Trigger relay or other accesories with M button - Page 2 - BMW M5 Forum and M6 Forums
 1Likes
post #11 of 25 Old 4th February 2017, 01:30 PM
pmalik
Originally Posted by kglover21 View Post
It should actually be the opposite of this, listen on the CAN-BUS for the specific M Mode message and then use this to trigger an output to open exhaust valves or whatever you fancy. Listening to the bus wont upset it, unless you get bus speeds or termination wrong
Yeah, you don't wanna broadcast anything - just listen for the frame that has the right identifier and toggle your internal state on and off. I would hope they have two frames, one of with on and one with off so none of the modules listening would get out of sync*.
* canbus isn't reliable multicast last i checked, so you'd expect all the frames to be state-explicit (M mode on, M mode off rather than M mode toggle).
Also it's pretty amusing that every m-car forum has a huge engineer userbase.
pmalik is online now
post #12 of 25 Old 4th February 2017, 01:31 PM
rt7085
rt7085's Avatar
Oh. Well that is super easy with an Arduino or the like. In fact I just built a contraption like that for my own exhaust.
rt7085 is offline
post #13 of 25 Old 4th February 2017, 01:35 PM
rt7085
rt7085's Avatar
Trigger relay or other accesories with M button-imageuploadedbyautoguide1486211579.048637.jpg
This thing listens (and talks) on CAN to throttle input, RPM and speed, measures actual vacuum pump negative pressure for actuating the exhaust valves, monitors pump temperature, activates and deactivates the pump via a relay. I slapped a display on it because I could. Adding the M button is trivial. Let me know if you need help.
rt7085 is offline
post #14 of 25 Old 4th February 2017, 01:42 PM
pmalik
What do you actually use for the exhaust valves? The electric stepper motor ones won't last more than couple months with that duty cycle. OEMs all do spring loaded vacuum ones (I had an S8 with that setup), thought i haven't seen any aftermarket ones.
post #15 of 25 Old 4th February 2017, 01:54 PM
rt7085
rt7085's Avatar
I have a Frequency Intelligent exhaust with vacuum valves. That is the way to go. I bought a separate vac pump (Hella PU-28) which is the same as the pump in our cars. It makes -1 bar. The problem is that these pumps draw 120W (10A) and get hot when they run too long. I have it tucked away under the trunk liner for noise. I tried it the simple way with a vacuum cut off relay and a pressure accumulator. But sometimes the pump would not shut off. So hence this extra stuff. Now I can monitor and control it safely. I could simply have run a vacuum hose to the engine vacuum. But I don't want to compromise that. Besides what fun would that be. LOL!
rt7085 is offline
post #16 of 25 Old 4th February 2017, 02:52 PM
pmalik
post #17 of 25 Old 4th February 2017, 03:11 PM
rt7085
rt7085's Avatar
Originally Posted by pmalik View Post
Hmm why not recycle one or two of the 335i exhaust valve pumps?
https://www.turnermotorsport.com/p-1...-exhaust-flap/
That is not a pump. That is a control valve. I have one of these as well. Different brand. But indeed, you collect vacuum in the accumulator and when you are ready, you release the vacuum into the exhaust actuators. You need a check valve between the pump and the accumulator to trap the vacuum. I found one on amazon for a couple of bucks. Get good silicone vacuum hoses. I found several grommet locations on the left and right sides of the truck bottom that were located right behind the bumper over the exhaust muffler locations to get out to the actuators.
rt7085 is offline
post #18 of 25 Old 5th February 2017, 02:31 AM
pmalik
Oh whoops, you're right the 335 cars have mechanical vacuum pumps.
post #19 of 25 Old 10th February 2017, 11:18 PM
jpw0809
jpw0809's Avatar
So I had a thought. The "Power" button on the gearknob surround has a little orange LED that comes on when in M mode.
I'm thinking what if I take the surround off and tap one of the wires going to the button. It must have a 12v positive feed that lights up the LED when active.
If I can find which wire it is and then I could tap it and run it to a small relay I could then use the trigger wire from that to feed the exhaust cut outs...
What do you guys think?
jpw0809 is offline
post #20 of 25 Old 10th February 2017, 11:31 PM
CHARIOT
Very good thought! That may just work to trigger the control side of a relay. Pin #1 on the power button gets 12v to turn on the LED, just make sure your relay is wired in series or the LED won't work anymore.
CHARIOT is offline
The Following 2 Users Say Thank You to CHARIOT For This Useful Post:
jpw0809 (20th February 2017)
DME Fault 35 - Electronic Fan (Relay) - Auxiliary Fan Relay Not Working SleeperE39 E39 M5 and E52 Z8 Discussion 39 11th May 2015 08:00 AM
E39 For Sale: Will fit ALL style vehicles; Seltrab 16-row Oil cooler w/ accesories havasusteve03Beast Parts / Other For Sale or Wanted 2 21st January 2011 10:24 PM
Non-automotive: Push button starter (engine start button) from honda s2000 if lookz kill Parts / Other For Sale or Wanted 8 26th May 2010 09:58 AM
Genuine standard accesories for BMW B5 / B5S Alpina owners Gustav ALPINABoard.com | BMW Alpina Discussion 1 7th November 2008 11:01 PM
Need help with color combiations and/or accesories! GreekM5 E39 M5 and E52 Z8 Discussion 6 1st June 2001 10:33 PM
