 7th June 2016, 08:34 AM Thread Starter
Minimization
Thank you Jim!
I will put an order in soon, maybe wait on shipment until we know the BE timeline. If it turns out to be unknown, I may just go with stock bolts/bearings.
I'm going to order a throttle body actuator too.
Can you get me this part as well, by any chance?
Carrier, outside door handle, right, 51227191588
(Comfort Access is dead for rear passenger's side door)
2006 BMW M5 Sedan
post #9 of 19 Old 7th June 2016, 12:17 PM
gmak
Thank you Jim!
If he can't get the carrier outside door handle, there are a number of used ones around. I used one of them on my 530xi to replace a buggy comfort access module on the RHS rear. Not too bad a DIY and it cured the parasitic battery drain.
gmak is offline
Minimization (16th June 2016)
post #10 of 19 Old 7th June 2016, 04:55 PM
Bucky
Got the same on mine, just ordered one from ebay. Passenger front though.
Bucky is offline
The Following 2 Users Say Thank You to Bucky For This Useful Post:
///Fast Attack Motorsports - VDO S85 Throttle Actuators jcolley M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 5 16th June 2016 10:16 PM
Tune, fast attack vs Evolve vs jaws M6sweden E60 M5 and E61 M5 Touring Discussion 12 27th May 2016 08:18 PM
Contacting us Imran@evolve E39 M5 and E52 Z8 Discussion 1 11th December 2014 02:17 PM
Contacting BMWNA?? g9s8r E39 M5 and E52 Z8 Discussion 4 11th March 2008 04:57 AM
Contacting Hartge.....? MYM6ROCKS E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 19th July 2006 12:26 PM
