ISTA/D and ICOM emulator - BMW M5 Forum and M6 Forums
 5Likes
post #1 of 59 Old 4th December 2012, 03:07 AM Thread Starter
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Probably not too many people know what this is, but if you've delved much into the programming world with our cars, you've heard DIS, INPA, EDIABAS, NCSExpert, etc.
Borrowed from bmwcoding.com:
Dealership Level Software
3rd Generation
ISTA (Integrated Service Technical Application) - The dealership system used to diagnose and program cars, it's made up of many smaller parts outlined below.
ISTA/D (Integrated Service Technical Application - Diagnostics) - The diagnostics part of ISTA, used to perform diagnostics and service functions
ISTA/P (Integrated Service Technical Application - Programming) - The programming/coding part of ISTA, used to perform programming/coding of control units
ISID (Integrated Service Information Display) - Tablet-like computer which runs the ISTA/D application and is the gateway to the ISTA/P client application
ISSS (Integrated Service Software Station) - Server system (actually a desktop running as a server) which houses the ISTA/P server application and is responsible for programming and coding. It's controlled via the ISTA/P client application on the ISID.
ISIS (Integrated Service Information Server) - Server system which controls all other ISTA applications/hardware, it coordinates communication between all the parts of the ISTA system and is responsible for management of all ISTA software/hardware in the dealership network. Usually two are found at a dealership in a cluster configuration.
ISPS (Integrated Service Programming Server) - Successor to the ISSS starting with ISPI 3.0, BMW decided to make one of the ISIS servers a dedicated programming server since they saw no value with dual ISIS systems. Higher capacity than an ISSS system and will eventually phase out all ISSS systems in the future.
ISPI (Integrated Service Process Initiative) - Basically service packs to the ISTA infrastructure, currently at ISPI version 3.0.
ISAP (Integrated Service Access Point) - Managed wireless access point used by ICOM, ISID, IMIB systems to connect to the dealership network via wireless
IMIB (Integrated Measurement Interface Box) - Wireless system used to perform various measurements components of a vehicle, voltage, resistance, computerized oscilloscope.
ICOM (Integration Communication Optical Module) - ICOM is a communication device and constitutes the diagnostic interface to the vehicle. It is connected to the vehicle and can be linked to an ISID via a connection manager. Thus ISID can communicate with the vehicle, e.g. for automatic vehicle identification or for executing test programs.
1st and 2nd Generation
GT1 (Group Tester One) - Touchscreen computer used to run the DIS applications, hardware very similar to an IBM ThinkPad T30
DIS (Diagnostic Information System) - Software that runs on the GT1 hardware to perform diagnostics and programming. As part of the 1st generation system, DIS handled both diagnostics and programming up until DIS v44. Starting with DIS v45 programming was moved to the SSS, as part of the 2nd generation system.
SSS (Software Service Station) - Desktop computer used to run the Progman application, comes in various configurations with the most common being the SSSr5 and SSSr6 systems. r5 and r6 systems could also be upgraded to ISSS stations as part of the ISTA system. Usually the terms SSS and Progman are used interchangeably.
Progman - Programming software as part of the 2nd generation system which handles all programming and coding, known as CIP (Coding, Individualization and Programming). Last official version of Progman was v32, any version after that is a unofficial and known to cause issues.
Recently, someone figured out how to make an emulator for the ICOM hardware that would allow an ISTA/D or P installation to communicate to the car via a USB OBD II interface (such as this one) to be used. He sells the ISTA, ICOM, and ISIS installations as VMWare machines that will work with the ICOM emulator (he provides), an ENET cable (not sure what this one is yet), and of course any OEM BMW ICOM (if you have $7k to spend on one) or Chinese ICOM clone (such as this).
I just purchased from him via eBay and it works flawlessly. On a MacBook Air. That's right, BMW diagnostics, wiring diagrams, technical info, etc, right on my MacBook Air. The only problem I have is, the 11" screen doesn't allow all of the ISTA buttons to be shown, but just enough to use it.
He does not support Mac installations, so I had to figure out a little bit on my own, but with VMWare Fusion 5.02, it wasn't all that hard. Officially he supports PCs and overall, it might be easier, but I can't justify spending the money for one just to have this.
If you wonder what all of the codes mean when your car throws them, this is the exact software that the dealer will use to diagnose and repair your car when you take it to them.
I haven't done much with it yet, but will post some pics of the screenshots when I do.
For $100 (yes, an expensive, but well tested) USB OBD cable (with a D-CAN adapter) and $190, I can run my own SMG clutch teach-in, adaptation, etc.
Throttle actuator test? yep
Idle actuator test? yep
O2 sensor readings? yep
MAF intake volume? yep.
It has a bit of a learning curve, but I feel confident it will be far easier than INPA is and possible easier than using DIS.
***Disclaimer: Do not attempt to do any coding or programming without a power supply. Do NOT attempt to Program modules over an OBD cable, buy an ICOM for that if your car is newer than 3/2007 production date.***
Screw dealerships. This stuff isn't that hard and the more you get into it, the more fun you get to have with your car instead of someone else.
Jim
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
B767capt (21st December 2012), messex (6th December 2012)
post #2 of 59 Old 4th December 2012, 11:06 PM
Tj Hunter
Thanks for the info, very helpful reference for those looking to DIY.
Tj Hunter is offline
post #3 of 59 Old 5th December 2012, 04:56 PM Thread Starter
jcolley
jcolley's Avatar
jcolley is offline
post #4 of 59 Old 5th December 2012, 06:37 PM
WallyM5
WallyM5's Avatar
Jim,
That's excellent thank you for posting this. I am headed to ebay to grab one.
"An on ramp is a terrible thing to waste"
X5M
V1 Hardwired
Charcoal Filter Delete
K&N
Exhaust Cutouts
WallyM5 is offline
post #5 of 59 Old 5th December 2012, 07:36 PM
B767capt
B767capt's Avatar
Originally Posted by jcolley View Post
Come on B767Capt...you know you wanna post here...
Jim you're killing me. I'm so overwhelmed with this I don't have any time to read here. In fact I snuck on here while the ISSS is downloading. To everyone else, Jim has been very patient helping me out with emails on getting the software working. I'm halfway there. What a find Jim had on this ebay vendor. Looks very promising.
B767capt is offline
post #6 of 59 Old 5th December 2012, 07:54 PM Thread Starter
jcolley
jcolley's Avatar
A real (Marine proof) "How-To" is inbound Bill. It will just take a little time to write it up.
I just say in the car for an hour at lunch with my MacBook Air and played with ISTA/D.
Unfortunately, I think my impatience somewhere previous got the best of me and I may have force closed a Virtual Machine that wasn't shut down properly and corrupted the disk. It keeps giving me errors when I load test functions.
However, I was able to connect to the car, read the VIN and start the "module test" which shows a nice diagram of all the modules in the car and probes each to verify its existence and if any error codes are stored. I pulled all my fault codes and it automatically generated a "Test Plan" which the gives a list of tests to run and prioritizes them.
It has a mix of TIS like (think spaghetticoder) documents, wiring diagrams, connector pinout listings, and programmed test functions which it walks you through.
It almost seems dealer proof.
I keed, I keed!
Took some screenshots, but no camera on my iPhone, no tethering, and no Internet on my MacBook, so I will upload when I get home.
jcolley is offline
post #7 of 59 Old 5th December 2012, 08:03 PM
B767capt
B767capt's Avatar
B767capt is offline
post #8 of 59 Old 5th December 2012, 08:03 PM Thread Starter
jcolley
jcolley's Avatar
Pft, mama will get mad if she finds out I opted out of the extended warranty...
But, I like a challenge. If I wanted easy, I would have chosen surface ships instead if subs.
I don't get to take anything apart anymore or drive the boat, so this is my outlet.
jcolley is offline
post #9 of 59 Old 5th December 2012, 09:09 PM
335xi
Would the SMG Teach-In be considered coding? What I am asking is, can we use this to do diagnostics like SMG Teach-In, VANOS, etc with the d-can on post 3/2007 car?
Thx
335xi is offline
post #10 of 59 Old 5th December 2012, 09:21 PM
B767capt
B767capt's Avatar
This is the exact reason I bought it. To bleed the SMG hyd too. Haven't gotten there yet as I'm still installing it. I assume battery too. I got the 100.00 cable and the 190 software. For that price, it's worth a shot. Mine is an 03/2008 build. We'll know soon. I asked the eBay seller this same question and he said yes it will.
B767capt is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
ICOM - DC Area SMBowen USA Northeast Forum 0 28th November 2012 05:12 AM
lost voice control after ista/p update ukheman E60 M5 and E61 M5 Touring Discussion 6 27th March 2012 08:29 PM
Good source for ICOM Diagnostic Tool alibo70 E60 M5 and E61 M5 Touring Discussion 1 29th February 2012 09:31 PM
