When to change spark plugs? Car has no interval - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 16 Old 19th January 2013, 06:11 AM Thread Starter
lumi
Hey guys, as some of you might know, I just bought a 2009 CPO M5 with 31K on it.
How do I know if the dealer changed my plugs or when or if they are due? I checked in the service interval in the idrive and it gave no interval for spark plugs.
Thanks.
lumi is offline
post #2 of 16 Old 19th January 2013, 06:22 AM
ACG
ACG's Avatar
Mine does, I actually got a message that mine needed changing in so many miles.
Did a quick search and you can see from this thread how you reset the interval once plugs are changed.
changing spark plugs
ESS Supercharged VT2-650
Custom ESS Alpha N Tune
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
RPI Jet Hot Coated Headers
10.1:1 Low Compression Engine Build / Mahle Custom Pistons / Carrillo Rods / Custom Fuel System / Custom Rod Bearings.
KW V3 Coilovers
Hartge Rep Urethane Front Lip
AC Schnitzer Roof Spoiler
Matte Black Kidneys Grills / Gloss Black Side Gills / Gloss Black Rear M5 Emblem / Black/White CF Hood &Trunk Roundel / Rear Bumper Mesh / M5 Puddle lights
Electric Fold Away Front License Plate Frame
CF Rear Diffuser / CF Side Skirt Extensions /CF Rear Side Extensions.
SS Handbrake Handle/Pedals
Hardwired Valentine 1
Custom SC Kit Color Scheme.
Soft Close Doors / HUD/ Active Seats.
The journey continues......
RIDES:
2015 Jaguar F Type R, black on black
ACG is offline
post #3 of 16 Old 19th January 2013, 01:17 PM
B767capt
B767capt's Avatar
I think the newer cars dont have spark plugs updates in idrive. That might have changed with LCI, I don't know. The warranty manual says 37K for spark plug change along with trans and rear end oil change every 3rd oil change.
B767capt is offline
post #4 of 16 Old 19th January 2013, 01:57 PM
mdyaman
mdyaman's Avatar
Call or go to the dealer, give them the VIN of your car, have them run the service history and see if your spark plugs have been changed. If they have, you should changed every 30-60K miles depending on your car driving habits. the idrive will tell you, eventually, when the service is becoming due.
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops. 12.5mm TMS Spacers.
mdyaman is offline
post #5 of 16 Old 19th January 2013, 03:05 PM
jram
I changed mine at 34k and they looked like they needed changing. I'll probably change every 30k if that helps.
jram is offline
post #6 of 16 Old 19th January 2013, 03:10 PM Thread Starter
lumi
Yea my car does not have spark plug service warning. I even plugged my Bavarian technic cable in, and shows all the services I can reset, and no spark plugs. Thanks.
Thanks for that, all the dealer gave me was the manual, nothing else, so I wasn't sure of the maintenance intervals, thanks!!!
Yes, great idea, im gonna go next week to my dealer while I am still under full warranty and have them check to see if the plugs and all the services have been done.
Yea, I did oil, cabin, air filter, and now im gonna make sure the dealer, or ill DIY change the plugs since im at 31K. Thanks.
lumi is offline
post #7 of 16 Old 19th January 2013, 03:23 PM
B767capt
B767capt's Avatar
You can download the warranty manual pdf from BMW USA onto your computer for reference. Here is the 2008.
B767capt is offline
The Following User Says Thank You to B767capt For This Useful Post:
lumi (19th January 2013)
post #8 of 16 Old 19th January 2013, 10:05 PM Thread Starter
lumi
Thanks! Your the man
lumi is offline
post #9 of 16 Old 19th January 2013, 11:14 PM
ACG
ACG's Avatar
Bummer that newer models don't have this as I thought it was cool when it told me to change mine.
Sprint Booster V2
RPI GTS Exhaust
RPI SV1 Oil Cooler
KW V3 Coilovers
RIDES:
ACG is offline
post #10 of 16 Old 20th January 2013, 01:42 AM Thread Starter
lumi
Yea my 2010 335i had it. But since im under full warranty i guess the dealer will do it for me.
lumi is offline
HELP! replace spark plugs- car doesnt want to run prodigyracer19 E60 M5 and E61 M5 Touring Discussion 21 14th November 2016 06:54 PM
$400 to change spark plugs Yofranke E39 M5 and E52 Z8 Discussion 46 28th February 2010 07:01 PM
how long does it take to change spark plugs? gherardini E39 M5 and E52 Z8 Discussion 17 10th November 2007 07:26 AM
Another reason to change the spark plugs. vics E39 M5 and E52 Z8 Discussion 10 24th March 2006 06:16 AM
Interval for Spark Plugs lsdvm E39 M5 and E52 Z8 Discussion 3 1st February 2006 05:25 AM
