• Latest threads
    • Custom feed
      • Updates
        Poll: SMG, Auto or 7 speed manual?
        Poll Options
        Old 10th March 2003, 18:44   #1 (permalink)
        Gus
        Gus's Avatar
        smg, auto or 7 (yes, 7!) speed manual
        I have heard that the 7 speed may be an option on the E60 - the more we push, the more likely it will happen!
        Gus is offline
        Old 10th March 2003, 19:20   #2 (permalink)
        kees
        Administrator
        Why would you want to push a 7-speed manual? Doesn't it make more sense just to get an engine with enough torque to be able to deliver in combination with a 6-speed manual?
        As it stands you can't feasibly max out 3rd, 4th, 5th or 6th gear in most countries without already being highly illegal.
        kees is offline
        Old 10th March 2003, 19:23   #3 (permalink)
        Gus
        Gus's Avatar
        If they are prepared to allow any manual shift I'll be a supporter - don't know why a 7 speed has been proposed though!
        Gus is offline
        Old 10th March 2003, 19:32   #4 (permalink)
        zzzzMD
        zzzzMD's Avatar
        I agree with keesdh. If given a choice between auto and manual, I would naturally choose manual, but 7-speed seems eminently unnecessary with a 500+ hp engine with good torque. Rowing the gears is great, but the ratios would be so close with a 7-speed, that you would constantly be red-lining the engine, or be much higher in the rev band without wanting it. If the car were auto only, shorter gearing might be better, i.e., 6-speed auto.
        ZZZZMD
        zzzzMD is offline
        Old 10th March 2003, 21:02   #5 (permalink)
        Hutzal
        Hutzal's Avatar
        i read somewhere that the 7th gear would serve as an overdrive gear for highway driving...Mabey ME could elaborate on this more.
        Cheers,
        Robb Hutzal
        M5 is the show
        Hutzal is offline
        Old 11th March 2003, 01:28   #6 (permalink)
        PhilSeastrand
        PhilSeastrand's Avatar
        Send a message via MSN to PhilSeastrand Send a message via Yahoo to PhilSeastrand
        I bet we could find articles written when 6-speed transmissions become popular about why you don't need 6 speeds. Likewise for 5-speeds, 4-speeds, etc.
        At some point it does become too much, I just don't know when that point is. For "automatic" systems, the more gears you have the better the computer can choose the most optimum gear. That's why the CVT is starting to become popular. I suspect in a few years, CVT will be the only "automatic" transmission found.
        Phil
        01 M5 Silverstone/Silverstone
        04 Honda Pilot
        02 Indi Blue Mini Cooper (sold )
        PhilSeastrand is offline
        Old 11th March 2003, 01:49   #7 (permalink)
        Racerboy
        The M5's sixth gear is already an overdrive, I think it is like a .80 or thereabouts. Why you would want two over drives is beyond me and why you need 6 gears at or above 1:1 in a street sedan makes no sense at all. In the Veyron or the Enzo, cars capable of speeds in excess of 200mph I could see a 7spd (sequentials), but not in the M5. Just my 2 cents.
        Racerboy is offline
        Old 11th March 2003, 02:27   #8 (permalink)
        DoctorV8
        DoctorV8's Avatar
        6th is a 0.83:1 ratio, and the rear end is 3.15:1.
        The M5 revs at about 2500 rpm at 80 mph. It gets only 21 mpg on the highway.
        A similarly powered Corvette has a 0.75:1 fifth and 0.50 sixth with a 3.42 rear end. At 80 mph it revs at 1700 rpm and manages 28-30 mpg! Sure, you have to downshift to pass, but it's nice to cruise at 100 mph with the tach reading 2100 rpm.
        I'm all for a second overdrive.
        2001 M5 Black/Black, Vortech SQ, Supersprint headers, Tubi, Brembos, KW Variant 3, Dinan wheels/monoballs/S3 clutch/S3 rear subframe, etc....
        2005 CL65 V12TT Black/charcoal, 550 rwhp/670 ft lbs, Reus audio
        2005 Ford GT #1119, silver sans stripe, Whipple, 20 psi
        2006 C6 Z06, Stage II cam, Ported TB, Kooks headers, Air Charger, Exhaust valve switch
        2004 C5 Corvette, F55 Magnetic ride, Pioneer AVIC D1, ATI D1SC Procharger, minitub, Fikse Profil5
        1990 C4 Corvette ZR-1 DOHC Lingenfelter 415 cid stroker, coilovers, Wilwood brakes, Fikse FM5
        1991 Mustang LX Coupe 331 cid, Incon TT, Griggs, 6 speed, ABS, Big Stuff 3 w/coil on plug ignition
        1978 Lincoln Mark V 460 TT/EFI behemoth project
        etc...
        DoctorV8 is offline
        Old 11th March 2003, 03:42   #9 (permalink)
        Finality
        Finality's Avatar
        Why not simply make the single OD gear very tall? Something like 0.60? Power drop too severe?
        996TT dreamer
        Finality is offline
        Old 11th March 2003, 21:06   #10 (permalink)
        Enigma
        Enigma's Avatar
        For an SMG 7 gears = good
        For a manual 7 gears = more work
        Currently the M3 and M5 lose some time around the track because gears 2,3,4 are spaced too far apart. You want to keep the engine running as close to its HP peak as you can at all times on a track.
        Again the M is a performance car not some big torque buick. If you are too lazy to shift to get the engine into its powerband then get a regular car with an auto.
        Enigma is offline
        Old 11th March 2003, 22:22   #11 (permalink)
        zzzzMD
        zzzzMD's Avatar
        I think that the engine would be in the fattest part of the torque curve more often with more closely-spaced gearing, as in 7-spd manual, but mileage would probably suffer being higher in the rev range more of the time. With sixth being another drive gear, and not an overdrive, I'm not sure how the balance would play out. It WOULD probably be more annoying on the Garden State Parkway on a Friday afternoon.
        ZZZZMD
        zzzzMD is offline
        Old 11th March 2003, 22:24   #12 (permalink)
        Enigma
        Enigma's Avatar
