Comprehensive S85 Rod Bearing Picture Thread - Page 76 - BMW M5 Forum and M6 Forums
 232Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
post #751 of 809 Old 13th February 2017, 02:24 PM
benron_77
So as promised, here are mine.
Changed at 126k. Owned the car since 123k (kms).
Last OA - Lead at 19ppm. Weekend Drive only. No track. Changed to 702/703 bearings
Wear is not too bad but probably will not last another 100k kms so glad I changed them. I will probably wait another 120k kms before worrying about them again given the current condition?
Enjoy. Now I need to change serpentine drive belts as my car was squeaking like mad when I first start then goes away after warm up. Dealer noted this prior to disassembly. Dealer says the cost of this job is $72 + 1h labour. SOunds about right???
benron_77 is offline
post #752 of 809 Old 13th February 2017, 11:56 PM
Doc GTO
Doc GTO's Avatar
I just bought the car about a month ago and love it. I bought it with the intentions of doing the bearings because I planned on keeping this one for a while as it's the last of the great NA M5s. I got the car under book so bearings were not an issue. I went ahead and shipped the car to Markert Motor Works to do a custom dyno tune, SMG tune, LCAs, coil packs & plugs, and the rod bearings. I went with the BE bearings and ARP 2000 rod bolts. While the front subframe was out we did the motor mounts and did a front to rear inspection and it already had the updated vanos lines, new power steering pump & lines and an Evolve power pulley in it which was a score.
Rod info:
- mileage
79650
- owner history
I'm the 3rd Owner
- average oil change interval
Based on dealer info from 1st owner and service receipts on the 2nd owner, every 5K with either Castrol or LM 10-60
- oil analysis reports if available
None
- reason you decided to change (fear, suspect noise, suspect oil analysis, hard usage, etc)
Known issue and figured that since I plan to keep it, just do the BE/ARP and be done with it.
- DIY or shop changed
Shop. Markert Motor Works in Lawrencevile, GA
- link to your change thread I you have one
Dont have one.
Bearing pics. 8 of the 10 look good and then #3 was just starting to see a little copper and #8 was copper. Not the best pics but you get the jist of things. Crank looked perfect.
________________________________
Doc
2006 BMW M5: Alpine white/Full Silverstone II/Exhaust mods/AFE/H&R/Vorsteiner Carbon Hood/Lip spoiler/RPI Scoops/Apex ARC 8 Wheels/MMW Dyno tune/EVOsport pulleys
2002 E46 M3 Track Car: BoneCrusher
1994 E36 325is M Technic #5418
2016 GMC 3500 Denali Tow Beast
Doc GTO is offline
post #753 of 809 Old 14th February 2017, 01:30 PM
ticat928
ticat928's Avatar
Markert Motor Works are good people, surprised how well they know the s85, helped me out at NCM when I had a small coolant hose pop off that I was unable to access with tools i had. No charge repair by Markert Motor Works!
I owe them one.
ticat928 is offline
post #754 of 809 Old 14th February 2017, 02:25 PM
Doc GTO
Doc GTO's Avatar
I owe them one.
They really are great! We had a coil pack take a crap at Road Atlanta and didn't have a spare. They came over, ran the computer on it and found #6 was the problem and had a bag of coil packs and put one in for us. Zero charge.
That is what I use them now for all the serious work. They did the chassis work on the race car and they have it now putting in a new clutch for the SMG.
Doc
Doc GTO is offline
The Following User Says Thank You to Doc GTO For This Useful Post:
Ojisonracer (14th February 2017)
post #755 of 809 Old 15th February 2017, 02:29 AM
Matt C
Matt C's Avatar
Really dumb question guys, but how do you remove and then fit a replacement internal HP vanos oil line? Can't for the life of me work it out.
Cheers,
Matt
///M Fanboi
E60 2007 M5. Michi PSS's. Eibach. FAM. BE and ARP's. BMC. RPi.
E46 2004.5 M3. RIP 4th May 2015 my joyful toy.
Matt C is offline
post #756 of 809 Old 15th February 2017, 07:01 AM
mattcon
Did you remove the pump? I think it needs to be removed to get the line out. I didn't have too much trouble removing mine. Do you have it disconnected and just can't get it unseated or what is the issue?
mattcon is offline
post #757 of 809 Old 16th February 2017, 10:36 PM
Matt C
Matt C's Avatar
Bizarrely I thought it was connected at both ends internally. Worked it out. Thanks Jim Colley for the advice.
Cheers,
Matt
///M Fanboi
Matt C is offline
post #758 of 809 Old 28th February 2017, 05:57 AM
Bibm5
Bibm5's Avatar
Im new to the board and I just purchased a 2008 m5 (124k miles and runs amazing!) and im in the process of doing several preventive maintenance items including bod bearings.
My question is, what is the best brand bearings to use and are there any "complete kits" that have everything needed in one package? Any suggestions would be much appreciated. This car has great maintenance records and is on original bearings with no knocking at all. I promise to post up pics of the bearings once i get down to them!
Bibm5 is offline
The Following User Says Thank You to Bibm5 For This Useful Post:
bbrant (28th February 2017)
post #759 of 809 Old 28th February 2017, 12:49 PM
B767capt
B767capt's Avatar
Fast Attack Motorsports
B767capt is offline
post #760 of 809 Old 28th February 2017, 12:59 PM
Doc GTO
Doc GTO's Avatar
Doc GTO is offline
The Following 2 Users Say Thank You to Doc GTO For This Useful Post:
Bibm5 (1st March 2017)
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
Bearing Rod Changed with Pictures ! S85 Duschanio E60 M5 and E61 M5 Touring Discussion 235 2nd September 2014 07:05 AM
rod bearing messier781 E39 M5 and E52 Z8 Discussion 9 24th March 2014 05:49 AM
Bearing Rod Changed with Pictures #2 - S85 TomekW E60 M5 and E61 M5 Touring Discussion 14 24th August 2013 01:05 PM
Rod Bearing Tolerance? Rod Bearing Advice? lefebv19 E39 M5 and E52 Z8 Discussion 21 17th August 2011 04:36 AM
Comprehensive Header Thread CU'09 E39 M5 and E52 Z8 Discussion 9 21st November 2009 05:40 PM
