Comprehensive S85 Rod Bearing Picture Thread - Page 6 - BMW M5 Forum and M6 Forums
 231Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
post #51 of 785 Old 12th October 2013, 01:06 AM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Originally Posted by Ogjohnsmith View Post
I have an 06 with 75k, it's an Arizona car where it 100 degrees 100+ days a year. I have a theory that the s85 rod bearings in hot climates don't suffer as much oil starvation as the s85 rod bearings in cold climates because the oil will have more viscosity. I'm awaiting my Blackstone report to add some weight to that theory.
Anyone here have worn rod bearing or high lead Blackstone report that lives in a hot climate?
Sent from AutoGuide.com App
My BMWs never see winter. I'm hot in SoCal, but it's not nearly AZ hot. I am meticulous with warm up procedures in all my cars. With that said, I don't know how my s85 was treated in the early days (test drives at the dealership and wreckless techs included). My RBs were shot.
As a side note, I regularly switch to thinner oils in our SuperCharged LandCruiser (210,000 miles) for the winter months, where it lives above 8,000 ft.
I'm still running 10w60 but not Castrol. Instead, I'm on Motul 7100T. I'm 4,000 miles post-rod bearing replacement and I'm still burning ZERO oil. I just returned from a blast across The Nevada Desert and burned ZERO oil. I'm about to do my 2nd oil change post-bearings and send a sample to BS for analysis.
I've thought about going to a thinner oil, (per m3post) but my s85 never sees cold temperatures.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =133,000 miles with no RCOD and counting ...just saying...
2007 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing (Blanton) 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PSS 255/40/19 and 295/35/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; RedLine B/S RDR off, F/R G1W-H, ALP w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 miles!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; z3 1.9L ssk and ZHP shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the sub 2,400lb e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 228,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014 to a good home.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service autohausfrankfurt.com/ my local Dinan supplier trinityautosport.com my local drug dealer for my crack habit
fastattackmotorsports.com because JColley!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #52 of 785 Old 12th October 2013, 01:15 AM
335xi
So, what about folks that are still under warranty?
Originally Posted by jcolley View Post
The hottest climate on earth won't thin TWS enough. Visibility has increased on the rod bearing issue in the last few months. Funny, BMW AG specified more frequent oil change intervals recently. Oh yeah, they recommend thinner oil now too.
If I had an S85 in any climate, any conditions, any number of owners, anywhere in the world, I would change the rod bearings out preventatively and switch to thinner oil. There's enough documentation floating around now that the notion of this being pure speculation is starting to go away. They got our money when we bought the car, they got our money with TWS, now they get more with parts. At least the improved visibility of the subject may save a few engines from here on out.
My car has 1 1/2 years left on the extended warranty and it had elevated lead at 23, 2 oil changes ago. It was down within normal parameters at the next oil change but i am concerned that could be because it wore off.
335xi is offline
post #53 of 785 Old 12th October 2013, 05:29 AM
SuckaGDog
SuckaGDog's Avatar
This whole rod bearing thing I am sure has taken a toll on owners on this board. I know I've thought about running alternative oils for the past week or so. Along with researching what can be done to fix/ban-aid the problem, etc. I am simply sick of it, honestly! lol. I spoke with the shop foremens at my work and upper shop management no one has heard ANYTHING about this new oil recommendation. Most likely because BMW hasn't issued a bulletin about it.
This ish really sucks. Looks like I shall be continuing to send in my oil for analysis to Blackstone Labs for the rest of my ownership lol.
Anyone get lead levels in the 20's PPM range before? Just curious.
Evolve Stage #3 E60 M5
Performance
-Evolve Stage 3 Header Tune
-De-cat Stock Headers
-Eurocharged Pulley
-RPi GT Exhaust Sec 1-3
-RPi Scoops, BMC Filters, Block Off Plates
-RPi SV1 Oil Cooler
Handling
-Dinan Stage 1 Suspension
-Carbotech Bobcat 1521 Brake Pads
-RDSport Sway Bars
-StopTech SS brake lines
Exterior/Interior
-Weisslicht LED License Plate lights and White LED Side Markers
-Republic Wrap Custom Headlights with Orion V4s
-Color Matched Kidney Grills, Matte Black Side Vents
-Sprint Booster V2
-Trinty Autosport Interior LED's
-iND Painted ///M5 Badge
-LCI Tailights w/ Bruce Miranda V6.0
-BSW Center Speaker Upgrade
-Pedal Haus Black Anodized Pedals
-DCT Motorsports CF Steering Wheel
-HRE P40S Brushed Tinted Clear, Wrapped in PSS.
Front: 20X9 (255/35/20)
Rear: 20X10.5 (295/30/20)
-Custom Coding by Alex@Alpine
Countermeasures
-Blinder M47 Laser Jammers
-V1 Hardwire
Pictures
2014 Photos
2015 Photos
SuckaGDog is offline
post #54 of 785 Old 12th October 2013, 05:53 AM
ACG
ACG's Avatar
I have put 2k miles on my new engine and checked the oil level and it still reads .8L
Before I would have had to add a quart in the next 500 miles.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights
Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions.
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / HUD/ Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, black on black
ACG is offline
post #55 of 785 Old 12th October 2013, 01:37 PM
tjav8b
I am not sure if it is a good or bad thing but I never have to add oil between 5k oil changes using TWS. 32k total miles.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #56 of 785 Old 12th October 2013, 02:00 PM
bayerischemotor
bayerischemotor's Avatar
Looking at these pics again, I'm happy my car in on Raikku's lift to get this **** sorted.
X5M
To be Evolved
Gone is the M5....
° Evolve Alpha N Stage 3
° Evolve Long tube headers
° Evolve Carbon fibre intakes
° 100 cell race cats
° RPi ST pulley kit
° Supersprint exhaust and resonator
bayerischemotor is offline
post #57 of 785 Old 12th October 2013, 02:38 PM
PRM5
PRM5's Avatar
PRM5 is offline
post #58 of 785 Old 12th October 2013, 03:05 PM
tjav8b
Originally Posted by PRM5 View Post
Oil consumption has nothing to do with rod bearing wear.
Agreed. I do think it is odd though that some of these engines will burn alot of oil and some will burn very little. Mine stopped burning oil at 20k miles. Before that I had to add a liter between changes.
07' M5 SILVER/BLACK
ESS VT2
tjav8b is offline
post #59 of 785 Old 12th October 2013, 03:09 PM Thread Starter
jcolley
m5board.com Site Sponsors
jcolley's Avatar
You couldn't be in better hands. Post the pics here.
jcolley is offline
post #60 of 785 Old 12th October 2013, 03:58 PM
bayerischemotor
I know!
Yes, he'll take pics, and I'll take pics.
It's a double treat for me, as I'm not only getting new bearings but also long tube headers!
Can't wait! Hurry up Raikku will you!
X5M
To be Evolved
Gone is the M5....
° RPi ST pulley kit
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Bearing Rod Changed with Pictures ! S85 Duschanio E60 M5 and E61 M5 Touring Discussion 235 2nd September 2014 07:05 AM
rod bearing messier781 E39 M5 and E52 Z8 Discussion 9 24th March 2014 05:49 AM
Bearing Rod Changed with Pictures #2 - S85 TomekW E60 M5 and E61 M5 Touring Discussion 14 24th August 2013 01:05 PM
Rod Bearing Tolerance? Rod Bearing Advice? lefebv19 E39 M5 and E52 Z8 Discussion 21 17th August 2011 04:36 AM
Comprehensive Header Thread CU'09 E39 M5 and E52 Z8 Discussion 9 21st November 2009 05:40 PM
