UPDATE: After the software update everything was fine for a while (I bet it had nothing to do for error occurance). Then "27A1 DME:Throttle valve actuator, enable line, bank 1" returned. I started to get it every day but after one or more restart it went away. One day i was driving quite hard and new code popped up "2B25 Throttle valve monitoring bank 1". It was time to take the plenum off and replace both actuators and see what's wrong. After i got plenum off, i manually operated the throttle valves (actuators and arms were still connected) and i notice that bank 1 was very weak and had some resistance comparing to bank 2. Took the actuators out and now the throttle valves moved same speed. Bank 1 actuator returning spring didn't work correctly and was 2. times slower than bank 2, so i found my problem.
I measured internal enable line from both old actuators and it showed 104kOhm so the lines were ok. Also measured the enable line wire for continuity just for fun, it was ok.
What i learned this time is 27A1 or 27A2 does not mean automaticly that your throttle valve sensor is bad, like the one thread in this forum tells you. Also it was easier for me to take both actuators out from the bank 1 side (passenger side).
ISTA also tells you these reasons / solutions about 27A1 error code:
1. Check enable line for continuity, if ok move to step 2.
2. Check throttle valves moves properly, if ok move to step 3
3. Replace throttle actuator
I hope this helps someone to chase down those 27A1 and 27A2 codes. This code could mean many things but in my case it told that DME had shutted down bank 1 actuator because the throttle valves didn't move properly.. It became clearer to me when i got that 2B25 code.
