Windows do not operate after Passenger rear view mirror broken off - BMW M5 Forum and M6 Forums
post #1 of 7 Old 22nd May 2013, 12:36 AM Thread Starter
nathan@needel.net
The passenger rear view mirror was snapped/broken off my 2008 E60 M5. With the exception of the passenger window all the other windows do not work. The driver window control panel does not work either.
Is there a can bus fuse that may have blown when the mirror was broken? The 3 wires to the mirror are not shorting to anything now but perhaps they did when the mirror came off?
I ordered a replacement mirror from a parted out car of the same year, model and color ($625 ouch). What kind of programming will I need to do?
Thank you for any advice. Nathan 813 426 3549
nathan@needel.net is offline
post #2 of 7 Old 22nd May 2013, 12:38 AM Thread Starter
nathan@needel.net
Oh, I forgot to mention that all the windows are down by operating them from the wireless key fob.
post #3 of 7 Old 22nd May 2013, 01:40 AM
avlnch
Moderator Emeritus
avlnch's Avatar
Try to reinitialize the windows to regain function. To do this, follow the below instructions exactly.
Initialization
Following replacement of a power window motor or a door module and following every repair to the power window mechanical system, an initialization must be carried out. The initialization serves to adapt the anti-trapping protection to the power window system. The initialization procedure is divided into the functions standardization and learning the characteristic curve.
In the case of standardization, the mechanical end stops of the power window are learned.
In the case of learning the characteristic curve, the mechanical closing forces in the power window are recorded.
The initialization must always by run with the power window switch on each door!
Control procedure for initialization:
Press the window 'open' switch beyond the second switching position. When the window has reached the lower final position, operate the switch for at least 15 seconds but not longer than 25 seconds.
Then let go of the button and immediately pull the switch beyond the 'close window' position. Do not let go of the switch!
The window now moves into the top final position, stops, then moves to the lower final position, stops again and then moves back to the upper final position. The switch must be held in the "pulled beyond engaging point" position during the entire procedure.
Once the window has reached the upper final position, the initialisation is complete.
Important!
It must be ensured that there is on-board supply voltage of at least 12 V during initialisation, otherwise initialisation of the power window is not possible.
The anti-trapping protection has no function during the entire initialization procedure.
Emergency operation
If there is no valid characteristic curve, the one-touch closing function is unavailable. If there is no standardization, the Automatic Open function is also disabled. In this case, the window only moves around 2 cm in the desired direction with each press of the button.
2013 BMW ///M5 INDIVIDUAL {Frozen Black/Amaro Brown/Amaro Brown Alcantara/Piano Black Trim/Contrast Stitching}
~Mods: Akrapovic Exhaust, OEM Charcoal Filter Delete, P3 Vent Gauge, DINAN Pedals
~Mods: BMW Individual Exterior Equipment, Frozen Black Reflectors
Other Vehicles: '12 MERC S63 AMG [WHITE], '11 MERC S65 AMG [BLUE]
Previous Vehicles: '10 INDIVIDUAL BMW M5, '09 MERC S65 AMG, '08 BMW M5, '08 MERC S63 AMG, '07 BMW ALPINA B7, '06 RANGEROVER S/C
avlnch is offline
The Following User Says Thank You to avlnch For This Useful Post:
Clyde (22nd May 2013)
post #4 of 7 Old 22nd May 2013, 03:57 AM Thread Starter
nathan@needel.net
Thanks for the advice. Turns out there was a Pbus short and 2 blown fuses that are not properly marked in the trunk fuse guide. I went thru every fuse in the car. The two that were blown were under the glove box.
Now I get into taking the door card off.
post #5 of 7 Old 27th May 2013, 07:46 AM
avlnch
Moderator Emeritus
avlnch's Avatar
Good to hear you found the cause.
avlnch is offline
post #6 of 7 Old 9th February 2017, 05:15 AM
Texasgrego
Texasgrego's Avatar
Help needed: Same but different
Driver side mirror broken off while car running.
Driver door mirror/window/shade controls quit working instantly when it happened.
Removed door panel and replaced mirror and glass with new OEM, without incident.
Did not appear wiring was "pulled" past sealing grommet.
Door controls still not working.
Ribbon connection to glass new and ok. Mirror connection to wiring harness in door new and ok.
All fuses have continuity. . Puddle light driver door working.
Buttons do nothing, cannot begin window initialization as suggested above.
Disconnected battery again after install for 8 hours to see if LIN bus was freaked out by sudden loss and might settle , but no dice.
Don't know where to turn ?????
Many searches yield people throwing door module (TMFA) or driver switch block module( SBFA) at similar problem with no avail.
Software will actuate the window, but not the mirrors and does not "recognize" door or airbag modules?
There are no fault codes or shadow faults.
The FOB will operate the windows including the drivers door, so there is communication between CAS-SGM and the door module for sure.
Thanks for suggestions.
Texasgrego is offline
post #7 of 7 Old 16th February 2017, 06:07 PM
Texasgrego
Texasgrego's Avatar
Update
Fuse 32 10A
Visual inspection (passed or passed over on multimeter test) yielded blown fuse.
passenger side rear view mirror dipping on Reverse mavster E60 M5 and E61 M5 Touring Discussion 18 24th October 2012 03:29 PM
Valentine One & Escort Rear View Mirror Systems from Radar-Mirror.com RaceMX-M3 M6 E63 Group Buy and Sponsor Discussion and Offerings 1 3rd April 2011 05:16 AM
Valentine One & Escort Rear View Mirror Systems from Radar-Mirror.com RaceMX-M3 M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 26 2nd April 2011 11:30 PM
Passenger sideview mirror broken.. dgriner E39 M5 and E52 Z8 Discussion 2 30th March 2006 01:45 AM
Passenger Rear View Mirror Jim Catington E39 M5 and E52 Z8 Discussion 4 12th November 2000 11:22 PM
