BMW S85 100% True Equal Length Stainless Steel Tubular Headers Information
Hello to All M5board members,
First post under this user name but one of thousands on this forum.
This is an introductory post with regards to a new header that will be coming to the market very soon.
As per the title, the product is a long tube header but with special focus on the equal primary pipe length across all cylinders.
At present there is only one header on the market which is close to equal length and it's one that costs nearly $8,000. A very competent design.
Having been involved in header development over the last 10 years and supplying many M5board members with previously worked on S85 headers, we decided to take the S85 header after market a little further.
Unequal length headers always have one downside which is the exhaust pulses are now unequal with respect to time.
This changes the exhaust note somewhat. Designs with short lengths which are very equal can give a 'V8' engine tone.
The closer you go to equal length but still well off and you begin to get a more of a 'Twin 5 Cylinder' or 'Off - Beat' 10 Cylinder sound.
This, to my surprise put many people off buying headers and it was clear that people wanted to retain the F1 Style V10 sound track which the original headers give which happen to be almost 100% equal length.
Also, you then have the power band. Equal length headers in theory can give a little more power at high rpm due to the exact pulse tuning which in turn creates a scavenging effect. However through experience we have seen the actual different in 'peak power' is very little and not worth noting. It depends form engine to engine but on high capacity BMW engines we found many times it made little difference to peak power.
However, there was a different through the rpm band where the equal length headers would deliver more torque. In dyno graph talk there is more are under the curve. In real world driving condition way better throttle response and torque/power in the lower and mid rpm's.
So without doubt, even if there is no tangible gain at peak power, if there is a gain where there is more power available in the most driven part of the RPM band then 100% equal length is well worth investing in especially as it will also meet the demands of those who want to retain the fantastic F1 style V10 noise.
The next ambition was to hit a price point which is gives actual value for money rather than charging a huge premium because it's a 'BMW M Power car'. In other words, we do not charge the BMW tax.
We use :
T304 16 gauge seamless Stainless Steel which is internally polished.
TIG weld (Argon gas purged) every joint.
CNC machined stainless steel flanges
So far we have achieved near enough 100% equal length. Both bank 1 and 2 cylinder are all within 1 inch of each other and that's very good going for a header this complex to fit into an area which is not very accommodating.
Pictures of the design will be posted with the development progress/jigs/tooling as soon as we finish the F1 style merge collector.
The layout is extremely compact with provision to access all of the header flange nuts, just like the original design. Some header designs are extremely difficult to fit due to lack of access to bolts. Having fitted many headers, this is a very very important aspect of the design. The last thing you want is to invite frustration for the fitter and make the product as easy to install as possible. Saves the end user labour time further economising the product as a whole with respect to total layout.
We already know the amount of stainless steel, materials which will be used and the welding time per pair of headers.
We calculated the production price very accurately based on experience and the prototype.
We WILL make this an outstanding product at a very very reasonable price. Let's just say south of $3000 and it will tick every box in every way. World class TIG welding / Build quality / Fitment with what everyone wants, 100% Equal length to retain the F1 sound and enhance torque at the lower-mid rpm's.
We are also already working on a CATTED version which does meet emissions and makes sure the emissions OBDII readiness checks are passed.
DME tuning is something that many people on this forum and many forums alike have benefited from us through another past venture.
At this point we cannot give out company contact information as we would first like to sponsor the forum and not upset the current sponsors.
Once we give out information it automatically generates interest and we get free advertising which is used which irritating for the previous position.
Thanks for Reading and we will continue to update this thread.
Pictures will follow soon and it will all start getting much more interesting. There will be independent testing done most likely by one of the M5board members.
We use :
