Closed Thread
Old 23rd June 2004, 15:53   #1
enots
Garage: 2004 Mazda 3
Official press release: Engine / Drive System
Just recieved an email from BMW AU press club ... found these details very very interesting!!!
World Premiere of the New BMW M5’s Drive System Text & photos courtesy BMW AG
edited 06-23-2004
(Short story) Whenever BMW M GmbH presents a new M automobile, the focus of attention is traditionally on the power unit beneath the bonnet. This is particularly the case with the new M5: across the world, its V10 engine is considered to be one of the most fascinating drive concepts featured in a production car.
This technological masterpiece does not only sport the same number of cylinders as its Formula 1 BMW WilliamsF1 racing counterpart, but also shares its high-revving concept. As is the case with all high-performance normally aspirated engines made by BMW M, this power unit generates enormous pulling force over the entire speed range.
First high-revving V10 engine to be featured in a regular-production saloon
The V10 is the only high-revving power unit to be featured in a series-production car. The M5's engine has ten cylinders, a cubic capacity of 5 litres and produces a maximum output of 507 bhp and a maximum torque of 520 Newton metres, making the M5 the most powerful final production model in the BMW line-up. The segment of powerful sports saloons was introduced 20 years ago with the presentation of the first M5 and this new engine once again sets the benchmark in this particular segment.
There is, however, more to it than pure performance. What is important for M automobiles is acceleration and driving dynamics, the latter which is dependent on the actual forward thrust and the vehicle's weight. The drive forces at the driven wheels are significantly influenced by the engine torque and the transmission ratio. The high-revving concept caters for an optimum transmission ratio, thus guaranteeing an impressive forward thrust.
The perfect choice: high-revving concept
For the BMW M engineers the compact, high-revving normally aspirated engine was the ideal choice. With a red line of 8,250 rpm, the ten-cylinder engine has ventured into terrain which has so far been reserved for red-blooded racing cars. Compared to the previous M5 eight-cylinder engine, performance has increased by more than 25 per cent. The M5 has also surpassed the magical 100 bhp per litre limit, its specific output being on par with that of racing cars.
A masterpiece in engine construction
BMW, one of the leaders in engine construction, has made a name for itself primarily as a manufacturer of inline engines. The two five-cylinder banks of the V10 are arranged at an angle of 90¡ă to achieve a mass balance of the crankshaft drive, which is optimized for low vibration and increased comfort. For reasons of stiffness, that is due to the high loads resulting from combustion pressure, engine speed and vibrations, a bedplate design has been chosen for the crankcase. For an optimum alignment of the crankshaft, grey-cast iron inserts have been integrated into the aluminium bedplate, which also serve to enhance acoustics, increase vibrational comfort and ensure a high oil supply rate. The extremely stiff crankshaft is supported by six bearings. In the new M5, it is the first time that BMW has used a bedplate design for a production V engine.
Every gram counts in lightweight construction
The one-piece aluminium cylinder heads of the V10 engine are arranged in banks. The V10 power unit features four valves per cylinder, a layout which is typical of BMW engines. All valve train components are of low mass. Thus, for example, the M engines feature for the first time low-weight, flow-optimized 5 mm-shaft valves, spherical valve tappets with hydraulic valve play compensation and single valve springs. All this results in a considerable mass reduction, which is a prerequisite for the realisation of the high-revving concept.
High-pressure bi-VANOS for an optimum charge cycle
The bi-VANOS variable valve timing featured in the new M5 engine ensures an optimum charge cycle, thus helping to achieve extremely short adjustment times. This means in practice: increased performance, an improved torque curve, optimum responsiveness, lower consumption and fewer emissions. Thanks to the bi-VANOS technology, intake and outlet valves are always opened and closed at precisely the right moment.
Individual throttle butterflies help the engine to breathe freely
The naturally aspirated engine uses ten flow-optimized intake trumpets to "breathe in" air from two intake plenums. Each cylinder has its own throttle, a feature typical of racing cars. All throttles are actuated simultaneously and are electronically controlled in order to make the engine highly responsive in the lower speed range, as well as to achieve an immediate response of the vehicle at the high end of the performance spectrum.
Dual exhaust system made of stainless steel
The exhaust system of the new M5 engine is made of seamless stainless steel and has a dual-flow design all the way to the silencers. The exhaust gases finally leave the system through four tailpipes which are what make the rear end of the M vehicles so unmistakable. The exhaust system complies with the European EU4 and the US LEV2 emission standards.
The engine control module: the first of its kind in the world
The MS S65 engine management system is the central factor behind the V10's outstanding performance and emission data. With more than 1,000 individual components, this engine management system is unparalleled in its package density. Its processors are the most powerful ones which are currently approved for use in automobiles, as high engine speeds and comprehensive management and control tasks demand the utmost from this system. Receiving more than 50 input signals, this system calculates for each individual cylinder and for each individual cycle the optimum ignition point, the ideal cylinder fill, the injection quantity and the injection point. At the same time this system calculates and makes the necessary adjustments for the optimum camshaft angle and the optimum position of the ten individual throttles.
Highlight in engine management: ionic current technology
The ionic current technology featured by the engine management unit is a technological highlight which serves to detect engine knock, misfiring and combustion misses. Utilizing the spark plug in each cylinder, this system helps to pinpoint engine knock, to check for correct ignition and to detect any ignition misses. Thus the spark plug has a dual function - as an actuator for the ignition and as a sensor for monitoring the combustion process.
The ionic current measuring is done directly during the combustion process. The so-called ionic current satellite receives signals from the five spark plugs of each cylinder bank. Dependent on the load, it amplifies these signals and transmits them to the engine management system for analysis, which, for example, perfectly adjusts the ignition point of each cylinder via knock control to the combustion process. All this results in benefits for the driver of the new M5 ¨C lower fuel consumption, higher torque and enhanced performance.
Seven-speed SMG gearbox conveys M power to the tarmac
The high-revving concept only succeeds in combination with a gearbox which translates the torque available to the engine, by means of a short overall transmission ratio, into optimized forward thrust.
The seven-speed SMG gearbox is precisely the right transmission to ideally convey the V10 engine's power via the drive train to the wheels. BMW M is the first manufacturer worldwide to offer a seven-speed sequential gearbox with drivelogic function. Even more highly perfected than the previous six-speed transmission, the seven-speed SMG gearbox enables manual gear selection with ultra-short shifting times as well as comfortable cruising thanks to automatic gear selection. The purpose of the additional seventh gear is to reduce engine speed and torque gaps.
New SMG gearbox's speed up by 20 percent
With the seven-speed SMG gearbox, gears can be changed using the central gearshift lever or the so-called paddles on the steering wheel. Compared to the previous SMG transmission, changing gears is 20 per cent faster with the new SMG generation. Never before has it been quicker to change gears with a transmission of this kind. The advantage for the M5 driver: Gear change is smooth and ccomplished at a speed impossible to reach even by the most proficient driver, thus making the inevitable power flow interruptions when changing gears hardly noticeable. The M5 delivers an almost jerk-free performance when accelerating from a standstill to its top speed.
Drivelogic: the driver determines the SMG's characteristics for changing gears
Thanks to the SMG's drivelogic function, the driver can choose from eleven gear change options, which enable him to adapt the SMG's characteristics to his very own style of motoring.
Six of these programs can be preselected in the sequential manual gearbox mode (S mode), the spectrum ranging from balanced dynamic to very sporty. With the gearbox in the S mode, the driver always shifts gears manually. Whenever the driver activates the Launch Control function, the SMG Drivelogic shifts gears shortly before the maximum engine speed is reached at precisely the right moment and with optimum slip until the M5 reaches its top speed.
In the D (Drive) automatic gearshift mode, the transmission shifts the seven gears automatically, depending on the program selected, the driving situation, the road speed and the position of the accelerator pedal.
SMG for increased safety and comfort
The seven-speed SMG gearbox not only supports the driver in achieving motor sports performance, but also offers scores of safety features. In critical situations, when the driver shifts down on a slippery surface, for example, the gearbox opens the clutch in the fraction of a second in order to prevent the M5 from swerving out of control in the event of excessive drag torque at the driven wheels. Further functions are the climbing, which prevents the car from rolling backwards during hill starts as well as the hill detection, which adjusts the shift points on gradients and descents. This prevents gear hunting when going uphill. When driving downhill, the hill detection holds the lower gears for longer in order to make effective use of the engine's braking power.
Production of high-performance engines - engine production at its best
The high-performance power unit featured in the new BMW M5 reflects the engineering competence of the BMW engine construction specialists. The most powerful production engine in the company's history is manufactured along with other BMW special engines on a highly flexible production line at the BMW plant in Munich.
The wide selection of products requires very agile processes and demands the utmost flexibility, profound product knowledge and skilful craftsmanship from the qualified staff.
The most stringent quality standards are met in the mechanical production and assembly of the high-revving aggregate. As the materials and components of the high-revving engine are exposed to heavy loads, extremely high demands are placed on surface quality and production tolerances. Some parts and components are processed at a precision of up to one thousandth of a millimetre.
The coding of the core components enables the staff to keep track of each individual component from goods receipt to processing and through to installation. A storage medium is provided for each engine to ensure, by data transfer to the assembly stations, that the right parts and tools are used.
The heart of every BMW is its powerful engine. It is more than obvious that this particularly applies to the models made by BMW M GmbH. This description alone, however, would not do justice to the new engine in the M5: modestly put, this ten-cylinder power unit is a milestone in modern engine construction. It is one of the most fascinating engines the world over ever to be used in a series-production vehicle.
Some automobile aficionados also attach great importance to the sound of the engine. This is also the case with the V10: this technological masterpiece is to the sports vehicle aficionado what a symphony is to the ears of music lovers. Similarities to the sound of the BMW WilliamsF1 racing engine won't go unnoticed. The M5's V10 engine not only has got the same number of cylinders as its Formula 1 counterpart. Both engines also have the high-revving concept in common, a principle which generates enormous forward thrust from high engine speeds and is a characteristic of all high-performance, naturally aspirated BMW M GmbH engines. All this, in conjunction with the ten cylinders, results in an orchestra-like staccato, something that is normally only heard on the race track.
First high-revving V10 engine to be featured by a regular-production saloon
The new M5's high-revving V10, which has so far been reserved for racing cars and exotic low-volume cars, is the first engine of its kind to be used in a series-production saloon. In order to do justice to the exclusivity of the M family, this high-performance power unit offers a performance which is truly impressive: it has ten cylinders, displaces five litres, produces a maximum output of 507 bhp and a maximum torque of 520 Newton metres. Engine speed peaks at 8,250 rpm - a road-going athlete par excellence.
var DMdomain = ""; var DMpage = window.location; var DMVersion = 86; var DMsendTo = "//collector.deepmetrix.com/dm.gif?"; var DMsession; function dmerr(){return true;}window.onerror=dmerr; var u3k8u6y1j3 = new Date(); if (navigator.userAgent.indexOf('Mac') >= 0 && u3k8u6y1j3.getTimezoneOffset() >= 720){ u3k8u6y1j3.setTime (u3k8u6y1j3.getTime() - 1440*60*1000);} var u3k8u6y1 = location.protocol+DMsendTo+"v="+DMVersion+"&vst=1"; var u3k8u6 = document.cookie.toString();if(u3k8u6.indexOf("_dmid") == -1) {DMsession = parseInt( Math.random()*1000000 ) + "_" + u3k8u6y1j3.getTime(); var u3k8 = "";if(DMdomain != ""){u3k8 = "domain="+ DMdomain +";";} document.cookie = "_dmid=" + DMsession + ";expires=Mon, 31-Dec-2008 00:00:00 GMT;"+u3k8+"path=/;";} u3k8u6 = document.cookie.toString();if(u3k8u6.indexOf('_dmi d') == -1){DMsession = "";} else{if(u3k8u6.indexOf(';') == -1){u3k8u6 = u3k8u6.replace(/_dm/g, ';_dm');}var u3 = u3k8u6.indexOf("_dmid=") + 6; var g5b1z7i5z6 = u3k8u6.indexOf(";",u3);if (g5b1z7i5z6 == -1){g5b1z7i5z6 = u3k8u6.length;} DMsession = unescape(u3k8u6.substring(u3,g5b1z7i5z6));} u3k8u6y1 += "&id="+DMsession+"&url="+escape(DMpage) + "&ref="+escape(document.referrer)+"&lng=" + ((!document.all || navigator.userAgent.match('Opera')) ? navigator.language : navigator.userLanguage) + "&tz=" + (Math.round(new Date('dec 1, 2002').getTimezoneOffset()/60)*-1); if(screen){u3k8u6y1 += "&scr=" + escape( screen.width + "x" + screen.height + " " + screen.colorDepth + "bpp" );} u3k8u6y1 += "&rnd=" + new Date().getTime();if(document.layers){ document.write(""); }else{document.write("");}
view larger
BMW M5 V10 power chart / © GCF But there is more to the engine than just impressive performance data. At the slightest movement of the gas pedal, the high-revving normally aspirated engine reveals itself to be a typical sports engine. At the same time, it is perfectly suited for use in daily traffic. The M5 is a saloon for everyday use with the heart of an athlete ¡¡́C in other words, a roadworthy sports saloon. The M5 fully lives up to these two demands, opening up a new dimension of effortlessness. 20 years after the presentation of the first M5 marked the introduction of the segment of powerful sports saloons, this new engine once again points the way forward in this particular class.
Inspired by the Formula 1 engine
The engine was redesigned from scratch by the BMW M GmbH engineers. When constructing the power unit, the engineers drew inspiration from the BMW WilliamsF1 engine, which is generally regarded as the most powerful engine on the starting grid of the top echelon of motorsports. On the other hand, they transferred all M specific features from series-production automobiles, such as bi-VANOS, individual throttle butterflies and the most powerful engine electronics system currently available, an in-house development, as well as a traverse force regulated oil supply system.
In order to create a worthy successor of the previous M5, which features a 400 bhp V8 engine, it was essential to do one thing: to increase performance even further. In engine construction there are three possibilities for boosting performance: increase the cubic capacity and raise maximum torque in the process, boost performance by using a turbocharger or a compressor or use a high-revving concept to increase torque.
Power is more than increased horsepower
There is more to it than pure output. Acceleration behaviour and driving dynamics are further important aspects, which are greatly dependent on the actual forward thrust and the vehicle weight. The forward thrust at the driven wheels is a result of both torque and transmission ratio. The high-revving concept contributes greatly to an optimum transmission ratio, which, in turn, helps to unleash impressive drive forces.
When it comes to the laws of physics, the wheat is separated from the chaff, even if the engines under comparison are identical in output. If an engine's cubic capacity is increased, one has to put up with - for the benefit of high performance and torque - the problem of additional weight, more space required and higher fuel consumption. Supercharged engines also have drawbacks. Only rarely do they excel due to fuel economy and their spontaneity, i.e. the engine's ultra-fast response to the driver's inputs, fails to meet the high demands made of an M overall concept.
High-revving concept is the perfect solution
The third option, a compact, high-revving naturally aspirated engine, is the perfect answer. If only for the sake of tradition, for the BMW M engineers the following solution was the ideal choice: boosting performance by increasing torque. In this context it must be said that, from a technological viewpoint, the high-revving concept is far more sophisticated, so that it is much more difficult to put this concept into practice. After all, it is no coincidence that BMW's introduction of the new M5 has made them the first manufacturer worldwide to position a high-rpm V10 engine in the segment of powerful final production sports saloons.
Offering a maximum speed of 8,250 rpm, the ten-cylinder engine has ventured into terrain which has up to now been reserved for thoroughbred racing cars. By way of comparison: the previous M5's engine speed is electronically limited to 7,000 rpm. The new ten-cylinder powerplant has broken the 8,000 rpm barrier.
Formula 1 technology takes to the roads
With this new engine beneath the bonnet, the M5 redefines what is technologically feasible in the manufacture of series-production engines. The higher the torque, the closer the engine gets to its limits. The following comparison gives you an idea of the immense stress acting on the material: at 8,000 crankshaft revolutions per minute, each of the ten pistons covers a distance of approximately 20 metres per second. Coming back to the ten-cylinder engine in the BMW WilliamsF1: at 18,000 rpm, the pistons move as much as 25 metres per second. The difference is, however, that a Formula 1 racing engine only has to travel 800 kilometres in one racing weekend, whilst the M engine must last the lifetime of the vehicle, regardless of the climate, traffic situation and style of motoring.
It is evident that the M5 engine has various basic technological principles, production methods and materials in common with the Formula 1 engine and that it is based on technological transfer.
A 25 percent plus in performance - a new dimension of driving dynamics
The completely redesigned V10 engine, a high-revving ten-cylinder powerplant, is superior to its predecessor, which features 8 cylinders and the same cubic capacity, in all disciplines. Proof of this is provided by its performance which is up by more than 25 per cent. The new V10 engine produces a maximum output of 507 bhp (373 kW) at 7,750 rpm (maximum output of the V8 is 400 bhp - 294 kW - at 6,600 rpm). Weighing in at just 240 kilograms, the new ten-cylinder engine is almost identical in weight with its eight-cylinder forebear. Given its awe-inspiring performance, the new ten-cylinder engine is a real lightweight. However, the engine is a heavyweight when it comes to its output per litre: the ten-cylinder M5 exceeds the magical mark of 100 bhp per litre of cubic capacity, its specific output being on par with that of racing cars.
Engine speed has a major influence on performance and torque
As far as maximum torque (520 Newton metres) is concerned, the ten-cylinder matches the eight-cylinder power unit. Nevertheless, the new M5 beats its predecessor in all disciplines relating to driving dynamics. This phenomenon is also connected to the engine speed. A case in point: If a cyclist changes down when going uphill, he must pedal faster but he will master almost every gradient no matter how steep. If he does not change gears or if he even changes up, he needs a lot more energy or he has to get off the bike. If there are two cyclists with the same amount of stamina, it is always the cyclist who pedals faster that wins the race.
The logical consequence is that the new M5 with its high-revving engine also effortlessly outdoes all direct competitors who exclusively rely on the "torque concept" of an eight-cylinder engine with an increased cubic capacity. In addition, this engine's superiority can be put down to the fact that the concept-related extremely high torque of competing engines has to be transferred via a massively reinforced and heavy drive train - added weight and mass that must also be accelerated. Thanks to the V10's high-revving concept, a considerably lighter drive train can be used and closer gear ratios can be achieved.
By the way, the new M5 also outdoes its competition when it comes to torque: peak torque of 520 Newton metres is reached at 6,100 rpm, a torque of 450 Newton metres is already obtained at 3,500 rpm. And 80 per cent of maximum torque is available at up to 5,500 rpm, which is a wide speed range for an engine of this calibre. By way of comparison: the sporty and most powerful engine in the BMW 545i offers a maximum torque of 450 Newton metres.
Even superior to twelve-cylinder engine
The ten-cylinder engine is truly superior to its eight-cylinder competitors and, at the same time, does away with the design drawbacks of a twelve-cylinder powerplant, which, due to the number of components and the filling quantities, is larger in its dimensions and heavier than the compact ten-cylinder engine. Increased fuel economy due to lower frictional losses incurred by a reduced number of components is a further advantage of the ten-cylinder engine.
The new V10 therefore represents the perfect solution for a car such as the M5. In addition, the ten cylinders with a displacement of 500 cc each, fully live up to the ideals of the most discerning engineers.
Compact design for increased robustness and comfort
BMW, one of the leaders in engine construction, has made a name for itself primarily as a manufacturer of inline engines. When constructing the new ten-cylinder engine, the engineers arranged the two five-cylinder banks at an angle of 90 degree (V-configuration) with a 17 mm offset to create a compact aggregate. The 90 degree angle has been chosen due to its low-vibration and comfort-oriented mass balancing properties. In its geometry the engine solves the conflict between minimum vibrations and maximum component robustness.
The cylinder crankcases are cast utilizing the low-pressure gravity die casting method and are made of hypereutectic aluminium-silicon alloy. This special alloy contains at least 17 per cent silicon. The cylinder liners are created by precipitation of the hard silicon crystals. Additional liners are not necessary ¡¡́C the iron-coated pistons run up and down in the uncoated bores. Stroke is 75.2 mm, bore is 92 mm, overall cubic capacity amounts to 4,999 cc. By the way, the blocks for the M5 engines are cast at the same place as the Formula 1 engines: at the BMW light alloy foundry in Landshut.
Bedplate derived from racing technology
High engine speeds, high combustion pressures and high temperatures put an enormous strain on the crankcase. Therefore the engineers have chosen the so-called bedplate design, a compact and extremely stiff configuration which is derived from car racing. The new engine in the BMW M5 is the first series-production V engine to feature such a bedplate design. The aluminium bedplate with integral grey-cast iron inserts ensures high-precision crankshaft alignment, keeping the main bearing clearance over the entire operating temperature range at a minimum. The grey-cast iron inserts help to reduce the thermal expansion of the aluminium casing. To ensure positive coupling with the adjoining aluminium frame, the inserts have been provided with openings. At the same time, this architecture contributes to fulfilling the demands made of the M5's engine acoustics.
The extremely stiff and finely balanced crankshaft made of forged, high-tensile steel is supported by six bearings and weighs a mere 21.8 kilograms. It balances inertia forces and is designed for maximum torsional stiffness. The main bearing diameter measures 60 mm at a bearing width of 28.2 mm. Two con rods connect to each of the five crank pins, which are offset at an angle of 72 degrees. A reduced cylinder spacing of only 98 mm enables the use of a short crankshaft, thus resulting in high flexural strength and torsional stiffness, as well as a very low weight.
The weight-optimized pistons are made of high temperature resistant aluminium alloy and are provided with an iron coating. They weigh a mere 481.7 grams, including piston pins and rings. The compression height is 27.4 mm at a compression ratio of 12.0:1. The pistons are cooled using oil spray jets which are directly connected to the main oil duct. The 140.7 mm long, low-weight, fracture-split trapezoidal connecting rods are also made of high-strength steel and effectively reduce the oscillating masses. Each of the ten connecting rods forged from 70MnVS4 has a weight of only 623 grams, including the bearing shells.
The single-piece aluminium cylinder heads of the V10 engine are also produced at the BMW light alloy foundry in Landshut. The cylinder heads feature integrated air ducts for air injection which is important for rapid catalytic converter warm-up. The cylinder heads incorporate four valves per cylinder, a BMW specific engine architecture. The valves are actuated by spherical tappets featuring hydraulic valve play compensation. The tappet diameter has been reduced to 28 millimetres and its weight is down to 31 grams. Through optimisation of all parts and components of the valve train, the moving mass has been reduced by 17.5 per cent in comparison with the predecessor model. The diameter of the intake valve is 35 millimetres, the exhaust valve measures 30.5 millimetres in diameter. The shaft diameter is 5 millimetres.
Innovations with attention to the smallest detail reduce maintenance costs
The intake valves are exclusively manufactured for the M5 engine. With a reduced shaft measuring only 5 mm in diameter, there is hardly any impedance of the flow in the intake tract. Hydraulic valve play compensation units automatically provide for the optimum valve adjustment at all times, which is beneficial to the customer as it lowers maintenance costs.
The higher the engine output, the higher the need for cooling the engine, particularly in the vicinity of the combustion chamber. Compared to conventional systems, the crossflow cooling concept of the M5 engine considerably minimises pressure losses in the cooling system. It ensures an even temperature distribution in the cylinder head and the reduction of peak temperatures in critical areas of the cylinder head. Every single cylinder is evenly supplied with the optimum amount of coolant which flows from the crankcase at the outlet side through the cylinder head and via the manifold strip at the intake side to the thermostat or cooler.
The bi-VANOS variable camshaft control, which celebrated its world premiere in the M3 back in 1995 and has been further optimized for use in the current M3 model, is also featured in the new M5 engine. It ensures an optimum charge cycle, thus helping to achieve extremely short adjustment times. This means in practice: increased performance, an improved torque curve, optimum responsiveness, lower consumption and fewer emissions.
For example, at the lower end of the load and engine-speed scale the car can be driven with an increased valve overlap, boosting internal exhaust gas recirculation. This, in turn, leads to a reduction in charge cycle losses and fuel consumption.
The adjustment of the angles as a function of the accelerator pedal position and the engine speed is infinite and map-controlled. For this purpose, the sprocket, which connects to the crankshaft via a simplex chain, is linked to the camshaft via a two-speed, helical gearbox. In the event of an axial displacement of the adjusting piston, the helical set of teeth turns the cam relative to the sprocket, which allows for the variation of the angle of the intake camshaft by up to 66¡ă and that of the outlet camshaft by a maximum of 37 degrees in relation to the crankshaft.
The M bi-VANOS technology requires very high oil pressures for ultra-precise, high-speed camshaft adjustment. This is why a radial piston pump in the crank chamber increases engine oil pressure to an operating pressure of 80 bar. The map-controlled high-pressure adjustment ensures reduced adjustment times, allowing for the optimum angle, precisely the right ignition point and injection quantity under all conditions and in accordance with load and engine speed.
Constant lubrication even in hard cornering situations
Four oil pumps provide the engine with lubricating oil. The reason behind this unusually elaborate oil supply system is the M5's exceptional driving dynamics with extreme acceleration rates. The sports saloon has a cornering capability of over 1 g. During extreme cornering centrifugal forces force the engine oil to the cylinder bank facing the outside of the bend, thereby preventing the natural return of oil from the cylinder head, which might lead to inadequate oil supply in the oil sump. Should the worst come to the worst, the oil pump sucks air. In order to reliably prevent this situation, the engine features a traverse force regulated oil supply system. This system incorporates two electrically-operated duo-centric pumps which pick up oil from the outer cylinder head and transport it to the main oil sump if lateral acceleration rates exceed 0.6 g. A lateral-g sensor transmits signals to the pumps. The oil pump itself is a continuously variable pump with volume control which delivers exactly the amount of engine oil needed by the engine. This is achieved by the variable eccentricity of the pump's rotor in relation to the pump casing, depending on the oil pressure in the main oil duct.
view larger
BMW M5 engine pressure oil pump / © GCF
Proper oil circulation in all conditions
In extreme braking manoeuvres the M5 might even reach negative acceleration rates of up to 1.3 g. If deceleration rates are that high, it might well be that the amount of oil flowing back to the oil sump, which functions as an intermediate buffer, is not sufficient, particularly since the oil sump is located behind the front-axle support in order to save space. The worst-case scenario is that lubrication is interrupted. In order to prevent this situation, the M5 engine has been fitted with a so-called "semi-dry sump oil system" which incorporates two oil sumps: a smaller one in front of the crossmember and a bigger one behind. A recirculating pump has been integrated into the housing of the oil pressure pump, which picks up oil from the small front oil sump to convey it to the big rear oil sump, which has been carefully shielded. The return passages and the pickup point of the oil pressure pump are perfectly tuned to ensure proper oil circulation in all conditions.
Ten individual throttle valves are electronically actuated
Each of the ten cylinders has its own throttle valve, each cylinder bank, in turn, is served by its own actuator, a concept we are familiar with from motorsports. Although this system is very complex from a mechanical viewpoint, there is no better way to achieve spontaneous engine response. In order to attain maximum engine responsiveness in the lower speed range, and to achieve an immediate vehicle response at the high end of the performance spectrum, all throttle valves are controlled fully electronically. Two contactless Hall potentiometers determine and evaluate the position of the accelerator pedal 200 times per second. The engine management reacts to changes and causes the two actuators to adjust the ten throttle valves. It goes without saying that this process is performed at a lightning-fast speed: it takes just 120 milliseconds to completely open the throttle valves, this is about the time an experienced driver needs to fully depress the accelerator pedal. This gives the driver a feeling of instantaneous response and allows him to "dose" the gas pedal even more precisely. At the same time, the electronic throttle valve actuation keeps transitions from overrun to part load and vice versa smooth and harmonious.
The V10 engine uses ten flow-optimized intake trumpets to "breathe in" air from two intake plenums. The intake plenums and the trumpets are made of a lightweight compound material that contains 30 percent fibreglass.
view larger
BMW M5 exhaust system with manifolds / © GCF
Although the intake system contributes considerably to the remarkable performance of the new M5 engine, the importance of the exhaust system must not be underestimated. Also with respect to the exhaust system, only the best was good enough for the BMW M engineers. The two stainless steel 5-in-1 high-performance tubular headers have been optimized for equal length by using complicated calculating methods. For exact pipe diameters, the seamless stainless steel pipes are formed from the inside using the so-called interior high-pressure forming technique with a pressure of up to 800 bar. The manifold pipes have a wall thickness of just about 0.8 mm, which is also a sign of the M engineers' incredible attention to detail when designing this masterpiece in engine construction.
Even a sports engine can be a paragon of cleanliness
When designing the exhaust system, the engineers considered it most important to keep the counterpressure to a minimum and to optimise the gas-dynamic design for impeccable performance and torque behaviour. The exhaust system has a dual-flow design all the way to the silencers. The exhaust gases finally leave the system through four tailpipes which are what make the rear end of the M vehicles so unmistakable. As you would expect from a BMW M automobile, two trimetal-coated catalytic converters per exhaust line clean the exhaust gases produced by the ten-cylinder engine in compliance with the demanding European EU4 standard and the American LEV 2 standard. There are two underfloor catalysts. The other two catalytic converters (one for each exhaust line) are located close to the engine. In conjunction with the thin-walled exhaust manifolds, these catalysts quickly reach their optimum operating temperature, which means that they are fully operational quickly after a cold start. They excel due to their low pressure losses and high mechanical strength.
The MS S65 engine management system is the central factor behind the V10's outstanding performance and emission data. It enables the optimum coordination of all engine functions with the different vehicle control units, especially with that of the SMG. This innovative control unit is a world-first in a regular-production car: with more than 1,000 individual components, this engine management system is unparalleled in its package density. By the way, hardware, software and functioning are BMW M in-house developments.
view larger
BMW MMS 65 electronic engine management unit / © GCF
High engine speeds call for high-level performance
Due to the M5 engine's high speeds and the large number of control and regulating tasks, the demands placed on the MS S65 control unit's performance are extremely high. In order to meet these demands, the engine control module has been equipped with three 32-bit processors that perform more than 200 million individual calculations per second. Compared to the M3 control unit presented only four years ago, this represents a performance increase by factor eight. In terms of memory capacity, the latest control unit outdoes the previous one by as much as factor ten. Receiving more than 50 input signals, this system calculates for each individual cylinder and for each individual cycle the optimum ignition point, the ideal cylinder charge, the injection quantity and the injection point. At the same time this system calculates and makes the necessary adjustments for the optimum camshaft angle and the optimum position of the ten individual throttle butterflies.
By pressing a button, the driver can activate two sportier control maps for the throttle system, which offer an even more progressive response of the throttle butterflies to the actuation of the accelerator pedal. If the driver selects one of these settings, the dynamic transient functions of the electronic engine management system switch over to a more instantaneous response. In the M5, the more comfortable of the two settings is automatically applied as soon as the engine is restarted.
Comprehensive ancillary tasks for the engine management system
The electronic throttle valve control is based on a so-called power and torque structure which uses a potentiometer on the accelerator pedal to measure the driver's wish for power and performance and converts this to the desired function. The power and torque manager adjusts this request function by adding the power signals from the auxiliary engine units, such as the conditioning compressor or the generator. Functions such as idle-speed control, emission control and knock control are also coordinated and aligned to the maximum and minimum output and torque curves permitted by the Dynamic Stability Control (DSC) and the Engine Drag Force Control (EDFC). The target output and torque calculated in this way is then maintained at the desired level, while taking into account the current ignition angle. In addition, the engine management system carries out comprehensive tasks for onboard diagnosis with various diagnosis routines to be used by the workshops as well as other functions, and the control of peripheral aggregates.
The ionic current technology featured by the engine management unit is a technological highlight which serves to detect engine knock, misfiring and combustion misses. The uncontrolled ignition of the fuel in the cylinder is called engine knock. In order to prevent engine knock, engines without knock control generally feature a lower compression ratio. Furthermore, the ignition point is ******ed to prevent the cylinders from reaching or even exceeding the knock limit, which might cause damage to the engine. The "safety distance" to the knock limit resulting from this measure always has an adverse effect on fuel economy, engine output and torque. Active knock control, however, is an efficiency-boosting measure as it ensures optimum ignition timing and protects the engine from damages at the points of operation that are prone to knock.
Conventional systems employ several detectors on the outside of the cylinder to send knock signals to the knock control. In BMW M vehicles, one sensor monitors two cylinders. As the BMW M ten-cylinder engine is based on a multi-cylinder and high-revving concept, the use of those detectors alone is not sufficient in order to reliably detect engine knock. Due to the high engine speeds, evaluation must be very precise for optimum combustion quality in the cylinders, a factor which strongly influences the components' durability as well as the emission behaviour. This is where ionic current measurement comes into play.
The spark plug takes on additional control functions
This technology utilises the spark plug in each cylinder to sense and control engine knock. It also helps to check for correct ignition and to identify possible ignition misses. Thus the spark plug has a dual function ¡¡́C as an actuator for the ignition and as a sensor for monitoring the combustion process. Here again, the difference to conventional knock and ignition sensors becomes evident: they are located outside the combustion chamber, whilst the ionic current measuring is done inside the combustion chamber as spark plug and sensor are combined into one.
Measurement in the heart of the combustion chamber
Temperatures in a spark-ignition internal combustion engine's combustion chamber can reach up to 2,500 degrees. These high temperatures and the chemical reactions produced during combustion activity lead to a partial ionisation of the fuel-air mixture in the combustion chamber. Particularly in the flame front, the gas becomes conductive through the generation of ions by means of separation or accumulation of electrons (ionisation).
The spark plug electrode, which is electrically isolated from the cylinder head and linked to a small control unit operating independently from the engine management system, the so-called ionic current satellite, is supplied with a DC voltage and measures the so-called ionic current between the electrodes, the measured value depending on the degree of ionisation of the gas flowing between the electrodes. The ionic current measurement technique retrieves information on the combustion process directly from where things are happening, the combustion chamber. The ionic current satellite receives signals from the five spark plugs assigned to each cylinder bank, amplifies them and sends the data to the engine management system for analysis, which then makes the necessary interventions (for each cylinder separately). For example, cylinder engine knock and the ignition point are adjusted for each single cylinder in order to optimise the combustion process.
The spark plug, which is both an ignition source and a sensor, facilitates diagnosis when performing service and maintenance.
Shifting gears even faster with the seven-speed SMG gearbox
The concept of a high-revving engine only proves successful if the engine is combined with a transmission that matches the prodigious performance and translates the torque made available by the engine into optimum forward thrust by means of a short overall transmission ratio.
The seven-speed sequential M gearbox (SMG) is exactly what is needed to ideally transfer the power of the V10 engine to the drive train and finally to the wheels. With this gearbox, BMW M is the one and only manufacturer world-wide to market a seven-speed sequential gearbox with drivelogic function. Nonetheless, the new seven-speed gearbox is by no means an extended six-speed transmission. Instead, it is a completely novel gearbox, which has been designed exclusively for use in the new M5. Even more highly perfected than the previous six-speed transmission, the seven-speed SMG gearbox enables extremely fast manual gear changes as well as comfortable cruising thanks to the automatic gearshift.
The new transmission is technically designed to handle a torque of up to 550 Newton metres and engine speeds of up to 8,500 rpm. This gives the transmission sufficient reserves to ensure reliable operation throughout the new M5's entire lifecycle, which is further enhanced by a separate oil cooling system for the high-performance engine.
Even closer speed gaps than with the six-speed gearbox
Compared to a six-speed gearbox, seven gear steps offer even more reduced engine speed and torque gaps when changing gears. As forward thrust is closely related to high engine speeds, these reduced gaps assist the new M5 in achieving awesome acceleration.
The SMG transmission stands for sublime shifting pleasure
It goes without saying that the new seven-speed SMG gearbox offers all the advantages inherent in a sequential gearbox concept: gears are changed using the centre gearshift lever or the so-called paddles on the steering wheel. The driver does not have to press down the clutch and gear changes are possible even with the throttle foot flat on the floor. As opposed to an automatic transmission, the SMG transmission does not require an energy-consuming and performance-impairing torque converter.
As a matter of principle, all gears of the SMG transmission are shifted electro-hydraulically. The SMG gearbox features shift-by-wire technology, which has its origins in aerospace synergism and by which gears are changed in the fraction of a second without a mechanical link. In contrast to previous six-speed SMG transmission, the new M5's SMG hydraulic unit and the actuators have been integrated into the transmission housing. If a gear change request is made, the control unit actuates the respective magnetic valves which control the overall system's hydraulics. As a next step, the hydraulic oil with a high operating pressure of up to 90 bar flows swiftly via a magnetic valve into the clutch master cylinder to open the clutch. Then, using solenoid valves in the hydraulic unit, four hydraulic cylinders in the actuator are switched, which carry out the actual shifting process by means of four separate gearshift rods. When shifting down, the engine double-declutches automatically.
The new SMG boosts speed by 20 percent
The previous second-generation SMG transmission was already rapid-shifting, and, to top it all, the new, third SMG generation accelerates the process of shifting gears by another 20 per cent: for a gearbox of this kind, the shift speed is unrivalled and the advantages for the M5 driver are as follows:
Gear changes are extremely smooth and effected at a pace even the most experienced driver could not attain, thus making the inevitable power flow interruptions when changing gears hardly noticeable. The M5 delivers an almost jerk-free performance when accelerating from a standstill to its top speed. The driver gets much enjoyment out of shifting gears as SMG elicits a true "Formula 1 feeling".
Changing gears with an SMG gearbox also makes a valuable contribution to traffic safety: As shifting always involves the same level of speed and precision and is therefore absolutely reproducible, the driver does not have to concentrate that much on the process, meaning that the SMG gearbox promotes precise, safe and relaxed driving.
Drivelogic: the driver determines the SMG's gear change characteristics
Thanks to the SMG's drivelogic function, the driver can choose from eleven gear change options, which enable him to adapt the SMG's characteristics to his very own style of motoring. These programs differ from each other in the preselected gear change time: the higher the selected program, the engine speed and torque, the shorter the shift times.
Six of the eleven gear shift options can be preselected in the sequential manual gearbox mode (S mode), the spectrum ranging from balanced dynamic to very sporty. With the gearbox in the S mode, the driver always shifts gears manually, and the transmission does not at any time intervene in the shifting process.
Launch Control: moving up to maximum speed with full performance
With the gearbox in S mode, the driver can profit from the Launch Control function, which is a complement to the purist, sporty S6 driving program. The Launch Control function enables "rookie racing drivers" to make a perfect standing start in order to maximise the initial acceleration. This function requires the prior deactivation of DSC.
The aim of the Launch Control function is to relieve the driver of shifting gears, giving him more freedom to concentrate on his actual job of driving. When the car is stationary, the only thing the driver has to do is to flip the selector lever forward and keep it in that position. If he now fully depresses the accelerator pedal, the engine is automatically set to its optimum starting speed. If the driver releases the selector lever, the M5 is accelerated with the ideal amount of slip. The driver does not have to change gears until the M5 reaches its peak speed - the SMG gearbox with drivelogic automatically shifts/ through the seven gears and changes from one gear to the next gear shortly before maximum torque is attained.
As is the case with all driving programs, a telltale in the cockpit informs the driver of the gear currently in mesh.
Automatic gearbox - one that can hold its own even on the race track
Five of the eleven gear shift options of the Drivelogic function are available in the so-called D (Drive) mode. If this automated mode is activated, gears are changed automatically, depending on the driving program selected, the driving situation, the speed and the position of the accelerator pedal. With the D1 driving programme selected, for example, the gearbox sets off in second gear and ensures particularly delicate and smooth engagement of the clutch, this being of great help in wintry conditions.
Although having opted for automatic gearchanging, the driver can influence the process by, for example, releasing the accelerator pedal slowly, thus determining, also in D mode, the time when the gearbox shifts up. In turn, by depressing the accelerator pedal all the way down to the floor, he is able to effect fast downchanges. In S as well as in D mode, the gearbox automatically shifts down to the first gear as soon as the car is slowed to a halt. All the driver has to do to set the car in motion again is to step on the gas pedal.
Special functions for increased safety and comfort
The seven-speed SMG gearbox in the M5 not only helps the driver to squeeze the most out of the engine's prodigious performance but also offers a host of safety features. In critical situations, when shifting down on a slippery road for example, the gearbox opens the clutch in a split second in order to prevent the car from suddenly swerving out of control as a result of excessive drag torque at the driven wheels.
A further practical SMG feature is the so-called climbing assistant, which has up to now been featured exclusively in the M3 and allows for hill starts with virtually no roll-back. This effect is achieved by brake system intervention and can be taken advantage of in the sequential as well as the automated mode, irrespective of the direction of travel. The function is activated by applying the foot brake. As soon as the driver releases the brake pedal, the M5 is able to set off without rolling back in an uncontrolled manner.
The intelligent transmission on steep gradients
The so-called hill detection adjusts the shift points on gradients and descents. This prevents gear hunting when driving uphill. When going downhill, the hill detection holds the lower gears for longer in order to make effective use of the engine's braking power. In addition, with the gearbox in D mode, gear selection is adjusted to the steepness of the gradient.
These functions are only possible because the SMG control unit and the engine management system in the M5 closely communicate with each other via a particularly powerful CAN data bus, which connects the MS S65 engine management system with the SMG control unit, which is linked up to twelve redundant SMG sensors. In this way, the SMG control unit receives from the MS S65 the relevant data on the accelerator position, wheel and engine speeds, temperatures, steering angle and key memory. Moreover, the SMG and DSC directly communicate with one another.
ngine construction at its best
The highlights:
  • Highly flexible production line with a wide range of products at the BMW Plant in Munich,
  • Qualified staff and flexible processes,
  • Quality assurance by means of data transfer,
  • The highest quality standards.
The 507 bhp high-performance powerplant featured in the new BMW M5 perfectly reflects the manufacturing excellence of the BMW specialists. The production of the most powerful production car engine in the company's history is a complex process which requires premium quality.
Core components from the production network
The cylinder heads and the crankcase for the new V10 engine are produced at the light alloy foundry at BMW's Landshut plant, which also produces parts and components for the BMW Formula 1 engines.
Due to the heavy strain on the high-revving aggregate, demands on the surface quality and the manufacturing tolerances are extremely high in mechanical processing at the BMW plant in Munich. For example, components are processed at an accuracy of up to one thousandth of a millimetre. By comparison: a human hair is 0.05 millimetres in diameter (50/1000).
Flexible assembly
Final assembly, a highly flexible process, is performed in a two-shift pattern in the so-called special-purpose engine department of the Munich plant, where, in addition to the V10 engine, they also produce the six-cylinder aggregate for the M3, the V8 diesel and the twelve-cylinder for the BMW 7 model series. This diversity calls for a great deal of flexibility, profound product knowledge and excellent skills. This is why the staff responsible for BMW engine construction are all well-trained and experienced.
As this engine is not a high-volume product, full automation of the assembly processes only makes sense to a certain limited extent. This is why operations carried out manually and automated assembly processes are combined to complement each other perfectly.
An ergonomic work environment, devices for pivoting and swivelling the engine as well as for handling heavy loads ensure optimum working conditions and constitute the basis for supreme product quality.
As part of quality control, both the water chamber and the depressurised oil chamber of every single engine are checked for leakages, followed by hot run testing on the engine test bed.
Quality assurance via data transfer
The engines are mounted to special devices and to driverless system carriers that house a data unit which stores the most important production data. During the course of the assembly process, the data unit records crucial, quality-related data, such as the tightening torques or valve play and stores this data in a database. The data carriers also ensure that the right program, intended for the engine under construction, is activated at the automated assembly stations. At the assembly stations fitted with integrated tools, data communication ensures that the personnel use the right tools with the correct tightening torques.
Core components such as cylinder heads or connecting rods are provided with a code, which enables the staff to keep track of each component from the very moment it reaches the factory to mechanical processing through to its installation in the engine.
At work stations where complexity is particularly high, the monitors display which of the colour-coded crankshaft bearing shells has to be inserted.
Skilful craftsmanship: an absolute must
Particularly when it comes to the pre-assembly of the valve train and the crankshaft drive, experience, meticulousness and skilful craftsmanship are a must. The work on the kinematics of the VANOS variable camshaft control and the synchronisation of the ten individual throttle butterflies is also very demanding and requires considerable dexterity by the assembly staff.
The two-piece crankcase renders it necessary to use a special sealing technique. A sealant is injected fully automatically into the sealing surface via a circumferential groove. As soon as the sealant comes out at the other end, it is hardened at that particular point by means of UV light. The sealant in the interior hardens as the assembly process continues.
Sophisticated logistics
The supply of parts and components demands the highest of logistics standards as each of the four engine types with its numerous variants is made of about 400 different parts and components. The associates are an integral part of this complex process as they must use different parts and tools, depending on the type of engine manufactured.
The specialist engines are made to order, meaning that the customer-specific assembly does not start before the receipt of an order from one of the vehicle plants. Depending on the specifications, it takes up to 24 hours for an engine to pass through all stages of the assembly process.
2004 Mazda 3
[ View Me ]
enots is offline
Old 23rd June 2004, 19:22   #2
Black M5
Black M5's Avatar
Garage: Black M5
Re: Official press release: Engine / Drive System
Thats really impressive. It seem the car will set the standard with its technology and first in the World equipment
Black/ Black & Grey E60 /// M5 Nicknamed Mighty M5
Exterior
RD sport front splitters (diablo has a full lip)
RD sport silver CF front inlets
Kidneys painted black (just like diablo)
CF front and rear emblems (just like diablo)
CF double sided bonnet (coated and unpainted- just like diablo )
CF logo
AC schnitzer mono block V. 8.5x20 in the front and 10x20 in the rear. 245/35 ZR20 & 285/30ZR 20
AC Schnitzer roof spoiler (just like diablo)
CSL CF trunk
AC Schnitzer rear diffuser
Smoker LED rear lights (just like diablo)
CF side grillle
V-cool all around tint
Interior
AC schnitzer steering wheel (just like diablo)
CF logo
AC scnitzer black i-drive cover (model of wheels)
Hamann pedals (just like diablo)
CF BMW steering wheel logo (just like diablo)
Trim body matched
Corbeau racing seats. Weigh only 27 lbs
Custom 2 tone interior- black and grey leather with yellow stiching
Custom door panels. same as above.
Performance
EvoSport headers (diablo has SS headers)
EvoSport pulley
ESS computer upgrade
SS race mufflers (diablo has sports mufflers)
SS X pipe (just like diablo)
RPI intake w/black scoops
Brembo 15" front and rear brakes with yellow calipers (diablo has red calipers)
16" OEM fan installed at the front of the radiator
H&R lowering springs
Gone but not forgotten
Supercharged e39 M5 nicknamed El Diablo
700+whp@only 13 psi. Has all the mods in the book minus racing seats.
Sold to board member wilsodh
Black M5 is offline
Old 23rd June 2004, 19:36   #3
markf
Garage: 996 tt
my mouth is watering ,even though i don't like the looks of the 5 maybe a black one with tints might satisfy me,til the m6 arrives.Seriously tempted to get a deposit down.
Cobalt Blue 997tt
markf is offline
Old 23rd June 2004, 19:58   #4
alsahher
alsahher's Avatar
Garage: M5
very interesting .. cant wait any longer .. thanx for sharing
alsahher is offline
Old 23rd June 2004, 20:15   #5
rvacha
rvacha's Avatar
Garage: '08 E92 Jerez M3
Sounds very cool, specially the ionic knock sensors ans stainless steel headers.
Did anyone notice that there still is no mention of a manual tranny?
'03 E53 X5 4.4i Topaz/Sand
'06 E90 330Xi 6MT Sparkling Graphite/Terra
'08 E92 M3 6MT Jerez/Speed Cloth/Carbon Leather <-- Evil Twin
rvacha is offline
Old 23rd June 2004, 22:23   #6
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
bMw
Thanks for the link.
A nice reminder of what the "M" stands for
Very exciting!!!
All the best,
MEnthusiast is offline
Old 24th June 2004, 01:27   #7
BG
BG's Avatar
Garage: Renault Laguna
Brilliant! Can't wait to sample it!
BG is offline
Old 24th June 2004, 01:36   #8
Jim Dolan
Jim Dolan's Avatar
Garage: 2006 M5 Silver Grey Metallic
Great reading and very exciting.
Only 18 months to go................
Jim
2006 Silver Gray Metallic over Black
The "Wolf in Sheeps Clothing" is back in the USA again
1971 2002 Colorado(Light Orange)
1976 2002 Inka(Red orange, a classic)
1982 528e Blue metallic
1984 533i Burgandy
1987 325i Alpine white
1988 535is Salmon silver
1993 525iT Calypso red
1999 528iT Titanium silver
2000 M5 Titanium silver
2006 M5 Silvergray
Jim Dolan is offline
Old 24th June 2004, 01:40   #9
tifosi
tifosi's Avatar
Garage: Interlagos Blue E60 M5
Send a message via ICQ to tifosi Send a message via MSN to tifosi
ONLY??
tifosi is offline
Old 24th June 2004, 01:50   #10
Gustav
Administrator
Gustav's Avatar
Closed this, please see more detailed info here:
Pictures:
http://www.bmwm5.com/articles/m5e60/pressrelease
Press Release 1:
The Press Releases: no 1 BMW M5: MUSCLES FROM MUNICH
Press Release 2:
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons...
Bangle yes or now this car will set new standards for high-performance four doors as well as performance cars.
Gustav is offline
Closed Thread
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 62 28th December 2009 22:44
Got a Press Release: Supercar Rally (Attn. Lonman) Gustav Gumball 3000 Forum 21 14th May 2004 20:18
UK Official Press Release for the M5 E60 with Pics fastsaloons E60 M5 and E61 M5 Touring Discussion 6 7th March 2004 23:09
Audi RS6 presented, 440 HP! Gustav E39 M5 and E52 Z8 Discussion 52 11th March 2002 01:51
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 23:45
Page generated in 0.54489 seconds with 11 queries
