15th September 2004, 11:35
#1 (permalink)
Auto Motor Sport Road-Test
Auto Motor Sport tested the new M5. It was published this morning. For German-speakers, I could scan & upload it, if you want. The main points were:
- no negative points, except consumption
- the best overall performance package ever
- perfect engine, very low noise in the interior, loud and aggressive from outside
- perfect transmisson, the fastest gearbox ever seen
- extremely fast accelerating, even more extreme at 180+ (km/h)
- extreme brake-force, even at many highspeed-stops, no fading
- consumtion was about 15 l/100km
Now, Its Here:
<** max_m5 **> WE HAVE IT: THE NEW E60 M5.
15th September 2004, 11:38
#2 (permalink)
Re: Auto Motor Sport Road-Test
yes, please scan it. on that issue should be a test of the 535d too. could you scan that too? please
15th September 2004, 11:56
#3 (permalink)
I can't belive people who own a car with an large engine and complains about fuelconsumption, maybe because it's annoying to stop and refuel so often, but there can't be another reason for it.
15th September 2004, 12:04
#4 (permalink)
thats nice different impressions between most journals
15th September 2004, 12:43
#5 (permalink)
you are absolutely right. if the car needs 15l that is a lot, but 500hp and 1850kg is a lot too. and if you compare it to a golf (7-8l, 1250kg and 100hp) 15l is not much.
but why does the car only have a 70 litre tank? i don't see the reason for it. it is the same with the porsche turbo, which has a tiny 64 litre tank. unbelievable...
15th September 2004, 13:30
#6 (permalink)
Yes please scan test. I am very curious!
Thanks in advance.
15th September 2004, 14:10
#7 (permalink)
Weight my friend, they simply reason that refueling a little more often is a small price to save weight.
EDIT: 1850 kg  Is it really THAT heavy ?!?
15th September 2004, 14:15
#8 (permalink)
no fading,  contradicts the other test!  maybe the other test car had been given a rough old time  or they have different defintion of fade  ....lol
15th September 2004, 15:10
#9 (permalink)
just tryin' to scan it...
15th September 2004, 15:14
#10 (permalink)
Thanks.
15th September 2004, 16:12
#11 (permalink)
my scanner doesn't work. its an epson perfection 1250. the light can't be switched on anymore.
could any other member scan it in?
in the mean time, i'll search sb. here with a scanner...
15th September 2004, 16:20
