New wheels, offset help? - BMW M5 Forum and M6 Forums
post #1 of 3 Old 6th September 2013, 05:08 PM Thread Starter
europower
Thinking about getting TSW Mirabeau 19 inch wheels in matte black. What do you guys think about these wheels, and what offset should I go with?? My car has been lowered by the previous owner not sure how much though... I'm assuming that it is just an HR or Eibach springs... Thanks!
europower is offline
post #2 of 3 Old 6th September 2013, 10:59 PM
InDaBungHole
InDaBungHole's Avatar
I just had 19" TSW Nurburgring installed on my M5 so the TSW Mirabeau should work also. My car has Dinan springs which only lower a smidge but I still think your springs will work too. I bought them from a dealer here in Phoenix, but they sell nationally. Give them a call (Robert I think?), he will remember my car. Make sure they give you the hub rings (they forgot mine) that come from TSW. The wheel has 76mm bore but our hub is only 72.5mm. Some people will tell you that you don't need hub rings because the bolts lock it down perfectly centrally but this is BS. My car had a shimmy until I got the hub rings installed, now it runs smooth as glass and performed flawlessly at the track day I just did.
- Staggered Full Set -
(2) 19x9 TSW Mirabeau Matte Black (Multi-Piece)
(2) 19x10.5 TSW Mirabeau Matte Black (Multi-Piece) Wheels
You don't have different choices of offset with TSW but trust that these will work (15mm front and 27mm rear)
Not sure what tire size your looking at but the TSW wheels are slightly wider (9.0 front 10.5 rear) so 255 front and 295 rear tires will be the square fit for them. You could go 245 and 285 if you like the stretched look. You will likely need spacers on front to clear strut so order the 12mm spacers from turner motosports with the longer bolts. My rears bolted right on. The fitment on mine looks perfect now.
I screwed around with my wheel and tire fitment for literally two months before I got it right, so hopefully my pain will benefit someone else.
You will need TMPS sensors if your M5 is 2007 or newer (check with BMW on this). Mine is 2006 so no sensors needed (senses wheel rotation).
2006 E60 M5 SMG (PAINFULLY SOLD )
K&N performance intake
RPI GT exhaust section 3
Dinan Stage 3 suspension, -2.3 camber front, -1.8 camber rear
Dinan Monoballs
Padig Yellow RS19 Race Pads, SS lines, Motul RF600
ESS E-Flash Tune 8400 rev limit, governor delete
Front: TSW Nurburgring 19x9, Advan AD08 255/35/19
Rear: TSW Nurburgring 19x10.5, Advan AD08 295/30/19
425+ RWHP
Bad SMG, had to let her go
1999 E36 M3 5sp, Track Project
Full custom Ground Control Coilover Racing Suspension
Back Half Racing Cage
OMP full containment racing seat
NRG quick release racing steering wheel
Stock Rims with Toyo R888s
Suspension and cage work done by Flatout Motorworx http://602flatout.com/
Mishimoto radiator
Stewart water pump
Sunroof Delete
Stock motor with Magnaflow muffler
1973 Pontiac Trans Am, 455 HO, 4sp, Buccaneer Red
2008 Ford F250 Crew Cab 6.4L Powerstroke Diesel
InDaBungHole is offline
post #3 of 3 Old 7th September 2013, 01:39 AM Thread Starter
europower
Awesome, thanks!! Not sure if I want to go as wide as 10.5, but it looks like they only come in a 9... Love your wheels as well!
Sent from AutoGuide.com Free App
Barter WTB: 18" Wheels 30-32 front offset and 34-36 rear offset M5_Forever Parts / Other For Sale or Wanted 1 15th November 2012 05:55 AM
What is the offset for wheels for a m6? 747M6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 4 3rd February 2009 12:10 AM
B3 E36 offset (wheels). nealpina ALPINABoard.com | BMW Alpina Discussion 2 10th October 2007 02:36 AM
what is the offset on the stock wheels. phillym5 E39 M5 and E52 Z8 Discussion 2 30th June 2003 05:36 AM
