http://nelson.maxieuro.com/BMW_info....small_updates_
Here are some more details from the BMW M-Manager for sales an Orderprocessing in Europe, very kind man.
1) Fog Lamps
They needed to remove them for the cooling of the engine and the brakes.
2) Black inserts in the mirror
The black inserts in the mirror are only for decoration, but the mirror has specific function it will increase the ground effect of the car. That's why they have such a strange shape.
3) The seats
Even the seats have a special function when you are in track-mode and you take heavy turns the side of the seat will be insufflated (ex. when you take a right turn the left side of the seat will be insufflated that the driver and the passenger are better maintained in the seat).
4) M-Button
The specific M-Button in the steering wheel can be programmed individually with several functions like ex: POWER-Function with DSC off and the fastest SMG Mode or or or.
5) SMG
The SMG has the same functions like the well known "old" Smg (Launch-Control and others). New is only that when you are in the manually position Kick-down and the car will shift down one or two gears by itself to overtake. A manual gearbox will not be available.
6) The Power-Button
The Power funtion P500 must be activated by yourself every time you start the car. Comment: This is not to preserve the engine but for the city there is no need for 507 Hp.
7) Official presentation
The official presentation will be at the Mondial de l'automobile in Paris from september 25 to october 10.
If possible I try to be invited to the press presentation in late september for a test drive.
8) Official specs
The official 0-100, 0-200 and V-max are not confirmed by BMW and aren't quite concluded. For the moment they have disscussion about the V-Max (250, 280 or even removing the speed limiter).
His opinion was that the car will be limited again to 250 but he says that it will be as easy like "always" to remove the V-max.
After I said that I've read somethin about 328 km/h, he started laughing and said that this is an easy take for the car.
9) The delivery
Delivery terms are by now late November 04 (Germany and +/- The rest of Europe).
10) M6
For the M6 the car is planed for late spring 05 but it will "only" have 507 Hp not more. The car is quite more agile because of its weight and deeper center of gravity and that's "enough" progression.
For the Moment there will not be an M6 convertible or M6 Csl.
