DIY: M5/M6/S85 Recall, Tech Service Bulletin/Service Information Bulletin/Technical Docs Thread - One Stop Shop - BMW M5 Forum and M6 Forums
 22Likes
post #1 of 36 Old 4th November 2012, 06:08 PM Thread Starter
mdyaman
mdyaman's Avatar
Arrow M5/M6/S85 Recall, Tech Service Bulletin/Service Information Bulletin/Technical Docs Thread - One Stop Shop
This thread is meant to be a one stop shop for all Technical Documentation, Recall, TSB/SIB notices for the M5/M6 and S85 engine. Use this thread as a reference for general understanding, troubleshooting, recalls, issues, for your BMW services centers or indy service shops. If there are any that I missed, please let me know as this thread is a work in progress.
Technical References
E60 M5 Complete Vehicle PDF (also referred to as the "Aftersales Training Manual")
Starting off, here is the one reference everyone should have if you own this car.
E60 Series Information
The next set of PDFs are part of a training program from BMW for M Division vehicles. A lot of the information in here specific to the M5 is identical to the Complete Vehicle document, but there is some more in-depth discussion on the engine components and DME. There is some great engine rebuild discussion and some info on the vacuum booster pump as well that is surprising. Download them all for the table of contents to work properly.
General E60 Series Information
These documents aren't M specific, but do have a lot of useful information on the E60 platform in general.
Service Information Bulletins (SIB) and Technical Service Bulletins (TSB):
**Website links are provided, as well as PDF files are attached to this thread.
*** BMW Changes Oil Recommendation ***
BMW_Oil_Supplier_Listing_Aug2013_V2.pdf
SMG Transmission Service Functions notice
PDF attached
SMG Hydraulic Unit Motor fault: SIB 23 01 07
Ramifications of service bulletin SIB #23-01-07; Carbon Brush Wear
(no PDF for this one)
SMG Hydraulic Unit faults: SI B 23 07 06
website link: http://www.google.com/url?sa=t&rct=j...r5blVlDEuvG8RA
Clutch Service Bulletin: SI B 21 02 06
website link: Clutch Service Bulletin for SMG
SMG III: Fault Code 5101 Analyze Hydraulic Sensor
No PDF, See Post 17
Analyze hydraulic sensor
No PDF, See Post 18
SMG Gear Blocking Faults SI B 23 03 08
SI B23 03 08.pdf
Sunroof Noise: SI B54 04 09
website link: sunroof wind noise??
S85 VANOS Line Replace: SIB 11 10 05 (up to 11/22/05 production)
website link: List of recalls for MY2006/2007
Upgraded Differential Fluid (for grinding noises caused by differential): SIB 33 01 02
website link: http://www.google.com/url?sa=t&rct=j...KrbcBiVh6ykTug
Differential and transmission fluid question
SZL Optical Element (steering angle sensor): SIB 34 05 06 (from 8/26/05 to 7/28/06)
website: 2006 Angle Sensor - Recall # ?
S85 Engine Oil level and Service TSB (1): B11 01 06
PDF attached
BMW TSB # SI B 12 19 08 Engine Electrical Systems
Post 8 below
Service Information: Reset CBS
PDF attached
E60/E63 Recall (Battery Cable)
PDF attached
website link: E60 Recall?
Tire Pressure Monitoring: SIB SIB 36 05 07
website link: 2006 BMW M5 Bulletin - Vehicle Safety TSB ID 320580
Fuel System/Pump Repair: SIB 16 02 09
website link: 2005 BMW M5 Bulletin - Vehicle Safety TSB ID 322547
Voluntary Emissions Recall: SI B12 16 08
website link: 2007 BMW M5 Bulletin - Vehicle Safety TSB ID 281238
Digital Instrument Panel (Gear Selector Display issues): SI B25 01 0
website link: 2007 BMW M5 Bulletin - Vehicle Safety TSB ID 280073
**Master SIB list attached with a PDF
File Type: pdf SIB 33 01 02 Grinding Nosie_Differential fluid upgrade.pdf (32.8 KB, 1591 views)
File Type: pdf TSB B11 01 06 S85 Enginge level & Oil Service.pdf (71.5 KB, 912 views)
File Type: pdf RA Notes on SMG transmission service functions.pdf (20.4 KB, 1292 views)
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops. 12.5mm TMS Spacers.
mdyaman is offline
The Following 12 Users Say Thank You to mdyaman For This Useful Post:
///Mike M (3rd March 2015), 08e60M5SMG (6th November 2012), 5soko (28th April 2013), Benzin (8th June 2013), BMWPower06 (22nd June 2015), canes79 (30th May 2015), Deepblue (23rd January 2014), hk_e60 (6th January 2014), petesamprs (4th November 2012), potassium (8th November 2012), SpeedFreek (5th November 2012), ypeyret (18th August 2014)
post #2 of 36 Old 4th November 2012, 06:23 PM Thread Starter
mdyaman
mdyaman's Avatar
reserved for updates
mdyaman is offline
post #3 of 36 Old 4th November 2012, 06:24 PM Thread Starter
mdyaman
mdyaman's Avatar
mdyaman is offline
post #4 of 36 Old 4th November 2012, 06:25 PM
petesamprs
petesamprs's Avatar
...and stickied. thanks.
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
petesamprs is offline
post #5 of 36 Old 8th November 2012, 05:06 AM
potassium
potassium's Avatar
potassium is offline
post #6 of 36 Old 9th November 2012, 10:07 PM
dhirm5
dhirm5's Avatar
This is great, David; it would be even more helpful if you listed the dates of the various bulletins in the main post so people know which would apply to them.
Thanks for taking the time to put this together.
2014 M5 Comp Pack
Azurite Black over Silver Stone II Full Leather
dhirm5 is offline
post #7 of 36 Old 10th December 2012, 11:54 PM
ykjones
ykjones's Avatar
Thanks much. This is great.
2013 F10 M5 Singapore Gray
Gone but never forgotten:
Dinan/RPi 06 E60 M5. Silver Gray
ykjones is offline
post #8 of 36 Old 4th February 2013, 06:37 PM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
Ran across this one, can't find it on the list here:
SUBJECT: S85 - Power Reduction with Idle Actuator Faults Stored
MODEL: E60 M5 from SOP up to 3/08
E63, E64 M6 from SOP up to 3/08
SITUATION: The Service Engine Soon light (MIL) is illuminated. The engine power reduction mode is activated with any of the following idle actuator (LLS) faults stored:
2B0E: idle actuator, monitoring bank 2
2B0D: idle actuator, monitoring bank 1
2B23: idle actuator, governor monitoring, bank 1
2B24: idle actuator, governor monitoring, bank 2
CAUSE: Certain engine operating conditions could lead to overheating of the idle actuator (LLS) motor electrical components.
If the engine is operated at low load conditions with the idle actuator open and the throttle valves positioned at less that 10% (constant-speed highway driving, for example), the idle actuators could fault.
When the idle actuators (LLS) remain steady in the open positive during this type of driving, it is possible that the contracts on the LLS motor commutator may begin to degrade and cause operational faults.
CORRECTION: The DME software has been improved to include a "wiping function" of the LLS, beginning at a 3% throttle opening. This functional change in the LLS control will help maintain the electrical integrity of the internal motor contacts.
On a customer complaint basis only, reprogram the vehicle with the latest version of Progman.
This DME software improvement is included with integration level E060-08-03-500 and higher.
In the event that one of the idle actuators continues to fault after the DME programming, it will then be necessary to replace it.
jcolley is offline
post #9 of 36 Old 5th February 2013, 03:10 AM Thread Starter
mdyaman
mdyaman's Avatar
thanks for the addition!
mdyaman is offline
post #10 of 36 Old 11th April 2013, 05:04 PM
texsn95
Nice list...I've had the Complete Vehicles list open on my laptop at work for the past week or so, great info.
texsn95 is offline
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests)
Progman v26 Service Information Bulletin (SIB) rslee E60 M5 and E61 M5 Touring Discussion 17 4th February 2013 10:07 AM
Vanos Service Information Bulletin 12 09 07 Digi E60 M5 and E61 M5 Touring Discussion 5 10th January 2008 04:04 PM
M5 Technical Service Bulletin List howler E39 M5 and E52 Z8 Discussion 0 16th November 2004 04:28 PM
Recall and service bulletin site Pete E39 M5 and E52 Z8 Discussion 2 12th July 2004 01:22 AM
Current Recall and Service Bulletin list for MY2000 M5 jkleb E39 M5 and E52 Z8 Discussion 2 5th September 2001 05:22 PM
