Let's talk DCT conversion - Page 6 - BMW M5 Forum and M6 Forums
 62Likes
post #51 of 202 Old 15th June 2015, 04:28 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Originally Posted by Donald-M5 View Post
Gintani Has done this on there 1500whp E63 M6!!!
As far as any real evidence has surfaced, Gintani is *planning* to do this on Tamirlan's M6 TT build. Along with a bunch of other dreamy cool stuff that seems above and beyond at this point. Not downplaying their ability by any means, but so far I haven't seen anything besides renderings and prototype pictures.
jcolley is online now
The Following User Says Thank You to jcolley For This Useful Post:
Hasan Shaikh (16th June 2015)
post #52 of 202 Old 15th June 2015, 11:51 PM
MarkieM5
MarkieM5's Avatar
MarkieM5 is offline
post #53 of 202 Old 15th June 2015, 11:57 PM
ACG
ACG's Avatar
Nicely said Jim.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights
Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions.
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / HUD/ Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, black on black
ACG is offline
The Following User Says Thank You to ACG For This Useful Post:
post #54 of 202 Old 16th June 2015, 05:14 AM
rt7085
rt7085's Avatar
Originally Posted by CHARIOT View Post
OK, I cut off all CAN comm between smg and DME and here's what I have:
0x2b57 emergencyprogram started
0xcdc3 smg can message 3 missing
0xcdc1 smg can message 1 missing
0xcdc2 smg can message 2 missing
for dme
0xcf0b local can bus OFF
0xcf27 message dme 3 missing
0xcf2a message motor data missing
0xcf2b message m-drive status missing
for smg
Unfortunately the faults don't say exactly what the messages are specifically. I'll have to look them up in ZEDIS and see exactly which messages they are....
Does anyone have a coding trace from DME? Then we could see if the L_CAN messages can be toggled to the PT_CAN like in the KOMBI.
Disconnecting the PTCAN leads to errors as they are likely going through a handshake init procedure first. You need to leave them connected and use a CAN sniffer to capture all the back and forward data.
Sent from AutoGuide.com Free App
rt7085 is offline
post #55 of 202 Old 16th June 2015, 05:54 AM
jcolley
jcolley's Avatar
Sniffer is all set, just trying to determine a non-intrusive yet easy to access point to tap the wiring.
post #56 of 202 Old 16th June 2015, 12:28 PM
rt7085
rt7085's Avatar
That is always the issue. They have the special removable wire piercing clamps that drives a thin needle through the wire insulation. Then you just clip to the contacts and remove them when you are done. Non intrusive and removable. Worthwhile investment when you do this often:
They are a bit expensive but you will have to shop around a bit to find the best price somewhere. I found these on Digikey but they are sold elsewhere and there are alternate brands available.
6405/POM Pomona Electronics | 501-1477-ND | DigiKey
rt7085 is offline
post #57 of 202 Old 18th June 2015, 12:39 AM Thread Starter
CHARIOT
CAN sniffing will still be a tough venture as you will only see the structure of the messages, not their identities. We would need to start unplugging individual sensors to see what sensors correlate to which messages drop out. My initial thought of breaking the comm was thwarted by the fact that bmw has grouped these individual signals into "packages" on the CAN which adds a step of complexity. The identifier frames of the messages will obviously just be 1 or 0, but there will be a lot of manual work in matching the identifiers with what physical signal (sensor) they represent.
As far as tapping goes for tracing....at work we double crimp wire sets with a new terminal for all for all of our trace equipment. I highly advise against any cutting, poking or any other means of raw copper exposure which requires breaking the jacket of the wire.....
CHARIOT is offline
post #58 of 202 Old 18th June 2015, 01:12 AM
jcolley
jcolley's Avatar
I've been wanting to work on PT-CAN for something else anyway. Perhaps an engine harness, actuators, DME, DSC, and SMG on a test stand will be an easier start. Not running of course, but should allow some interpretation of handshakes, etc.
post #59 of 202 Old 18th June 2015, 01:13 AM
jcolley
jcolley's Avatar
What do you mean by packages? You mean multiple signals per byte string?
post #60 of 202 Old 18th June 2015, 01:13 AM Thread Starter
CHARIOT
What business does the SZL have with the DKG I wonder?
EDIT: Dumb question....steering position.
Precisely.
Message headers containing multiple identifiers in sets.
Example - "engine data", (0x2CFA) message is an identifier for all other engine related signals en mass.
CHARIOT is offline
All this talk johnbmw6 F10 M5 Discussion 22 19th February 2012 05:47 PM
Video: BMW M3 DKG | DCT vs BMW M3 Convertible DKG | DCT 50-250 km/h Gustav E60 M5 and E61 M5 Touring Discussion 2 11th August 2008 06:39 PM
Video: BMW M3 DKG | DCT vs BMW M3 Convertible DKG | DCT 50-250 km/h Gustav E39 M5 and E52 Z8 Discussion 1 11th August 2008 03:40 PM
Talk me into one please! 20C4S E60 M5 and E61 M5 Touring Discussion 22 22nd January 2006 09:22 PM
I need somebody to talk some sense into me! Filthy Monkey GTBoard.com: General Sportscars 38 23rd December 2005 10:23 AM
