Open Brakes Ducts Work !!! - BMW M5 Forum and M6 Forums
Like Tree1Likes
Old 26th March 2001, 18:54   #1
Parkerfe
I had my M5 at Road Atlanta on 3-24-01 for the first time since opening up the brake ducts. Believe me, it makes a substantial difference. When I was at Road Atlanta back in November 2000 the brakes would fade to almost nothing after 4 to 5 laps. This time, I ran the car even harder and experience no brake fad whatsoever. The only thing I have done is open up the brake ducts and put SuperBlue brake fluid in. Stock pads and rotors. Give it a try. it works !
Parkerfe is offline   Reply With Quote
Old 26th March 2001, 18:58   #2
greg
greg's Avatar
Garage: 2000 Anthracite
Post
Nothing like a hands-on, before and after comparison. Thanks, Parkerfe. I think this is the most important upgrade you can do if you want to track your car.
Out of curiosity, how did the outside temperature compare between your before and after runs?
greg is offline   Reply With Quote
Old 26th March 2001, 19:09   #3
c4m5
Garage: 2000 Alpine White #2
Could you post a step by step how to do it as well as all the correct part numbers? Thank you in advance.///
D. Guilburt
c4m5 is offline   Reply With Quote
Old 26th March 2001, 21:12   #4
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
Post
C4M5-
This topic's nearly been beat to death. For a pretty comprehensive summary (including part numbers) see: http://www.bmwm5.com/ubb/Forum1/HTML/003032.html
Also, check these out for more of the history/rationale:
http://albums.photopoint.com/j/Album...0244&a=8849636 http://www.bmwm5.com/ubb/Forum1/HTML/002290.html http://www.bmwm5.com/ubb/Forum1/HTML/002631.html
101421
Teutonaddict is offline   Reply With Quote
Old 26th March 2001, 21:19   #5
Teutonaddict
Post
I gotta agree with Frank-- there were three of us M5ers at Road Atlanta on Saturday, and nobody had issues with fade! My first time on that track (last April, at 1400 miles) I encountered fade (pedal-to-floor! kind) four laps into my third session. Now, by opening up the ducts, I had no such problems. I also upgraded fluid (SuperBlue), front pads (Mintex C-Tech) and ran Goodridge stainless lines. Bottom line: more air to the rotors, and a higher T fluid works wonders!
It's interesting to note that we had three stages of cosmetic appeal: bmurphy had the all-out body-colored splitter, straight out of the M-Technic book (sharp!); I had the M-Technic 'web insert' installed, but no splitter (still workin' on that one, DrKev!), and Parkerfe had the OEM grill drilled out to feed the channels.
BTW, bmurphy had the Stage II Dinan suspension set-up, and he was experiencing considerably less oversteer (per the cornerworkers and instructors on Turn 7) than either Frank or I. Sounds like that could be next....
101421
Old 27th March 2001, 02:07   #6
Parkerfe
Post
C4M5, The way I done it involves no new parts. I drilled multiple holes in the outside blanked out panels on each side of the grill. One hole per square. I then turned the wheel all the way to the side to get to the front panel of the wheel well. I then drilled several holes directly behind the existing duct in order to get a small keyhold saw in there to cut it out to match the size of the duct. Thats it. You can now through the holes in the grill and see down the existing ducts directly to the brake rotors. It is a straight shot. The whole job took less than one hour.
Old 27th March 2001, 02:37   #7
btr
Post
Hey Parkerfe...
Any chance that u took a few photos of the whole process??
btr is offline   Reply With Quote
Old 27th March 2001, 03:00   #8
Parkerfe
Post
Sorry, no photos
Old 27th March 2001, 03:18   #9
bobafett
bobafett's Avatar
Post
Instead of doing it the "legit" way, what about just taking drilling holes in the plates, as well as cutting out holes in the panels next to the foglights, and then taking flex tubing and routing it directly to the brake area?
Personally I think it would be easier and you don't even have to pull the bumper off. Opinions?
--Dan
bobafett is offline   Reply With Quote
Old 27th March 2001, 07:02   #10
GradX
GradX's Avatar
Garage: 2000 Carbon Black M5 - GA Plate: M5POWR
Post
Sorry Guys, my car wasn't ready in time due to some issues with replacing my TriFlo exhaust system. The jerks at the dealership thought it was a stock system even when I told them that it was a TriFlo exhaust they needed to replace. That delayed everything a few days but as a result I have a brand new exhaust on both sides (all nice and shiny again). B&B will not fabricate just one side of the exhaust so my insurance had to pay for a completely new exhaust!
Anyhow, is there going to be a general Atlanta meet? Motorbahn in Roswell is having their raffle for a 2001 M3 at the end of this month, $100/ticket, max of 750 tickets to be sold (only 300 or so sold since the Petit Lemans), and the raffle goes on regardless! We could meet there!
GradX is offline   Reply With Quote
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
QUESTION: Does anyone have the DINAN BRAKES and if so......... FAST 5 E39 M5 and E52 Z8 Discussion 19 26th April 2006 20:11
Brake Rotor Issue Joe Lapicki E39 M5 and E52 Z8 Discussion 29 26th December 2002 15:42
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49
