DIY: 5soko || Evolve Eventuri Intakes. DIY, Review, Datalogs - Page 10 - BMW M5 Forum and M6 Forums
 85Likes
post #91 of 99 Old 25th July 2015, 05:42 AM Thread Starter
5soko
5soko's Avatar
Originally Posted by Mcc420 View Post
Did anyone move the wiring harness that passes in front of the right air filter.
Never moved any wiring, dont rememver any wiring being in the way of air flow or scoops.
Originally Posted by Lay3r3 View Post
I get a weird vibration sound with aggressive vibration. I'm thinking it's the brackets that are mounted to the intakes rubbing against the front metal panel that they are mounted to with the rubber bushing threaded bolt thing. Anyone else notice this?
Never had this.. Loosen the screw and try to move the back a little? Maybe take a pic to pinpoint where its coming from?
2009 ///M5
Evolve Alpha-N Stage 2 Flash Tune | Eventuri Intake Kit | Supersprint Full F1 70MM-Xpipe-Catless
OEM Alcantara tri-stitch steering wheel|LUX H8 160 Angel eyes|Osram CBI's
IND Black Gloss Fender Vents|IND Painted Side Markers
Satin Black OEM wheels |Michelin PSS |30% Tint|LED License Plate lights
BMW Performance Grills|Full OEM BMW LED Interior + Trunk
Oem M projection Door lights|US Mill Work Tow plate|OEM M Floor Mats|Coding
5soko is offline
post #92 of 99 Old 13th April 2016, 04:52 AM
Texasgrego
Texasgrego's Avatar
Vubratiion update w/pic
Took out the carbon fiber intake assemblies to clean filters for first time since install, approx. 8k and about 8 mos. as well.
Amazingly clean, only had to shake out debris and clean up edges, and nooks, etc.
I have kept close eye on ductwork coming from brake ducts, and the d.s. had already come out of place from not being snapped in the bottom properly. This duct remains solid after adj. shortly after install.
The p.s. duct would normally be secured up top by the oem airbox.
Since it is gone the duct has worked into a state of possible vibration from lack of stabilisation from above.
We used foam backed door and window tape to secure the duct from possible movement to and fro. See pic with one side applied.
Texasgrego is offline
post #93 of 99 Old 15th April 2016, 03:58 AM Thread Starter
5soko
5soko's Avatar
Job well done sir...
Getting that bottom part of the duct to snap into its place is not very easy... But once done correctly, its very hard to take off or come loose..
2009 ///M5
5soko is offline
post #94 of 99 Old 2nd November 2016, 07:59 PM
M6sweden
Sorry to bring up a old thread but do anyone how vbox times of eventuri vs BMC- RPI setup? =)
For sale: New Throttle Actuators, Eventuri intake
Want to buy: Hood, sway bars, angel eyes for E63 M6
www.instagram.com/FT730/
www.youtube.com/channel/UCIwFqmgsar92SaQPo9mmtxg
M6sweden is offline
post #95 of 99 Old 17th February 2017, 02:19 AM
Dkey
Dkey is offline
post #96 of 99 Old 18th February 2017, 12:30 AM
yihchau
yihchau's Avatar
Evolve Eventuri CAI Air Duct / Lower Scoop Re-installation Tip
Originally Posted by 5soko View Post
/... the hardest part is honestly removing the front grills to put the scoops in there.../
Partially agree - to all the other search result tips found from others who claim kidney grill replacement is a breeze and can be done without undoing the top of the bumper or being able to reach through the kidney grills, or even just 'pressing on the tabs', yada yada yada... bulllllllllllshit.
/...The duct just pulls straight up and out, it pops out of its grove and out.. .../
Hard to do the 1st time, may require twisting motion to loosen the vertical air duct. 2 vice grip pliers attached to the vertical air duct will be your best friends in this scenario.
/...Then put the duct back into place but pushing down and twisting left and right, you can use a long screwdriver also to try and get the bottom of the duct to pop back into place..
Where the duct goes down into its place, the plastic wheel liner is right next to it, you can push the wheel liner in towards the wheel so you make room for your hand to reach down and guide the duct in, this is what worked for me..
THIS was the hardest part of the install - I'm willing to bet there are others who did this install who thought they did this part right or worse, gave up and said fock it and just left the air duct disconnected.
Thank you for documenting this crucial tip - hoping that others searching this forum for help on re-installing the vertical air ducts with lower scoops back into place will find your tip via 'search' more easily.
(Caveat: unsure if this tip is only applicable to LCI models) Since the front bumper's lower air dam/duct (that the vertical air ducts connect to) are made of flexible plastic, twisting/pushing the vertical air ducts w/lower scoops installed back into place was not easy at all. Imagine pushing the vertical air duct into the top hole of an an empty tissue box that has 1 vertical side on the box removed. Very mushy and unstable.
My contributing tip... you may benefit from following 5soko's tip and then "guide" really means, use your hand to stabilize/pull up the outer lip of the flexible plastic base vertically against the direction of the vertical air duct until it pops back in place. Note: This still takes considerable effort but is much more feasible than without this tip.
Tony
S85 NA | S62 SC
yihchau is online now
post #97 of 99 Old 18th February 2017, 01:58 AM
Craze
To put the ducts in put your hand in the airduct at front bumper then push it down, clicks in easy
Craze is offline
post #98 of 99 Old 18th February 2017, 03:40 AM
Mcc420
Mcc420's Avatar
As for the kidney grills I just put my fingers in the slots and pull hard and they come out. I just did it on my f10 samething.
Mcc420 is offline
post #99 of 99 Old 21st February 2017, 11:53 PM
Matt C
Matt C's Avatar
Awesome write up. Thanks.
Cheers,
Matt
///M Fanboi
E60 2007 M5. Michi PSS's. Eibach. FAM. BE and ARP's. BMC. RPi.
E46 2004.5 M3. RIP 4th May 2015 my joyful toy.
Matt C is offline
Evolve Eventuri Intakes installed on my BMW E61 M5 Touring ss19777 E60 M5 and E61 M5 Touring Discussion 16 9th August 2014 03:49 AM
E60 M5 fitted with Evolve ECU Remap, Evolve E-Tronic, Evolve Eventuri VAi Intake Kit Imran@evolve E60 M5 and E61 M5 Touring Discussion 17 3rd July 2014 02:33 PM
So you guys wanted some Evolve Eventuri Intake videos... randywei E60 M5 and E61 M5 Touring Discussion 31 5th June 2014 07:35 AM
Evolve Eventuri intakes have landed BRUNBERG E60 M5 and E61 M5 Touring Discussion 90 19th May 2014 08:44 PM
REVIEW+DIY : Evolve E60 M5 AlphaN Tune and blanking plates + Drone Elimination plus other stuff potassium E60 M5 and E61 M5 Touring Discussion 32 30th December 2012 05:58 PM
