Proper e60 M5 Operation - Survey - BMW M5 Forum and M6 Forums
 13Likes
post #1 of 24 Old 6th September 2013, 04:56 PM Thread Starter
MarlonF1
MarlonF1's Avatar
With all the talk about rob bearings, clutches, how long to warm up the motor, when to shift, and what rpm is the best or cruising in a high revving big engine, I thought it might be interesting to see what consensus we might create about operating our cars. I'm curious how you might answer the following... I know the climate you live in matters, so maybe differentiate between summer and winter if it matters where you drive.
1. From a cold start, how long do you warm up the motor before driving away?
2. When the motor is still warming up, (oil NOT at 210), at what RPM do you normally shift gears when just cruising around town?
3. When the motor is warm, (oil at 210), What RPM do you normally shift gears when just cruising around town?
4. What do you mostly run in: P400? P500? Or M mode?
5. How much have you used / do you use the launch feature?
6. How many miles on your original clutch?
7. How many track days has your car seen?
8. How many miles have you got on a set of brake pad? Rotors?
9. How often do you use D mode?
What else do you do, to "properly" operate your car?
Former: 2008 E60 M5
Current: 2015 F82 M4
MarlonF1 is offline
post #2 of 24 Old 6th September 2013, 04:58 PM Thread Starter
MarlonF1
MarlonF1's Avatar
Here's my contribution:
1. From a cold start, how long do you warm up the motor before driving away? 3-4 mins
2. When the motor is still warming up, (oil NOT at 210), at what RPM do you normally shift gears when just cruising around town? 3,000 rpm
3. When the motor is warm, (oil at 210), What RPM do you normally shift gears when just cruising around town? 3,000 to 4,000 rpm
4. What do you mostly run in: P400? P500? Or M mode? P500
4. How much have you used / do you use the launch feature? Zero
5. How many miles on your original clutch? 50,200
6. How many track days has your car seen? Zero
7. How many miles have you got on a set of brake pad? Rotors? 50k
8. How often do you use D mode? Never
Former: 2008 E60 M5
MarlonF1 is offline
post #3 of 24 Old 6th September 2013, 05:06 PM
MTV10
MTV10's Avatar
No more than 30 seconds. Just keep revs below 3k.
3-4k
~4k
M-Mode. P500S, DSC OFF, S6, EDC SPORT
Never
80k KM's
None
40k
NEVER
Gone but not forgotten. . .
Interlagos Blue E60 M5
Euro SMG Software
Charcoal Filter delete
Meisterschaft X-Pipe
Meisterschaft GT2 Exhaust
Miro 111's 20x8.5 | 20x9.5
H&R Spacers (12mm | 15mm)
H&R Sport Springs
All Red Taillights
MTV10 is offline
post #4 of 24 Old 6th September 2013, 05:21 PM
MKSixer
MKSixer's Avatar
I let the idle settle down then drive off.
I gradually escalate the rpm beginning at 2000 rpm with the shift from first to second when leaving the neighborhood. Ex. 2000 rpm 1st
to 2nd gear, 2500 second to 3rd, 3000 3rd to 4th, etc. until the car is warm.
Rather situational...I generally rev at 6000-8000 rpm as a general practice. I use the car.
M mode...P500Sport, S5 or S6, Sport Suspension/Diff setting. I don't even back out of the garage in P400.
Never
70xxx. The clutch is in the process of being changed as I type this.
15-20 plus another 20, "spirited drives" with the car club. (We aren't playing around on the drive!)
About 15K on the fronts and 20K on the rears.
I'm not familiar with this..."D mode". J/K my wife has driven the car 2 or 3 times always in D mode.
I drive the crap out of the car and make sure it is properly inspected, serviced, and cared for at all times. I perform oil changes every 5K miles and inspect the undercarriage each time it's on a lift.
I just saw Mighty5 also discussed his shifting habits so I will add mine, as well. I grab every gear going down and since my clutch lasted 70K+ miles, I don't think that there was an adverse reaction to my driving style. I was taught to hit every gear up and down when I learned to drive a 3 pedal car and I've continued the habit on the SMG.
I hope this helps.
Cheers-Milton
MKSixer-Milton
2007 BMW M6 Coupe
Silverstone Metallic-Silverstone II Full Merino Leather Interior-Alcantara Headliner-Gas Guzzler Tax-No HUD (WTF?!)
Tubi X-Pipe (Thanks Hasan!)-Tubi Rumore Section 3-Red RPI Scoops-Dinan Carbon Fiber Cold Air Intake-Charcoal Filter Delete
ACS Front Strut Tower Brace-Dinan Carbon Fiber Rear Strut Tower Brace-Dinan Rear Anti-Roll Bar-Dinan Front Roll Control System-12.5mm TMS Front Wheel Spacers-12.5mm TMS Rear Wheel Spacers-Pirelli PZero Corsa System
Custom Finished Factory M6 Wheels-CF Front Spoiler-Carbon Fiber VRS Type Rear Spoiler-Matte Black Grille-Matte Black Side Gills-BMW ///M Valve Stem Caps-BMW ///M Matte Black License Plate Frame-LED Side Markers
Formula 1 Tint: 35% Front Windows-20% Side Windows-15% Back Glass
Hard-Wired V1 Radar Locator-Aluminum ///M Pedals-Dinan Embroidered Floor Mats
In Hand but not Installed: Interior LED Lighting-Evolve ECU Upgrade-LED Brow Lights
Next: Exterior LED DRLs-Angel Eyes Upgrade-RPI Oiler Cooler
2015 BMW i8, 2014 BMW 328d, 2012 Ford Fusion
MKSixer is offline
post #5 of 24 Old 6th September 2013, 05:21 PM
tbrown1985
Maybe add "Current Mileage?" and any "engine related mods"? and "oil type and change interval" Just a thought.
tbrown1985 is offline
post #6 of 24 Old 6th September 2013, 06:25 PM
EuroCarFan
1. From a cold start, how long do you warm up the motor before driving away? About 30 secs
2. When the motor is still warming up, (oil NOT at 210), at what RPM do you normally shift gears when just cruising around town? On my old engine, I didn't pay attention and probably shifted in all sorts of rpm ranges. With the replaced used engine (I shift before 4K).
3. When the motor is warm, (oil at 210), What RPM do you normally shift gears when just cruising around town? Around 4K
5. How much have you used / do you use the launch feature? Only twice after I got the Euro LC but I bought my car used with 10K miles on it back in 2007 and not sure how many times the previous owner used LC.
6. How many miles on your original clutch? My original clutch was replaced at 52K miles due to an intermittent red cog that would appear during cold start and disappear after a few secs.
7. How many track days has your car seen? None except a Car Control Clinic with BMWCCA where we practiced braking, slalom and skid pad
8. How many miles have you got on a set of brake pad? Rotors? About 11K miles on my current Brembo pads. I think 65K miles on the rotors
9. How often do you use D mode? Never
Additional info:
10. Oil changed every 7500 miles with BMW Castrol TSW 10W-60 oil.
11. Engine broke down from spun rod bearings at 88.5K miles.
12. Replacement motor has 15K miles.
13. Mods are in my signature.
2006 M5 Blk/Blk/Alum Fully Loaded
Engine: FAMS Tune | RPI Ceramic Coated Headers + GTS Exhaust w/Gloss Black Tips and Red RPI Logo + Ram Air Scoops + BMC Filters + Block-Off Plates + Pulley + Oil Cooler | Sprint Booster V2 | Euro SMG LC Tune
Wheels, Susp & Brakes: Neez QD7s Gloss Gunmetal 20x9-10 | PSSs | KW V3s | Dinan FRC + Rear Sway Bar + Front & Rear CF Strut Braces | Brembo 380mm BBKs
Exterior: Hartge Splitter & Diffuser | Vorsteiner CF Trunk Spoiler| Republic Wraps Side Diffusers | CF Lower Mirror Covers | CF Side Gills
Interior: RDSport Alum Pedals | Hardwired V1 | iPod Integration Kit | BSW Stage 1 Speakers | Earthquakes SWS Subs w/HiFonics Zeus 500W Amp | Flat Bottom Steering Wheel w/CF Trim | AS Designs Red Tachometer
Lighting: Eurospec Headlights w/Clear Corners | LCI LED Taillights | MTEC V3 AEs | Trinity Autosport Interior LEDs | F10 Style Smoked LED Side Markers
Coded Options: Folding Side Mirrors, Windows and Moonroof w/Remote | Deleted "Accept" Screen | Turn Signals in HUD | Real Speed in OBC Screen | Automatic Heated Seats Controls in iDrive
EuroCarFan is offline
post #7 of 24 Old 6th September 2013, 07:56 PM
Fuddy
Fuddy's Avatar
0 seconds, back out of the garage almost immediately.
2500-3000
6000-7000
Always P500 S6 DSC off
Never
original clutch was changed at 40k, i'm at 97k with replacement now.
0
I'll get back to you, just changed my fronts 1000 miles ago.
Never
this engine loves to rev...rev it often
Fuddy is offline
post #8 of 24 Old 6th September 2013, 11:35 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
I hope this helps.
Cheers-Milton
^^ I'm right there with you Milton...except I'm a 6MT.
My answers in BLUE:
1. From a cold start, how long do you warm up the motor before driving away? Same as MKSixer
2. When the motor is still warming up, (oil NOT at 210), at what RPM do you normally shift gears when just cruising around town? Same as MKSixer
3. When the motor is warm, (oil at 210), What RPM do you normally shift gears when just cruising around town? Between 6000 and 8000, unless I'm in a school zone or want to be stealthy
4. What do you mostly run in: P400? P500? Or M mode? 6MT; M mode = P500s as soon as I start the car.
5. How much have you used / do you use the launch feature? Yes, I launch with my left foot.
6. How many miles on your original clutch? 68,000+
7. How many track days has your car seen? Same as MKSixer
8. How many miles have you got on a set of brake pad? Rotors? Don't keep track, check every 3000 to 4000 miles when I change my oil.
9. How often do you use D mode? What is the "D" mode you speak of?
Additional info:
10. Oil changed every 3000 to 4000 miles with MOTUL 7100T 10w60
11. Rod bearings replaced at 84,000 miles as preventative maintenance. Rod bearings at 84,000 miles
12. Currently at 86,xxx miles, with the last 60,000 miles put on by me.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =133,000 miles with no RCOD and counting ...just saying...
2007 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing (Blanton) 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PSS 255/40/19 and 295/35/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; RedLine B/S RDR off, F/R G1W-H, ALP w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 miles!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; z3 1.9L ssk and ZHP shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the sub 2,400lb e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 228,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014 to a good home.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service autohausfrankfurt.com/ my local Dinan supplier trinityautosport.com my local drug dealer for my crack habit
fastattackmotorsports.com because JColley!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
The Following User Says Thank You to Fiftytwoeighty For This Useful Post:
MKSixer (7th September 2013)
post #9 of 24 Old 7th September 2013, 12:16 AM
MIGHTY5
MIGHTY5's Avatar
1. From a cold start, how long do you warm up the motor before driving away? Until the Rpm's settle around 700 or so.
2. When the motor is still warming up, (oil NOT at 210), at what RPM do you normally shift gears when just cruising around town? I always shift at around 3k when engine is still cold
3. When the motor is warm, (oil at 210), What RPM do you normally shift gears when just cruising around town? When there are cops around under 3k when there is no cops depends on my mood.
4. What do you mostly run in: P400? P500? Or M mode? Im always set to P500 dsc off sport everything but i dont use the M button unless im going to do some real driving.
5. How much have you used / do you use the launch feature? No i never use the launch feature
6. How many miles on your original clutch? I had 42k on my original clutch at that point the SMG took a dive on me luckily i was still within CPO so to the tune of 15k the dealership replaced my Entire SMG with a brand spanking new one.
8. How many miles have you got on a set of brake pad? Rotors? Havent had to change them yet as they were just changed when i aquired my car
9. How often do you use D mode? Never! lol
What else do you do, to "properly" operate your car? I have an SMG so when i come to any stop i always put my car in neutral and then back into gear when im ready to go again. The reason is i want to prevent clutch wear by not allowing the SMG to down shift from 7,5,3,2,1. so far its fine no issues car runs like a boss.
MIGHTY5 is offline
post #10 of 24 Old 7th September 2013, 12:54 AM
Kazakh015
Kazakh015's Avatar
Yeah, I usually let the car sit for about 10-15 minutes warming up, basically as soon as cold start is done and RPM's fall below 1k I slowly drive off, without any revving and shifting as low as possible.
I try to shift early, may be 2.5-3.5k rpm, despite the fact that my smg clearly doesn't like that - blinking gear indicator...
First of all, I never just 'cruise' in town and I generally hate driving slow. Moreover, it constantly pisses me off how other drivers in Boston are driving like they are half asleep at the wheel or they just can't drive. Hence, I shift at 8600 RPM (Evolve-R Stage 2 Remap) quite often, at least 15-20 times per day
Honestly, I find myself in M-mode as soon as the engine warms up to full operating temperature. For me, M-mode is set at P500S, DSC OFF, EDC Comfort (Horrible roads in Boston) and of course SMG in manual S6
I've used LC about 5-7 times since I purchased the M5 on the 15th of March 2013, so almost 6 months ago! However, I did have to change the clutch/flywheel and have not done any launches since then!
My original clutch/flywheel crapped out on me after 38000 miles, of which only 5000 where my miles + 5-7 LC starts! New clutch should last at least another 30k (Fingers crossed!)
Unfortunately, my car has not seen a single track day...
When I bought my car at 33000 miles, the stealership replaced all four rotors and brake pads as part of the deal (Also got a set of new tires). So fast forward 6 months and right now I have driven about 7000 miles on these parts without problems.
Honestly, I don't like D mode and never use it!
Taking good care of the M is vital for her longevity, so I am following my own maintenance schedule. Unfortunately, I have no idea how the car was treated by the two previous owners and the 33k miles they drove, but I am assuming they followed the blind BMW-recommended schedule!
When I bought the car in March, as part of the deal I had all fluids changed (engine oil/filter, smg trans, rear diff fluid, brake fluid flush), and also they changed the filters and as mentioned above I had new rotors/pads installed. Since this 'major' service, I had another oil change done at 38k miles while the car was getting a new clutch/flywheel and going to change the spark plugs in when I hit 40k miles (should have done it much earlier, I know I know...)
BMWDave: "The E60's V10 is like dating that hot girl who takes you for granted, makes you buy her stuff all the time, the sex is mindblowing and she screams too loud during the act , mother never approved of her, and she got too drunk at your wedding and made out with the best man..."
Richard Hammond: "Straight away, you can see the problem - Its brilliant. Big 500hp V10, naturally aspirated...Its just distilled essence of single malt driving pleasure."
Jeremy Clarkson: "In M********** mode, this car is pretty hard to describe. But 'perfect' will do for the moment. The M5, I think, may very well be my next car. I absolutely love it."
[Aldiyar] [Boston, MA]
My Cars (Current)
2015 Lamborghini Huràcan LP610-4
Brand New
Giallo Midas (Yellow)
Black Leather/Giallo Midas alcantara
Sports Exhaust System
My Car (Past)
2008 E60 BMW ///M5 (V10 SMG) - Crashed...
40XXX Miles
Space Gray Metallic
Silverstone II Full Leather/Aluminium trim
2013 (W221) Mercedes-Benz S65 AMG - SOLD
4,XXX miles
Designo allanite grey magno
Designo AMG Exclusive nappa leather in silk beige/satin pearl red and AMG Carbon fiber
2013 Porsche Panamera GTS - SOLD
16,XXX miles
Basalt Black Metallic
Black leather/alcantara + GTS Interior package
2014 Nissan GT-R - SOLD
5,XXX miles
Pearl White Metallic
Red Leather
2015 Jaguar F-Type R Coupe - SOLD
5,XXX miles
Polaris White
Jet/Red Leather Performance Seats
Kazakh015 is offline
ignition key remote operation E60 M5 Legend E60 M5 and E61 M5 Touring Discussion 5 16th October 2010 05:38 PM
Proper Introduction [M3 E30 and M5 E60] Bman E60 M5 and E61 M5 Touring Discussion 18 25th May 2007 03:36 PM
E60 M5 Survey GrimReaper E60 M5 and E61 M5 Touring Discussion 3 24th September 2006 04:21 PM
E60 M5 - Proper exhausts ! Whizzkid11 E60 M5 and E61 M5 Touring Discussion 5 25th March 2005 07:37 AM
Not M5, but still proper BMW with proper M5 engine Doubled Owners Gallery 10 22nd October 2001 09:00 AM
