OEM Sway Bar options? - BMW M5 Forum and M6 Forums
 10Likes
post #1 of 37 Old 8th September 2015, 07:33 AM Thread Starter
beastpilot
I'm looking to upgrade the sways on my E60 M5.
It appears the best options are the RD Sways, but they are both expensive, and have a somewhat iffy quality reputation.
As far as I can tell, the RD sways offer the following stiffness increases:
Front: +13%, +29%, +45%
Rear: +40%, +68%, +119%
I hear most people run the fronts in the middle and the rears full stiff or middle stiff.
The front M5 sway is 26.5mm and the rear is 18mm. Thus, to hit +29% and +119% would need a 28.25mm front and a 21.9mm rear.
I'm thinking of going with the M6 front bar which is 28mm, and the Dinan rear which is 21mm. This should give me +25% in the front and +85% in the rear. I could go +43% in the front also via the M6 competition package bar.
Anyone tried anything like this?
beastpilot is offline
The Following User Says Thank You to beastpilot For This Useful Post:
22b (15th May 2016)
post #2 of 37 Old 8th September 2015, 08:00 AM
drewTT
I wouldn't mix and match. I would go with something specifically designed for the M5. I like the Dinan option with the rear sway/FRC.
2008 M5 SMG
drewTT is offline
post #3 of 37 Old 8th September 2015, 08:58 AM
Niart906
Niart906's Avatar
I like Dinan's setup, but I wish they made a front bar that was adjustable. Their FRC is not adjustable.
RDsport sway bars seem to be the only option for a fully adjustable setup. I just can't justify spending the money on them when their quality seems to be hit or miss at best.
2006 E60 M5 Silbergrau Metallic/Indianapolis Red
Niart906 is offline
post #4 of 37 Old 8th September 2015, 09:00 AM
LeeDan00
LeeDan00's Avatar
RD Sways are the only aftermarket sways for our cars that are fully adjustable. And yes, quality is really hit or miss. I have a set of brand new RD Sways if you're interested. PM me.
Dan
ESS VT2-650 Supercharger with Intercooler
ESS Alpha N Tune
Vortech BOV vta to replace the stock recirculating one (OMG loud!)
Rod bearings changed 8/10/15 at 88k miles
Dinan sections 1 - 3. Straight pipe 4'' "loudest" version Dinan offers. (Sounds amazing at WOT)
Secondary cats and resonator removed
KWv3
Flat bottom steering wheel all leather with M stitching
RPi SV1 Oil Cooler in silver
RD Sway Bars
Brembo BBK 405/380mm in factory yellow
Dinan Monoballs
Hardwired V1
CF hood by Seibon. E9x style with hood bump and functional vents
CF Hamann front lip
CF rear diffuser
CF trunk lid from member Socale39
ZHP shift knob
HRE 545 custom built with tri-step-lip
HRE P40 with MPSS
Custom built headlights by Evan with fx-r projectors and Orion v2's and full blackout
Gloss black kidneys and side vents
Gloss black M5 badge
Gloss black ESS badge
LCI tails with special brake effect done by Simon aka BCD
LED front, side, and license plate
Dyno'd 598wrhp and 413tq on Dynojet 10/29/15 on stock headers
LeeDan00 is offline
post #5 of 37 Old 8th September 2015, 01:09 PM
Mcc420
Mcc420's Avatar
Mcc420 is offline
post #6 of 37 Old 8th September 2015, 04:46 PM Thread Starter
beastpilot
Got it, go with a specifically designed option like the RDSport which allows 9 different settings, or the Dinan which allows 3
post #7 of 37 Old 8th September 2015, 04:55 PM Thread Starter
beastpilot
To post my research on what is available OEM:
Front:
26.5mm - E60 M5 Stock - 31352283070
28 mm - E61 / E63 - 31352282790
29 mm - E61 Competition / E64 - 31352283123
Rear:
18 mm - E60 / E63 - 33552283072
19 mm - E61 Competition - 33552283908
20 mm - E61/E64 - 33552283036
The Following 2 Users Say Thank You to beastpilot For This Useful Post:
FastHackem (9th September 2015)
post #8 of 37 Old 8th September 2015, 05:09 PM
Bucky
Front:
Rear:
Assuming they are all the same material/hardness and have the same wall thickness.
Bucky is offline
post #9 of 37 Old 8th September 2015, 05:10 PM Thread Starter
beastpilot
Originally Posted by Mcc420 View Post
I put on e61 front and rears which is the same as a m6 vert.
E61 uses 28/20 while the E64 uses 29/20.
post #10 of 37 Old 8th September 2015, 07:54 PM Thread Starter
beastpilot
All of the BMW bars are solid, and it's hard to imagine they vary the material usage across these bars when the diameters make perfect sense in going up in size for heavier or or more aggressively targeted cars.
ticat928 (10th September 2015)
E39 M5 Sway Bar Options & End Links... iconoclast E39 M5 and E52 Z8 Discussion 2 24th August 2015 03:46 PM
E39 For Sale: Eibach 18mm Rear Sway Bar with BeastPower Sway Bar Brackets Clemster Parts / Other For Sale or Wanted 7 16th May 2014 02:24 PM
E39 For Sale: E39 M5 OEM rear sway bar w/Dinan bushings and OEM brackets KingJaffeJoffer Parts / Other For Sale or Wanted 5 17th September 2013 03:53 PM
E39 For Sale: S62 OEM Headers and M5 OEM Sway Bar havasusteve03Beast Parts / Other For Sale or Wanted 4 27th January 2010 05:37 AM
Rear Sway Bar Replacement Options Stone///M5 E39 M5 and E52 Z8 Discussion 10 17th April 2008 06:06 PM
