Let's talk DCT conversion - Page 2 - BMW M5 Forum and M6 Forums
 62Likes
post #11 of 202 Old 14th June 2015, 02:41 AM
ACG
ACG's Avatar
Originally Posted by jcolley View Post
You ready to send me your car yet @ACG ?
I have been sitting here keeping quiet about this as I know of one shop which has been working on this for almost 2 years + and still do not have a working model to show. If it was as easy as it is listed on here then I would have hoped to see a working model by now, especially after this much time.
Jim if you think you can achieve this then I will happily send you my car
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights
Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions.
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / HUD/ Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, black on black
ACG is offline
post #12 of 202 Old 14th June 2015, 02:52 AM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Might lose a little top end...but it will be quick!
All the problems associated with rear end gearing changes on both the SMG and DCT are solved inside the DME. The speed table for the SMG (still labeled SMG even in the mss60) uses just that...wheel speed. But not as read, but calculated by RPM from the selected gear and either CPS or layshaft sensor.
Just going to leave this here...
Name:  SMGvsDCT ratios.jpg
If you want to retain the stock total gear ratio, a shorter final drive gear is an option.
jcolley is online now
post #13 of 202 Old 14th June 2015, 02:57 AM
jcolley
jcolley's Avatar
While I'm just leaving things here...what's the point of using a stock DCT. Eventually, you're gonna want more power...
BimmerBoost
post #14 of 202 Old 14th June 2015, 02:57 AM
ACG
ACG's Avatar
don't mine losing a little top end, I can make up for that in other ways. Just let me know when it's a good time to take a drive down your way , I can always get a flight back via the company
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #15 of 202 Old 14th June 2015, 02:59 AM
jcolley
jcolley's Avatar
The software is the key. Having access to the internal of both the mss65 and mss60 helps. Maybe we can narrow down the differences and create our own.
post #16 of 202 Old 14th June 2015, 03:09 AM
ACG
ACG's Avatar
Jim that is a 5 year long thread, I am not going to read the entire thing lol
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #17 of 202 Old 14th June 2015, 03:12 AM
jcolley
jcolley's Avatar
don't mine losing a little top end, I can make up for that in other ways. Just let me know when it's a good time to take a drive down you way , I can always get a flight back via the company
You foot the bill for parts and I'll do the labor for free. Not kidding. Can't promise a timeline, but the wiring, mechanicals, installation is all easy for me to conceptualize and lay out. If we get the right people involved in this, the software will be the only challenge. @BrenTuning is a mere 60 miles away and tunes the SMG mapping inside the DME. By default, he would also know how to tune the DCT maps inside the mss60 as well, so could be a very helpful here.
CAN sniffing might come into play. Fortunately, I've done a little of that too.
post #18 of 202 Old 14th June 2015, 03:17 AM
ACG
ACG's Avatar
As long as we do not touch the tune for the actual SC then I think I can swing it. I do have a few upgrades going on in the next month with ESS to boost the power level so maybe we should touch bases offline and get down to some figures of actual cost of parts and such. Just need a ball park figure to get a better understanding of this project. Don't worry about the timeline, I will not create a gantt chart to track this one haha!!
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #19 of 202 Old 14th June 2015, 03:28 AM
jcolley
jcolley's Avatar
...I will not create a gantt chart to track this one...
Um...I will...
It's how my brain works these days.
post #20 of 202 Old 14th June 2015, 03:32 AM
ACG
ACG's Avatar
Um...I will...
Unfortunately mine does also especially now that I am in charge of 3 divisions at my company
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
All this talk johnbmw6 F10 M5 Discussion 22 19th February 2012 06:47 PM
Video: BMW M3 DKG | DCT vs BMW M3 Convertible DKG | DCT 50-250 km/h Gustav E60 M5 and E61 M5 Touring Discussion 2 11th August 2008 07:39 PM
Video: BMW M3 DKG | DCT vs BMW M3 Convertible DKG | DCT 50-250 km/h Gustav E39 M5 and E52 Z8 Discussion 1 11th August 2008 04:40 PM
Talk me into one please! 20C4S E60 M5 and E61 M5 Touring Discussion 22 22nd January 2006 10:22 PM
I need somebody to talk some sense into me! Filthy Monkey GTBoard.com: General Sportscars 38 23rd December 2005 11:23 AM
