Comprehensive S85 Rod Bearing Picture Thread - Page 3 - BMW M5 Forum and M6 Forums
 231Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
post #21 of 787 Old 6th September 2013, 09:14 PM
ACG
ACG's Avatar
Originally Posted by SoCaLE39 View Post
So after some reading it still appears that the clearances are too tight and the only way to reduce wear is to run thinner oil for the street and stick with 10W60 for the track. So technically, the only way to increase tolerances based on currently available bearing options is to machine the journals.
So my question to Paul would be, were your journals machined at all to accept higher clearances?
My journals were tweaked a little but to create less friction and thus less issues with wear there were special processes done to the actual bearings too.
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights
Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions.
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / HUD/ Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, black on black
ACG is offline
post #22 of 787 Old 6th September 2013, 10:10 PM
TZ04XJR
TZ04XJR's Avatar
2006 SMG (very late build)
Bought with 38k miles
Currently 68k miles
Oil changes every 7k miles
TWS 10w-60
#8 is the broken bearing.
Name:	7 & 8.jpg
Name:	8 broken.jpg
Name:	9 & 10.jpg
Name:	1 & 2 crank.jpg
Name:	3 & 4 crank.jpg
Name:	5 & 6 crank.jpg
Name:	7 & 8 crank.jpg
Name:	9  & 10 crank 2.jpg
E60 M5 SMG - Sapphire Black exterior, Black interior, Full leather, Ventilated comfort seats, Aluminum trim, Alcantara Headliner, Matte Black front/side grills, 20% window tint, Black Plasti Dipped Wheels, Hardwired 9500ix, RPI scoops(Red), Block off plates, BMC filters (c/f delete), Evolve-R Stage 2 Tune, Muffler & Secondary Cat Delete
P500s S6 DSC OFF- ALL DAY, EVERY DAY.. Unless it's wet out
Daily:
2008 C63 AMG, Black, Stock fo now..
Past:
2009 Cadillac CTS-V, Black Raven Sedan, Auto, Recaros
2004 Jaguar XJR- Platinum Silver Metallic exterior, Charcoal interior
2001 Jaguar XJR- Platinum Silver Metallic exterior, Charcoal interior
TZ04XJR is offline
post #23 of 787 Old 6th September 2013, 10:14 PM
SoCaLE39
SoCaLE39's Avatar
Were you getting an indication that the bearing was going? Knocking sounds?
2006 M5 (Jarvis) - Sapphire Black / Silverstone
RPI Scoops & Block Off Plates BMC Filters | Varrstoen ES1 20x10 20x11 Michelin SS | BC Racing Coilovers & Swift Springs | DINAN Section 3 Exhaust | LCI Tails Bruce V6.1 Cables | Matte Side and Front Grills | BSW Center Channel Speaker | Angel iBright V3 Angel Eyes | OEM iPod Interface
E60 M5 Carbon Vinyl Trunk Spoiler Accents - Click Here
SoCaLE39 is offline
post #24 of 787 Old 6th September 2013, 10:14 PM
ACG
ACG's Avatar
Worst I have seen thus far on here.
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #25 of 787 Old 6th September 2013, 10:17 PM Thread Starter
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Currently 68k miles
TWS 10w-60
TZ, this was a corrective and not preventive job, right? Was this the first look of your rabbit-hole nightmare?
Sent from AutoGuide.com Free App
jcolley is online now
post #26 of 787 Old 6th September 2013, 10:26 PM
TZ04XJR
TZ04XJR's Avatar
No indication. Vanos faults alerted me that I had a problem..
Their pretty bad.. Hopefully these pics will give other owners motivation to replace theirs every 50k miles.
These are pics from my old block.. I got a replacement motor instead of replacing the bearings per my dealerships recommendation.
-TZ
Daily:
Past:
TZ04XJR is offline
post #27 of 787 Old 7th September 2013, 10:42 AM
chrishkm5
-TZ[/QUOTE]
What did you end up doing with your old engine ??
Will post pictures of my RB when I can but they were also in really bad shape with only 62000KM on the clock, I'm the 4 owner of the car so really not sure about how the maintenance was being done before but under me I was changing oil and filter every 5000Km... (FYI it's really hard to drive a lot and long distance in HK..)
Chris
chrishkm5 is offline
post #28 of 787 Old 7th September 2013, 10:44 AM
chrishkm5
I bought a replacement engine that just arrived from a 2009 M6 and I'm really considering changing the road bearing as a prevention ASAP to avoid an other engine failure....
Also I'm looking for suggestion on what to do with my failed engine.
Chris
post #29 of 787 Old 7th September 2013, 04:28 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Smart...I would. How many miles on the replacement motor? I think we'd all want to see the replacement motor's bearings.
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =133,000 miles with no RCOD and counting ...just saying...
2007 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing (Blanton) 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PSS 255/40/19 and 295/35/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; CKS coils w/swift springs, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; RedLine B/S RDR off, F/R G1W-H, ALP w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 miles!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Euro RestoMod track car: caged, 6 point FIA harness, FIA Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; z3 1.9L ssk and ZHP shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x8 BBS RK w/Dunlop StarSpec II; undergoing Euro restoration, building the sub 2,400lb e28 CSL ///Motorsport never built. 5.71lbs/hp
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 228,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014 to a good home.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service autohausfrankfurt.com/ my local Dinan supplier trinityautosport.com my local drug dealer for my crack habit
fastattackmotorsports.com because JColley!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #30 of 787 Old 24th September 2013, 07:10 PM Thread Starter
jcolley
jcolley's Avatar
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
Bearing Rod Changed with Pictures ! S85 Duschanio E60 M5 and E61 M5 Touring Discussion 235 2nd September 2014 07:05 AM
rod bearing messier781 E39 M5 and E52 Z8 Discussion 9 24th March 2014 05:49 AM
Bearing Rod Changed with Pictures #2 - S85 TomekW E60 M5 and E61 M5 Touring Discussion 14 24th August 2013 01:05 PM
Rod Bearing Tolerance? Rod Bearing Advice? lefebv19 E39 M5 and E52 Z8 Discussion 21 17th August 2011 04:36 AM
Comprehensive Header Thread CU'09 E39 M5 and E52 Z8 Discussion 9 21st November 2009 05:40 PM
