Let's talk DCT conversion - Page 7 - BMW M5 Forum and M6 Forums
 62Likes
post #61 of 202 Old 18th June 2015, 01:20 AM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Originally Posted by CHARIOT View Post
What business does the SZL have with the DKG I wonder?
EDIT: Dumb question....steering position.
Precisely.
Here's some brilliant work on the E84. I found the vast majority of E60 to be identical. This structure should give some frame of reference for the PT-CAN.
http://www.loopybunny.co.uk/CarPC/k_can.html
Already ordered wire taps so I'll be the guinea pig.
Since the byte string begins with the ArbID, all messages in a string come from a single component. First step is to identify ArbIDs then break the structure down.
jcolley is online now
post #62 of 202 Old 18th June 2015, 01:35 AM Thread Starter
CHARIOT
All jobs required for DCT calibration/adjustment can be executed via tool32 at the absolute minimum. Toolset can access and control a module with a direct connection without relying on the rest of the car. Worst case scenario we will need to individually run the jobs without a fancy GUI like ISTA provides, but it will work. If we can make it work in toolset, we can make it work in INPA too. Technically, you could modify the VCM info or manually create a connection with ISTA and just give it e9x info for connection instead of the E60 info. If the physical wires are there, its just a matter of making everyone talk.
Physical plumbing of the air/oil cooler should be straight forward as well as a t-tap into the hot & cold side of the coolant system in the M5
I'd venture a guess and say that those signal ID's are uniform across the model range for at least the generic signals like RPM, VSS, brake signals, etc. Changing signal identities would call for complete reprogramming of the communication system as we know it.
CHARIOT is offline
post #63 of 202 Old 18th June 2015, 01:39 AM
jcolley
jcolley's Avatar
That's kind of what I was thinking. All the actual calibration routines are built into the firmware of the modules themselves, so it's just a matter of getting EDIABAS to send the correct commands to the correct module.
I build a custom .IPS at one point to poke around the SMG a bit. I would think building an .IPS for DCT should be achievable as well, even with the graphics. As you said though, should be able to access it via the E9x menus.
post #64 of 202 Old 18th June 2015, 01:45 AM Thread Starter
CHARIOT
Another thing to note....judging by the block diagram, PT_CAN is not directly wired from DKG to the OBD port - it goes through the Junction box. Were going to need a JB to be able to talk to DKG. D_CAN is the roadway to the JB, from there, JB puts you onto the PT_CAN - which means we will no longer need to trick ediabas into thinking hes talking to a e9x. We will simply wire a 2nd OBD port to the JBBF, from there ISTA will know what it what to look for depending what is on the bus.
CHARIOT is offline
post #65 of 202 Old 18th June 2015, 02:05 AM
jcolley
jcolley's Avatar
Is this the "footwell module" on the E9x or a similar module to KGM? OBD to KGM is the path for us to SMG via PT-CAN, correct?
post #66 of 202 Old 18th June 2015, 02:26 AM Thread Starter
CHARIOT
Technically it's the fuse panel electronics but it looks like it's serving as a pass through for CAN communication. If you look at the PT_CAN schematic, everything on PT is behind the JB.
CHARIOT is offline
post #67 of 202 Old 18th June 2015, 02:42 AM
jcolley
jcolley's Avatar
post #68 of 202 Old 18th June 2015, 02:52 AM Thread Starter
CHARIOT
Connection is not shown from DCAN to PT CAN. Either its controlled by the JB with transistors (likely) or it has constant continuity (unlikely). we need someone to do a continuity check from pins 1, 2, 33, & 17 to see if we will need a JB or not. If its simply a bridged connection we can omit the JB for a simple piece of wire.
CHARIOT is offline
post #69 of 202 Old 18th June 2015, 03:03 AM
5soko
5soko's Avatar
I love all the work from you guys and information! Amazing
2009 ///M5
Evolve Alpha-N Stage 2 Flash Tune | Eventuri Intake Kit | Supersprint Full F1 70MM-Xpipe-Catless
OEM Alcantara tri-stitch steering wheel|LUX H8 160 Angel eyes|Osram CBI's
IND Black Gloss Fender Vents|IND Painted Side Markers
Satin Black OEM wheels |Michelin PSS |30% Tint|LED License Plate lights
BMW Performance Grills|Full OEM BMW LED Interior + Trunk
Oem M projection Door lights|US Mill Work Tow plate|OEM M Floor Mats|Coding
5soko is offline
post #70 of 202 Old 18th June 2015, 05:50 AM
ACG
ACG's Avatar
Just dropping in to see how the progress is going
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights
Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions.
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / HUD/ Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, black on black
ACG is offline
All this talk johnbmw6 F10 M5 Discussion 22 19th February 2012 05:47 PM
Video: BMW M3 DKG | DCT vs BMW M3 Convertible DKG | DCT 50-250 km/h Gustav E60 M5 and E61 M5 Touring Discussion 2 11th August 2008 06:39 PM
Video: BMW M3 DKG | DCT vs BMW M3 Convertible DKG | DCT 50-250 km/h Gustav E39 M5 and E52 Z8 Discussion 1 11th August 2008 03:40 PM
Talk me into one please! 20C4S E60 M5 and E61 M5 Touring Discussion 22 22nd January 2006 09:22 PM
I need somebody to talk some sense into me! Filthy Monkey GTBoard.com: General Sportscars 38 23rd December 2005 10:23 AM
