Trigger relay or other accesories with M button - Page 3 - BMW M5 Forum and M6 Forums
 1Likes
post #21 of 25 Old 11th February 2017, 11:56 AM
Craze
Shouldnt it be parallel? And id bung a diode on the relay also as precaution
Craze is online now
post #22 of 25 Old 11th February 2017, 05:33 PM
kglover21
kglover21's Avatar
You're right, parallel and a protection diode is always a good shout.
I'll still be going CAN-BUS route as i'd like mine to function with the M button, not the power button as i tend to drive everywhere with the power button on, but then press M mode when i want to have some fun.
kglover21 is offline
post #23 of 25 Old 11th February 2017, 07:34 PM
CHARIOT
It depends on the resistance of the sport button LED. Either would really work. You CAN wire it paralell, but remember electricity favors the path of least resistance. My thought was a relay coil with ~10Ω or likely less of resistance will win vs. an LED which typically has high resistance since an LED internally is essentialy an air gap that curent flows over which produces the light.
CHARIOT is offline
post #24 of 25 Old 13th February 2017, 09:28 PM
jpw0809
jpw0809's Avatar
Thanks for tips guys. I have a couple of these laying around from when I did a PDC LED on my X5 to trigger my reverse camera.
Would this Relay be suitable?
OUAZ-SH-112L TE CONNECTIVITY, Signal Relay, SPDT, 12 VDC, 1 A, OUAZ Series, Through Hole | Farnell element14
jpw0809 is offline
post #25 of 25 Old 13th February 2017, 09:43 PM
Craze
It will work but id get something with lugs or socket unless you are putting on a pcb and in a box
Parralell will work, series will halve the voltage and probably wont operate your relay and dim the led
Dont forget a diode or relay with inbuilt led, that will also stop the voltage spike when the coils field collapses
Craze is online now
DME Fault 35 - Electronic Fan (Relay) - Auxiliary Fan Relay Not Working SleeperE39 E39 M5 and E52 Z8 Discussion 39 11th May 2015 09:00 AM
E39 For Sale: Will fit ALL style vehicles; Seltrab 16-row Oil cooler w/ accesories havasusteve03Beast Parts / Other For Sale or Wanted 2 21st January 2011 11:24 PM
Non-automotive: Push button starter (engine start button) from honda s2000 if lookz kill Parts / Other For Sale or Wanted 8 26th May 2010 10:58 AM
Genuine standard accesories for BMW B5 / B5S Alpina owners Gustav ALPINABoard.com | BMW Alpina Discussion 1 8th November 2008 12:01 AM
Need help with color combiations and/or accesories! GreekM5 E39 M5 and E52 Z8 Discussion 6 1st June 2001 11:33 PM
