Rough Idle - stalls - - BMW M5 Forum and M6 Forums
post #1 of 9 Old 14th February 2013, 06:29 AM Thread Starter
06m5e60
Hello!
Plugs replaced - recently
However, sometimes she idles badly.... Tries to stall, sometimes stalls but turns back on just fine. No check engine no codes just plain bad idle.
sometimes coming to a complete stop she stalls again no check engine turns back on like nothing happen!
Any ideas?
06m5e60 is offline
post #2 of 9 Old 14th February 2013, 06:41 AM
TZ04XJR
TZ04XJR's Avatar
Have you had it scanned for error codes? Sometimes you will have faults present that do not necessarily throw CEL on the dash.. I would get it scanned if you haven't already and post any errors up here for us to see.
If I had to just "guess" I'd lead towards a bad Idle Actuator or voltage regulator..
-TZ
E60 M5 SMG - Sapphire Black exterior, Black interior, Full leather, Ventilated comfort seats, Aluminum trim, Alcantara Headliner, Matte Black front/side grills, 20% window tint, Black Plasti Dipped Wheels, Hardwired 9500ix, RPI scoops(Red), Block off plates, BMC filters (c/f delete), Evolve-R Stage 2 Tune, Muffler & Secondary Cat Delete
P500s S6 DSC OFF- ALL DAY, EVERY DAY.. Unless it's wet out
Daily:
2008 C63 AMG, Black, Stock fo now..
Past:
2009 Cadillac CTS-V, Black Raven Sedan, Auto, Recaros
2004 Jaguar XJR- Platinum Silver Metallic exterior, Charcoal interior
2001 Jaguar XJR- Platinum Silver Metallic exterior, Charcoal interior
TZ04XJR is offline
The Following User Says Thank You to TZ04XJR For This Useful Post:
06m5e60 (14th February 2013)
post #3 of 9 Old 14th February 2013, 06:49 AM Thread Starter
06m5e60
06m5e60 is offline
post #4 of 9 Old 14th February 2013, 06:53 AM
TZ04XJR
TZ04XJR's Avatar
No problem.. Good Luck!
-TZ
Daily:
Past:
TZ04XJR is offline
post #5 of 9 Old 14th February 2013, 02:00 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Vacuum leak is a possibility as well. There are two large (1" ish) hoses leading from the bottom front of the intake plenums down underneath to the idle actuators. I just found the hose clamps on mine weren't even tightened down from the last person to work on it (not me).
However, these idle actuators are just as failure prone (if not more so) than throttle actuators and the old SMG pump motors.
jcolley is offline
post #6 of 9 Old 14th February 2013, 05:04 PM
cobratom
Sounds to me like you may have a bad EKTP (Fuel Pump module). I would get the car scanned, and find someone has access to a autologic, do a tank leak test.
cobratom is offline
post #7 of 9 Old 20th March 2013, 04:12 AM
Variable
Variable's Avatar
Same problem here. I'm leaning toward the issue being a bad cat converter though.
2007 M5 Black Sapphire Metallic
-----------MODS------------------
20" Ace Alloy Convex w/Michelin PSS
Active Autowerke full exhaust
RPI Ram Air Intake Scoops (yellow!)
RPI Blockoff plates
K&N intake filters
ESS E-Flash ECU tune
Euro SMG software
Led Turnsignals
Black Roundels
Black/White emblems
LCI Tailights with bruce cables
Powder coated calipers (yellow!)
Trinity Autosport 17pc smd light kit
Full 5% tint.
------Wishlist-------------------------
BC Coilovers
Variable is offline
post #8 of 9 Old 21st March 2013, 02:36 AM
allmotor_2000
allmotor_2000 is offline
post #9 of 9 Old 21st March 2013, 05:52 AM
Smoorebmw
Smoorebmw's Avatar
Originally Posted by allmotor_2000 View Post
I have a working idle actuator if someone wants it....
I call dibs!!! driver side!
Current:
2013 BMW M5 - B&O Sound - Piano Black trim - 2 toned grey/black interior....(MOD's are coming)
2016 M3 - Fully Loaded - GF's car
Grave Yard:
2014 BMW 640i
2007 BMW 335i
2006 BMW M5
2003 Infinti G35
2002 BMW 740i
2002 CBR 954rr
2000 BMW 540i
2000 BMW 328i
Smoorebmw is offline
Car stalls at idle coming to a stop, already replaced mafs and fuel pump Gouki E39 M5 and E52 Z8 Discussion 96 21st November 2016 10:33 PM
Please help. I have rough idle First e28 M5 E34 M5 Discussion 7 11th April 2010 03:37 AM
Idle surge + SES light + car Stalls Ottoman E39 M5 and E52 Z8 Discussion 6 29th January 2008 02:08 PM
Rough Idle/rough running at low revs Miksta E34 M5 Discussion 4 27th October 2006 08:56 AM
