Does anybody know if the install program from Evolve will work with windows 10, would like to find out before i purchase the tune just upgraded my laptop to 10, and i cant find a legit tuner that deals with them and is not going to try and steal my tune and sell it off .:nerd
Tested with Windows 10 Pro 64bit. The latest Evolve software installs fine but Windows 10 will not accept the driver for the cable. I'm sure there is a workaround, just need to figure it out.
Interesting. We purchased a brand new windows 10 machine and it works without any issues. Can you please uninstall and reinstall. If you have anymore issues please send me a pm
thanks Mark! just what i needed to hear, going with the RPI GTS-GT Full exhaust system minus the headers need it to pass inspection, also have AFE drop in air filters, minus the charcoal filter removal, will i need a special tune or is the standard tune good enough?:grin
Dimm,i hear you on that! trying to get all my ducks in a row,best parts, performance, and pricing! this car takes cash to build, so i would like to do it right the first time, without any bugs or drama in the future. this is why i try and accumulate as much info from various sources, so as to make a better judgment call on all future purchases that i do....:grin
The driver installation issue on 64bit Win10 has been resolved. For 64bit, you must disable Driver Signature Enforcement which prevents the installation of unsigned drivers.
1. Open a Command Prompt with admin privileges.
- Windows key + X and then select “Command Prompt (Admin)”.
2. Type in the following command and press Enter. bcdedit /set testsigning on
- You should receive “The operation completed successfully” message.
3.Close the Command Prompt and restart your computer.
- From now on, you will be able to install or run any unsigned driver without problems.
4. Connect Evolve-R cable & install Evolve software
If you need to enable the Driver Signature Enforcement again, run this command: bcdedit /set testsigning off
125.8K members
