E39 M5 vs Dinan S2 vs E60 M5 power curves - Page 2 - BMW M5 Forum and M6 Forums
Old 28th June 2004, 15:04   #11
digger
Garage: .
Re: E39 M5 vs Dinan S2 vs E60 M5 power curves
How does the S2 compare to an e55 or RS6?
1700kg or below would help. The 545i is at 1640kg and the e39 m5 was about 40kg above e39 540i at 1790kg.
Cheers
digger is offline   Reply With Quote
Old 28th June 2004, 15:13   #12
bernhtp
Garage: M6 Convertible - Saphire Black, Portland Brown full merino, CF
Originally Posted by rsteele
I would personally prefer that the E60 had the power curves of the S2 engine.
I'm happier with the more powerful E60 engine that will go faster when I want it to. I'm not concerned with available power when the engine is loafing as I am not adverse to go from loafing to screaming when the occasion arises. The new SMG technology appears to accomodate this.
The E55 engine has more low-end grunt than the S2 engine but I don't want that one either. I like the direction and design philosophy of BMW M on this one.
Speaking of the S2, the results posted here do not appear representative of many others. I have seen lots of complaints on the E39 forum by those whose S2 dyno results fall short of Dinan claims. Between the enormous cost of the upgrade, the unclear performance increase, and the the indeterminate effects on a clutch-transmission already stressed on longevity, I passed on it.
Tom
bernhtp is offline   Reply With Quote
Old 28th June 2004, 15:14   #13
VladCanada
Guest
Garage: 500hp
Here's stock E55k dyno i found.
VladCanada is offline   Reply With Quote
Old 28th June 2004, 15:16   #14
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
That's power to the wheels on that dyno chart, so an assumption of drivetrain losses has to made to translate it to crank HP. In any event, that chart will be very hard to get numbers from due to the poor quality.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
2001 Audi S4 6MT -- it's back
1996 Volvo 850R wagon
CSBM5 is offline   Reply With Quote
Old 28th June 2004, 15:28   #15
VladCanada
Guest
Garage: 500hp
Also here's one from Mercedes site.
http://www.mercedes-benz.com/omb/amg...ch_data_06.htm
Old 28th June 2004, 15:40   #16
rsteele
rsteele's Avatar
Garage: 2006 Silverstone/Black E360 M5
Originally Posted by bernhtp
...Speaking of the S2, the results posted here do not appear representative of many others. I have seen lots of complaints on the E39 forum by those whose S2 dyno results fall short of Dinan claims. Between the enormous cost of the upgrade, the unclear performance increase, and the the indeterminate effects on a clutch-transmission already stressed on longevity, I passed on it.
Tom
...and I agree with you. I wouldn't do the S2 upgrade either. I was only expressing my fondness for the power curves, whether or not they are real or appropriate for the rest of the drivetrain.
Richard
rsteele is offline   Reply With Quote
Old 28th June 2004, 16:01   #17
CSBM5
CSBM5's Avatar
Dinan does a nice job evaluating how the M5 cuts back on ignition advance and enriches the mixture on the dyno when not supplied with enough cooling airflow. Given the high state of tune of the M5, BMW thankfully did a nice conservative design of the system. There are essentially no dyno setups that can provide the on-road conditions a radiator sees (i.e. large pressure differential from what is almost an infinite plenum condition in front of the radiator), but he appears to have created one that is close. I think the reasons he outlines in the white paper on dyno testing are responsible for people who have had disappointing dyno test results on their stock M5s even. Some then assume their car is "down on power" when in fact it is fine...it was just the poor test conditions that created the outcome.
That said, I agree. I'm not interested in the S2 conversion either, but if I did do it, I would definitely put in the UUC clutch I had a chance to experience last month. Also, from the looks of the power curve, snapping off the shifts on the 7spd SMG of the E60 and likely running between 6-8k rpm, the E60 M5 will leave the S2 behind nicely assuming the weight comparison is close. I think the power curve of the E60 shows exactly why the 7-spd is necessary and also why BMW isn't all that interested in a manual for the car. I can see the burnt clutches already from people slipping it like mad trying to obtain a fast start. Think of how tricky this car will be to launch for a max acceleration run -- you need to get "way up there" on the torque curve to get out of the hole hard.
Old 28th June 2004, 17:10   #18
fastsaloons
fastsaloons's Avatar
Garage: Mini Cooper S Works
I'm not sure the E60 M5 is going to work - It looks like a Civic Type-R power graph - torque is real late too - it maybe a little too specialist for most people...
As for the lack of manual I agree - anyone trying to extract the max will certainly be pushing it - Hopefully the E60 would get a proper clutch - but even so !
Not exactly an effortless cruiser - it'll be interesting to see how it pans out...
Neil
Drives:
ALPINA B8 4.6 Saloon
Mini Cooper S Works
Renault Grand Espace
Subaru Impreza Sti 4 (SOLD)
Le Mans Blue M5 (SOLD)
Black Alpina B10 3.3 (SOLD)
fastsaloons is offline   Reply With Quote
Old 28th June 2004, 17:43   #19
jos
Garage: BMW 725
Isn't it normal that an evolution of a car, which the E60 M5 is, has better performance,higher HP, and higher torque figures than the previous model. Anyway, the E60 will give a lot of cars a good run for their money, and I am looking forward to hear the high-revving V10.
"Wise men talk because they have something to say, idiots talk because they have to say something..."
jos is offline   Reply With Quote
Old 28th June 2004, 21:54   #20
CSBM5
CSBM5's Avatar
I pulled that chart into Photoshop and got the data from it also. I stuck it into these charts up above, but I'm not going to post the results as I don't think at this early point in the E60 M5's pre-life it is worth attempting to compare the two. Not until the final production information is available from BMW does it make sense to do much more with this subject imo. We may find that the above data is in error for the E60 M5 also (but you wouldn't think BMW would release that power curve if it wasn't relatively close to the production plan). One thing is clear though, in a roll-on run next to the W211 E55, you sure don't want to be caught one gear too high.
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 63 5th June 2012 22:00
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 00:11
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav E60 M5 and E61 M5 Touring Discussion 31 4th July 2004 21:23
Official press release: Engine / Drive System enots E60 M5 and E61 M5 Touring Discussion 9 24th June 2004 00:50
Excellent article on Dinan S2 M5 in Roundel! beanboy E39 M5 and E52 Z8 Discussion 26 11th August 2002 17:33
