DIY: M5/M6/S85 Recall, Tech Service Bulletin/Service Information Bulletin/Technical Docs Thread - One Stop Shop - Page 3 - BMW M5 Forum and M6 Forums
 22Likes
post #21 of 36 Old 30th July 2013, 04:57 AM
spartan///m5
spartan///m5's Avatar
spartan///m5 is offline
post #22 of 36 Old 30th July 2013, 05:18 AM
Lavon M5
Lavon M5 is offline
post #23 of 36 Old 7th October 2013, 05:43 AM
jcolley
m5board.com Site Sponsors
jcolley's Avatar
jcolley is offline
post #24 of 36 Old 26th October 2013, 04:14 AM
5soko
5soko's Avatar
Originally Posted by jcolley View Post
Found a more recent master SIB list: Attachment 228145
Shows we are still looking for a lot of SIBs:
  • SI B12 09 07 May-07 M5/M6 Service Engine Soon Light Illuminated: S85 - Various VANOS Related Faults Stored
  • SI B12 19 08 June-08 M5/M6 V10 S85 - Power Reduction with Idle Actuator Faults Stored
  • SI B12 21 08 April-09 M5/M6 S85 - DME Fault 2742/2743 for O2 Sensor
  • SI B23 01 05 November-05 E60/M5 E60 M5 - CAN Communication Fault FFFF
  • SI B23 01 07 August-07 S85 M5 Service Action: Replace SMG Hydraulic Unit Electric Motor on M5 Vehicles (rpl 7/07)
  • SI B23 08 06 January-07 All SMG Cars SMG - Service Functions Performed after Drivetrain Repairs
  • SI B23 03 08 December-08 M5/M6 M5, M6 with SMG III; FC 4F82/4F83/4F84/4F85 - Gear Blocking Faults (rpl 10/08)
  • SI B32 02 08 August-08 M5/M6 Repair Instructions for Power Steering Pump and Pressure Line
  • SI B33 01 07 October-07 E60 - M5 E60 M5 Howling Noise from Rear Axle Area
  • SI B34 07 07 November-07 M5/M6 M5, M6 - DSC Disabling Function
  • SI B51 06 07 March-07 E60 - M5 Service Action: Replace Underbody Panel
  • SI B65 24 08 December-08 M3/M5 Audio System Is Intermittently Inoperative
  • SI B11 05 07 April-07 All S85 (V10) Service Action: Replace Front Crankshaft Radial Seal
  • SI B12 18 06 November-06 Ms Voluntary Emissions Recall 06E-A04: S85 - DME Reprogramming for OBD Monitoring
  • SI B12 28 08 December-08 S65 / S85 S65 / S85 Rough Running During the Catalyst Heating Phase
  • SI B23 03 06 April-07 M Cars Getrag SMG Transmission Repair & Replacement Information (SMG II and III) (Rpl 02/06)
I will start looking for them, if anyone has access to PDFs of these, post them up and let's all get smarter!
Found one:
"SI B 12 28 08
Engine Electrical Systems
December 2008
Technical Service
SUBJECT
MODEL
E90, E92, E93 M3 with the S65 engine
E60 M5, E63, E64 M6 with the S85 engine
SITUATION
These engines may exhibit rough running characteristics during a warm-up period after they are first started.
Once the engine is at operating temperature, the running quality is normal.
INFORMATION
To meet mandated emission requirements, the engine must operate on a leaner air/fuel mixture during catalyst heating.
This strategy is necessary in order to bring the catalysts up to operating temperature quickly. This catalyst heating phase lasts for approximately 30-40 seconds following a cold engine start.
If the rough running is only present when the engine is cold (warm-up phase) and no faults have been stored in the DME control unit, the customer should be informed about the particular design of M-type engines.
This characteristic of "lean operation in the catalytic converter heating phase" is described in the Owner's Manual under the section "Driving hints", and should be used to answer any questions in the event of a customer
complaint.
If error codes have been stored in the DME control unit, they must be worked through according to the test module/test plan."
2009 ///M5
Evolve Alpha-N Stage 2 Flash Tune | Eventuri Intake Kit | Supersprint Full F1 70MM-Xpipe-Catless
OEM Alcantara tri-stitch steering wheel|LUX H8 160 Angel eyes|Osram CBI's
IND Black Gloss Fender Vents|IND Painted Side Markers
Satin Black OEM wheels |Michelin PSS |30% Tint|LED License Plate lights
BMW Performance Grills|Full OEM BMW LED Interior + Trunk
Oem M projection Door lights|US Mill Work Tow plate|OEM M Floor Mats|Coding
5soko is online now
post #25 of 36 Old 26th October 2013, 04:21 AM
5soko
5soko's Avatar
Found another one:
For cars produced up to 09/08
http://www.google.com/url?sa=t&rct=j...BUX8sGrfLlRTUg
2009 ///M5
5soko is online now
post #26 of 36 Old 26th October 2013, 05:04 AM
jcolley
jcolley's Avatar
Originally Posted by 5soko View Post
Found another one:
Good find man...added to the OP and saved to forum to avoid dead link in the future.
jcolley is offline
post #27 of 36 Old 26th October 2013, 12:20 PM
///'s Avatar
reserved for updates
2008 Sapphire Black / Black M5
-Dinan High Flow Air Intake
-Dinan Software / Evolve R Tune
-RPI Pulley
-RPI Scoops
-Valentine One Stealth Install
-Laser Interceptor
-RPI Headers (Jet Hot Coated & Installed Soon)
-RPI GTC Exhaust (Coming Soon)
-RPI Oil Cooler (Coming Soon)
/// is offline
post #28 of 36 Old 29th June 2014, 12:56 PM
The Engineer
The Engineer's Avatar
Not sure if anyone is aware, but there is a recall on E60 2008+ models for tail lights. Gonna take mine in tomorrow and hope to get more details. Thanks.
The Engineer is offline
post #29 of 36 Old 19th September 2014, 10:40 AM
Sean77
how do i access the link above? i had this problem recently,
same sib number on my work order...
Sent from AutoGuide.com Free App
Sean77 is offline
post #30 of 36 Old 7th December 2015, 05:12 PM
jcolley
jcolley's Avatar
jcolley is offline
Currently Active Users Viewing This Thread: 26 (0 members and 26 guests)
Progman v26 Service Information Bulletin (SIB) rslee E60 M5 and E61 M5 Touring Discussion 17 4th February 2013 11:07 AM
Vanos Service Information Bulletin 12 09 07 Digi E60 M5 and E61 M5 Touring Discussion 5 10th January 2008 05:04 PM
M5 Technical Service Bulletin List howler E39 M5 and E52 Z8 Discussion 0 16th November 2004 05:28 PM
Recall and service bulletin site Pete E39 M5 and E52 Z8 Discussion 2 12th July 2004 02:22 AM
Current Recall and Service Bulletin list for MY2000 M5 jkleb E39 M5 and E52 Z8 Discussion 2 5th September 2001 06:22 PM
